Need Help - Solar Charging Question - Fiberglass RV
Old 04-16-2014, 10:51 AM   #1
Trailer: ParkLiner
Virginia
I'm trying to do what I have read others here have done.
I have a 100 watt solar panel (RENOGY 100W Watts 100 Watt Polycrystalline Solar Panel) connected to a charge controller (Renogy 30 Amp PWM Charge Controller Regulator Off Grid for Battery Charging).
The output from the charge controller is connected to aux power and ground on a 7-way blade rv connector (vehicle side).
Before I plug it in to the trailer connector, I want to make sure the voltage level is right. I'm reading 21.5 volts. Does this seem right?
Huck is offline   Reply With Quote
Old 04-16-2014, 11:04 AM   #2
Gina D.'s Avatar
It could be right if measuring directly from the panels. If you are measuring the output of the charge controller, it should be in the 12 to 14.5 volt range, given your panels are in full sun. (Depends on the controller you have)
Old 04-16-2014, 11:07 AM   #3
Jon Vermilye's Avatar
Trailer: Escape 17 ft Plan B
While that sounds like the normal voltage from the panel, it is high for the output of the controller. I'm not familiar with their controller - it may be that it does not provide the proper voltage unless connected to a battery. Depending on the state of the battery, the output should be in the range of 13.2 - 15 volts when connected.
Old 04-16-2014, 11:10 AM   #4
Trailer: ParkLiner
Virginia
I'm definitely going through the controller.
Old 04-16-2014, 11:26 AM   #5
If it was me, I'd try connecting it to a stand alone battery first to see if it drops to the proper voltage. I'll bet it does, but I wouldn't want to risk the trailer's electronics finding out...
Old 04-16-2014, 11:41 AM   #6
Trailer: ParkLiner
Virginia
Thanks everyone. I just got this response from Renogy. I asked them the same question I posted here.
Yes, that is the open voltage (when there is no load connected). When you connect a solar system, you want to connect the battery first to the charge controller and then the solar panel.
I have another related question, but will start another thread.
solar
Charging deep cycle batt. with car alternator - Do I need a charge controller??? Roo-lot Problem Solving | Owners Helping Owners 31 03-02-2018 05:00 PM
Solar charging system completed ruscal Modifications, Alterations and Updates 15 12-07-2013 08:56 PM
Need help connecting my solar panels Mouse Electrical | Charging, Systems, Solar and Generators 27 02-20-2012 05:40 PM
Battery charging question Kent I Problem Solving | Owners Helping Owners 4 12-29-2008 06:30 PM
Another battery charging question Sonny Care and Feeding of Molded Fiberglass Trailers 8 09-30-2006 08:14 PM
