My selfmade superfantastic fan - Fiberglass RV
Old 06-08-2013, 08:11 PM   #1
chse's Avatar
Trailer: 13' Scamp
I wanted to install a fan in my 13' scamp but did not want to cut in the roof or decrease the headroom. My solution was to buy 2 large 220 mm computer case fans from Newegg (Rosewill RCA-220-BL, also on amazon). After getting them I found out that unfortunately the direction is not reversible, but sucking air out is the primary function anyways. To install them in the escape hatch I used 3/4" aluminum brackets, I had to cut the corners off to allow the hatch to close (see picture). Another alternative would be to install them on a plexiglass sheet, that would reduce the circulation around the fans making them more efficient- but also give less air circulation when the fans are not in use. The 2 lines running across the hatch on the 2nd pictures are the same plastic profiles used at the corners for the cabinets, they run under the fand and prevent the insect net to rub on the fan.
chse is offline   Reply With Quote
Old 06-08-2013, 08:22 PM   #2
cpaharley2008's Avatar
sweet...
Jim
Never in doubt, often wrong
Old 06-08-2013, 08:25 PM   #3
deryk's Avatar
New Jersey
Interesting Chris! I was thinking about something similar for extra fan assisted ventilation... How about some more photo's!
deryk
Old 06-08-2013, 08:59 PM   #4
Trailer: Fiber Stream
sweet...
x2
Awesome!
Old 06-09-2013, 07:12 AM   #5
Now THAT'S thinking outside the box. Cool beans!
Old 06-09-2013, 07:45 AM   #6
KevinPete's Avatar
Trailer: 1995 Scamp 13
Very cool, Chris! (pun intended) I was thinking of using 4 120mm fans, but seeing how yours fill up the vent, might go with the bigger fans. Need to figure out a Maxxair-type cover for the escape hatch, anyone seen them made that size?
KevinPete is offline   Reply With Quote
Old 06-09-2013, 08:15 AM   #7
Trailer: 1979 Scamp 16- side bath
Virginia
Great job.
I thought of doing the same just for the efficiency of the brushless motors.
You could mount the motors in such a way that they can swing down and rotate, that way they could direct air either direction, or just blow air wherever needed inside of the cabin. Caframo makes a marine exhaust fan that does just that.
Ryan P R is offline   Reply With Quote
Old 06-09-2013, 10:47 AM   #8
Trailer: Casita 17 ft DLX SD
Emergency Exit
Isn't the roof vent supposed to be your Emergency Exit ? If so are the fans quickly removable ?
steve dunham is online now   Reply With Quote
Old 06-09-2013, 07:56 PM   #9
KevinPete's Avatar
The whole screen unit lifts up and over toward the front of the trailer. Unless you had really short wires, it should still work fine. If I'm scared enough to be climbing out the roof, I don't think either wires or fans would stop me for long!
Old 06-09-2013, 09:58 PM   #10
Ian G.'s Avatar
This system does work great, did a simliar set-up last year and it works great
It Started as a Kitchen Reno- Project Boler
Old 06-10-2013, 05:19 PM   #11
chse's Avatar
Trailer: 13' Scamp
As Kevin stated, the insect net with the lid flips out at as one piece for escape, so yes it still opens normally as long as everything is screwed on the insect-net frame and not the frame of the hatch. I wonder, though, what emergency would make me escape through the hatch .
Old 06-10-2013, 05:27 PM   #12
chse's Avatar
Trailer: 13' Scamp
Wow I did not know that the original fans suck so much air (478-920 CFM). This one is listed at 110 CFM (per fan) and 21dBA, it is nearly silent, the only thing I hear is a low humming. Still good for the 360cu/ft trailer (as you state).
Old 06-10-2013, 07:03 PM   #13
True story. I'd probably never get my bottom up and out in the case of a fire, etc. But, some campgrounds have been known to lose some trees or big branches in windstorms and if your door is blocked, ya gotta figure a way to get out.
Having the whole screen unit lift up is a good idea. Wires can be cut if you have to use the hole as an egress. I think it looks like a good compromise!
Old 06-12-2013, 03:40 PM   #14
dustyjmoon's Avatar
Trailer: 1979 Fiber Stream
So innovative! Love this kind of stuff!!
Rad and awesome!
dustyjmoon is offline   Reply With Quote
Casita fan tractors1 General Chat 7 09-16-2012 06:15 AM
ceiling fan Kenny Strong Modifications, Alterations and Updates 6 04-30-2012 03:43 PM
Fan-tastic Fan Seller - Best Price I Found barryra General Chat 1 07-11-2011 04:51 PM
Fan vs. A/C Time K General Chat 2 09-01-2008 05:48 PM
Fan-tastic fan Ken&Chris Problem Solving | Owners Helping Owners 13 04-11-2006 07:15 PM
