05-03-2013, 06:43 PM
Trailer: 13' Scamp
My virgin scamp got a stripe!
I am not a big fan of scamps huge labeling on the side with the stripes ending nowhere specific and was happy that the one I found had no stickers at all. Still I thought it looked a bit blunt and ordered a red stripe and the small old name tags from scamp. Here is what it look like-
I also treated the surface with oxidation remover and washed it with TSP (tri-sodium phosphate) and dawn to remove oils. Hope its ready now for the wet-look floor finish, did someone ever try that without the barkeepers friend scrubbing?
before with old rivets:
05-03-2013, 07:07 PM
Trailer: 1984 16' Scamp
Looks real nice! Whered you get the strip and how many feet did you need to go all the way around?
05-03-2013, 07:09 PM
chris---i like it! you chose well. it is striking how much of a difference a simple stripe can make.
05-03-2013, 07:23 PM
Perfect for you! Love it when a plan comes together Thanks for sharing the pictures, visuals always help.
05-03-2013, 07:31 PM
Glade Valley, North Carolina
Stripe and name tag looks great. Nice Job. Thanks for sharing.
“I have tried to live my life so that my family would love me and my friends would respect me. The others can do whatever the Hell they please!” —John Wayne
05-03-2013, 07:40 PM
Trailer: 13' Scamp
Thanks - I am really happy with it. After a day of scrubbing that was a nice finish.
Ryan- the stripe and decals are from Scamp Trailers Parts. I ordered 36 feet ($25.20) and had about 3 feet left.
05-03-2013, 07:52 PM
Chris, whether or not you choose to use Bar Keepers Friend has to due more with a chalky finish. If you think the trailer is spectacularly clean, then I'd say... it isn't needed. But if you see chalk anywhere, then use it. A couple more hours of scrubbing may be worth it. Remember, anything left on the trailer is going to be "sealed" into the finish when you put Red Max Pro (ZEP) on it. You don't want crud showing through.
05-03-2013, 08:55 PM
Trailer: 13' Scamp
Thanks for the advice. It looks pretty clean and smooth, I first thought polishing with a marine polish will do it but that resulted in rain stripes and there were some discolorations. I washed the polish off and polished it again with oxidation remover, now its nice and white, I did 2 more washes with TSP and dawn, my biggest concern is that there is still some wax left. I'll see to tomorrow hope its not to windy.
05-03-2013, 09:00 PM
Trailer: Trillium 4500
Looks real classy with just a small name on it. I noticed you don't have any fridge vents, do you have a fridge or just an icebox?
05-03-2013, 09:25 PM
Trailer: 13' Scamp
It only has an ice box. We mostly want to use it on weekends and for that the ice box works well, thats how we camped before in a tent. Maybe one day I will put a small fridge and an inverter. Interesting that you mention the vents, the other 2 scamps I looked at had both rotten floors under the fridge since the condensation water could not drain and there was no vent.
05-04-2013, 03:25 AM
A classic. Nice job. Raz
05-12-2013, 09:41 AM
Name: Norm I want to thank all the Kings horses and all the Kings men
Trailer: 73 Scamp 13'
I really like the stripes. I think I may steal your idea since I just painted mine. You are lucky not to have vents on the side. The only place I had rot was under the fridge. Good job!
05-12-2013, 09:58 AM
I washed my 75 green Trillium with Vim cream bathroom and kitchen cleaner.It has a very small amount of abrasive in it but does a great job on the chalky removal. Washed twice, rinsed 2x and then 5 Coates of Zep wet look floor finish. You don,t see the shine till after the 3rd coat but then the effort is rewarded. Looks great. When applying the Zep,just wet the rag, wring it out and just like damp cloth wipe. It drys in a few mint so time you do fist coat you can start again.
Good luck.
05-13-2013, 03:19 PM
Trailer: 13' Scamp
Thanks, if you order the stripe from scamp their shipping is a bit expensive I browsed through all their stuff to make sure I do not forget anything.
05-13-2013, 03:24 PM
Trailer: 13' Scamp
Good luck.
I am just done with the zep, too. Nice and shiny :-). For some reason the oxidation remover created a slight off-white,eggshell tone. I like it but its maybe not for everyone. I also learned to wash the rag once or twice before using it .... that's in another post.
05-15-2013, 09:01 AM
Trailer: Lite House
How did you replace the covers on the pop rivets?
05-15-2013, 05:10 PM
Trailer: 13' Scamp
Forgot, if the shell around the rivet is gone you will have to to replace the rivet. I think its easiest to get the rivet/acorn nut/snap cap set from scamp.
- You will need a helper who holds the nut from the inside while you drill out the rivet outside with a 1/8 drill (otherwise it might spin).
- Remove the rivet and put the plastic shell on the new one and put it through the hole, put the nut on on the inside and verify that the rivet is short enough so that the nut can not push it outside, but long enough to reach inside the nut.
- most of the times you will have to shorten the rivet, use a vice and hammer out the stem, than saw of the aluminium part to the right size. Re-insert the stem
- wrap some butyl tape around the rivet close to the cap, put it in the hole, have someone hold the nut on inside and install the rivet with the rivet gun.
- do one rivet at a time
This is much less complicated than it sounds, once you have the parts its easy. Do not use silicone since the rivets move around during traveling (and Donna hates it). Get a good rivet gun with 2 long handles (like Dorman 743-100 Rivet Gun).
05-15-2013, 07:03 PM
that I do
