New access hatch install? - Fiberglass RV
Old 09-07-2014, 05:28 PM   #1
jlbails's Avatar
Trailer: Boler 1977
Has anyone installed a new outside access hatch door for the dinette storage in a Boler?
I picked up a used hatch door at a swap sale this weekend. Just wondering if someone knows of a good video or photo instruction for doing the new install into the fiberglass body that I could view before I begin measuring and cutting.
Jamie
jlbails is offline   Reply With Quote
Old 09-07-2014, 05:43 PM   #2
Jim Bennett's Avatar
I cut a larger hatch into my Escape, an easy thing to do. Not sure if the curve of your Boler would be a issue, or not, but I have seen others with them. All you need to do is to hold the hatch into place where it is to go, and trace around the inside rim (on masking tape put on the trailer). You can then cut the fiberglass with a jigsaw, Dremel tool, or something similar that will give you a fairly smooth cut. Then clean the edges up with a bit of sandpaper. Put the hatch back in place, and mark the mounting holes to drill. Put some butyl tape around the edge between the flange and the trailer, then rivet it into place.
Here is a link to a write up I did on the Escape site.
http://www.escapeforum.org/forums/f8...-19-a-812.html
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 09-07-2014, 06:17 PM   #3
Jamie
Before cutting define the area where the hatch can be mounted. As others have done get some rare earth magnets from Harbor freight. Attach (tape) four magnets to the inside wall of the trailer. Two at the floor and two under the seat support to the fore and aft of your usable space under the seat then attach four magnets to the outside of the shell that lines up with the inside magnet. This will outline your usable space. Makes sure the outside of you hatch flange fits this area because your attaching hardware has should be accessible. Then follows Jim's directions.
If the shell has an extreme curve attach the top and upper sides to the shell. I cut PVC trim lumber to shim out the lower sides and bottom and use butyl tape on both sides of the lower shims.
Eddie
Old 09-07-2014, 06:30 PM   #4
Hatches don't bend! Just make certain your cut is on a FLAT space.
Old 09-08-2014, 04:12 AM   #5
Ron F's Avatar
Donna's right. You need a flat surface. Peterh did an excellent description of a hatch install here: http://www.fiberglassrv.com/forums/f...tch-34476.html
Ron
Ron F is offline   Reply With Quote
Install an Access/Compartment door on a 13 ft Scamp katmaicub Problem Solving | Owners Helping Owners 19 05-13-2013 04:18 PM
exterior access hatch and exterior shower aimeelightsey General Chat 36 10-06-2012 03:15 PM
Adding exterior access hatch Roger Harshaw Modifications, Alterations and Updates 21 05-12-2012 08:18 AM
Want to install fan but hatch is weird size jeckel30 Problem Solving | Owners Helping Owners 5 07-01-2011 06:07 PM
Golden Age Passports Replaced by New Interagency Senior/Access Recreat Adrian W General Chat 4 07-26-2008 12:50 AM
