Need help with 12v fuse panel and wiring update - Fiberglass RV
Old 03-24-2011, 01:37 PM   #1
Firt off i want to apologize for the basic question on how to wire in this type of 12volt fuse panel. Here's the link http://www.princessauto.com/trailer/...-circuit-panel
I need to update the wiring in my 76 boler and i'm looking at this 6 fuse panel. I'm not sure if the screw terminal at the rear is for the ground or power. I'm going to run my lights to a couple of the circuits, eletric water pump that i'm going to install soon to anther, and in the future a fantastic fan to another circuit.
I was hoping i could just find a 12 volt fuse panel where i could run a 10 guage or so positive from the battery to it, and then also ground the panel to the frame, and then run my positive and negative out to each appliance. Like i mentioned, sorry if i'm totally off and this question has been covered numerous times before. A little help would be appreciated.
Mike
Michael Collins is offline   Reply With Quote
Old 03-24-2011, 02:33 PM   #2
Trailer: 1989 Bigfoot
12 volt panel
The panel has 6 circuits with a fuse holder for each ,the termial at the bottom center is the power imput If the panel is close to the battery 10ga should be good , lights ,water pump,furnace. If you are going to play with bigger toys You might want to go with a bigger wire ga and get away from a plactic fuse holder
ken h is offline   Reply With Quote
Old 03-24-2011, 02:37 PM   #3
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
This one is a little cheaper AUTOMOTIVE FUSE PANEL - eBay (item 190515253611 end time Mar-29-11 09:51:49 PDT)
web site here Blue Sea Systems
Old 03-24-2011, 02:50 PM   #4
12 volt panel
A little example , one or two circuits hope this helps
Old 03-24-2011, 03:25 PM   #5
Raz
Raz's Avatar
Vermont
As Kens picture shows, ground is not involved in this fuse box. It is very seldom that you put a fuse in a ground(return) line.
Do you have a multimeter with a continuity tester? Most useful with these type of issues. If you were to take the fuse holder and put a fuse in one of the positions, a continuity tester would let you verify how the holder is constructed. Just a thought, Raz
Raz is online now   Reply With Quote
Old 03-24-2011, 03:26 PM   #6
Thanks for the replies guys. So on the written diagram you provided is the triple horizontal lines at the end of the cirucuit a required ground? Is there an easy way to use a shared ground for all circuits? Thanks again
Old 03-24-2011, 03:35 PM   #7
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
ken h example Click image for larger version
Old 03-24-2011, 03:41 PM   #8
I don't have a continuity tester. I'm new to wiring a trailer but as a kid i wired up my car stereos all the time. Right now my trailer has no fuse panel. All i have are lights and i believe they have an inline fuse somewhere under the sink. I want to connect my sureflow pump i bought and also just clean up the wiring. I have different colours of wiring running everywhere. That's where i thought a common fuse panel labeled of course would just make it look neater and more organized. If there is a better way to do this please let me know. All i know is that my trailer's 110 system is totally seperate and that the original 110 panel works but is pretty much useless with it's one 110 plug in. Don't want to get off topic, i'd just like to update the wiring in my old yellow trailer.
Old 03-24-2011, 03:47 PM   #9
Ok, so that looks simple. Thanks so much for the quick replies. So i ground the battery to the frame from the negative terminal, then run a 10 guage or larger wire to the fuse panel, then all i have to run is a positive to each appliance, with a switch inline if required. Looks very simple. I have a switch for my water pump that i'll splice in. My furnace has no fan so no need for 12 volt power. I don't think i'll wire my old original dometic rm21 to 12v. One more silly question, do the inline switches require their own ground? I have one that has 3 terminal prongs off the back of it and it has a led to show when the circuit is active. Thanks again to those who have helped. Hope i've understood this correctly. Looks very simple on the 12v side.
Mike
Old 03-24-2011, 04:09 PM   #10
Originally Posted by Kevin K View Post
ken h example Attachment 34260
Thanks Kevin ; Looks like you are also handy with your computer as well as wiring
Thanks again
Old 03-24-2011, 06:47 PM   #11
Raz
Raz's Avatar
Vermont
Mike
No ground on the switch. It's center to one side in one position and center to the other in the second position. Use the center and either side. Another good use for a multimeter with a continuity tester. Poke poke
Old 03-26-2011, 10:08 AM   #12
Joe MacDonald's Avatar
If the switch has a light in it , it most likely needs a ground to make the light work. which terminal it is, well that changes by manufacturer.
Joe
Old 03-26-2011, 10:16 AM   #13
Raz
Raz's Avatar
Vermont
Joe
Since it's a pump switch, you are probably right. I was thinking a SPDT toggle switch. Good call. Raz
Old 03-26-2011, 08:59 PM   #14
So just so I have this correct, do I need a positive and ground going to each appliance? That's the way it is now in my trailer. If so, how do I make a common ground?
Need guidance wiring 12v Distribution panel francene Problem Solving | Owners Helping Owners 13 11-02-2009 12:16 AM
Trailer Wiring BLOWING Fuse! Help, PLEASE! francene Problem Solving | Owners Helping Owners 5 08-10-2009 01:09 AM
Converter & Fuse Panel Nita F. Problem Solving | Owners Helping Owners 5 09-03-2006 07:44 AM
fuse panel Rick and Shannen Problem Solving | Owners Helping Owners 24 02-23-2006 12:55 PM
Fuse Box Wiring HELP PLEASE!! shawnswan Problem Solving | Owners Helping Owners 10 02-07-2006 04:06 PM
» Virginia Campgrounds
