My virgin scamp got a stripe! - Page 2 - Fiberglass RV
Old 05-13-2013, 03:24 PM   #15
chse's Avatar
Trailer: 13' Scamp
Originally Posted by RRJR View Post
I washed my 75 green Trillium with Vim cream bathroom and kitchen cleaner.It has a very small amount of abrasive in it but does a great job on the chalky removal. Washed twice, rinsed 2x and then 5 Coates of Zep wet look floor finish. You don,t see the shine till after the 3rd coat but then the effort is rewarded. Looks great. When applying the Zep,just wet the rag, wring it out and just like damp cloth wipe. It drys in a few mint so time you do fist coat you can start again.
Good luck.
I am just done with the zep, too. Nice and shiny :-). For some reason the oxidation remover created a slight off-white,eggshell tone. I like it but its maybe not for everyone. I also learned to wash the rag once or twice before using it .... that's in another post.
chse is offline   Reply With Quote
Old 05-15-2013, 09:01 AM   #16
Davie B's Avatar
Trailer: Lite House
How did you replace the covers on the pop rivets?
Davie B is offline   Reply With Quote
Old 05-15-2013, 04:52 PM   #17
chse's Avatar
Trailer: 13' Scamp
There is several posts about this f.e. here:
Rivet replacement
Replacing rivets?
The covers pop off easily with a screw driver, if the shell around the rivet is still intact you can order replacements from Pro-Dec: Manufacturer of Screw Covers, Screw Caps & Snap-Caps®
"The sizes you will need are 8/8-100 for the curtain rod rivets and 12/12-100 for the larger rivets.
The bases are sold seperately 8/8 FB and 12/12-FBA"
Replacing rivets?
or at scamp https://shop.scamptrailers.com/c-15-...c-washers.aspx
Old 05-15-2013, 05:10 PM   #18
chse's Avatar
Trailer: 13' Scamp
Forgot, if the shell around the rivet is gone you will have to to replace the rivet. I think its easiest to get the rivet/acorn nut/snap cap set from scamp.
- You will need a helper who holds the nut from the inside while you drill out the rivet outside with a 1/8 drill (otherwise it might spin).
- Remove the rivet and put the plastic shell on the new one and put it through the hole, put the nut on on the inside and verify that the rivet is short enough so that the nut can not push it outside, but long enough to reach inside the nut.
- most of the times you will have to shorten the rivet, use a vice and hammer out the stem, than saw of the aluminium part to the right size. Re-insert the stem
- wrap some butyl tape around the rivet close to the cap, put it in the hole, have someone hold the nut on inside and install the rivet with the rivet gun.
- do one rivet at a time
This is much less complicated than it sounds, once you have the parts its easy. Do not use silicone since the rivets move around during traveling (and Donna hates it). Get a good rivet gun with 2 long handles (like Dorman 743-100 Rivet Gun).
Old 05-15-2013, 07:03 PM   #19
that I do
15 minutes with a 3M™ Stripe Off Wheel - Bigfoot trainjunkie Care and Feeding of Molded Fiberglass Trailers 11 06-29-2012 04:39 PM
Play Pac mid section racing stripe removal Meghan Care and Feeding of Molded Fiberglass Trailers 2 08-21-2011 02:52 PM
I am no longer a virgin Gina D. Problem Solving | Owners Helping Owners 24 03-26-2007 06:54 AM
St John US Virgin Islands Maggie O. Camping, Campout Reports 7 02-25-2006 02:30 PM
