New Allure Flooring - Scamp 13' - Fiberglass RV
Old 09-23-2013, 11:06 PM   #1
Trailer: 2002 Scamp 13' Std, Rav4 - 6 cyl
Hi all,
Pulled out the Scamp basic brown carpet and replaced with the Allure, 'Lisbon Cork'. I used the original Allure, not the Ultra version (mostly b/c the Ultra was not available when I bought it last year.... yes...it's been sitting on the to-do list since last year)... Anyway --- went down fairly easily. I laid down a layer of 3mm closed cell insulation underneath to hopefully add a little warmth. After pulling out the carpet, there was enough space under the benches "upstairs" that I could run the planks under the benches and still keep the floor floating. I did have to sand and tidy up the bottom of both benches to make sure there was full clearance all along the bottom edges. The stair nose is epoxy'd to the flooring so it all floats. To fill in the unused screw holes in the metal nose strip, I used hardened steel machine ball bearings epoxy'd in place. I did glue the stair riser planks and the toe kick planks (under the kitchen area) to the metal frame of Scamp.
For the "downstairs" I used spacers around the entire perimeter to maintain the factory recommended 1/8th " expansion/contraction gap and then caulked with DAP Dynaflex 230 elastomeric caulking that was the same color as the flooring (pure luck that it matched). The edges came out so cleanly that I decided to forgo using quarter round edging or baseboards, etc.
I've never done flooring of any kind before so I went really slowly and multi-measured and dry fitted EVERYTHING before I cut or laid anything down. Also -- the Allure glue edges are really sticky. Someone in this forum advised to use wax paper strips on the glue edges until you get ready to actually stick them together to keep debris off them -- that was very good advise and helped a lot.
Really happy with it. I think it will be a bit chilly on the toes, but a couple little rugs should fix that. Oh -- and for an added put-yer-feet-up comfort piece while sitting at the table, I made a little "ottoman" out of the scrap wood from the cupboard doors that fits in the groove for the table/bed. It is padded and slides back and forth and then stows up above or on the floor when sleeping. Two people can use it at the same time.
Good fun. Take care.
Shannon
Shannon Thompson is offline   Reply With Quote
Old 09-23-2013, 11:12 PM   #2
Looks great. I like the color.
Old 09-24-2013, 05:50 AM   #3
Tim Wood's Avatar
Trailer: Class B for now
NY
Very rich looking, nice job.
Old 09-24-2013, 06:20 AM   #4
kdhanso's Avatar
Very nice! Thanks for sharing the details. This is on my to-do list as well.
Ken
kdhanso is offline   Reply With Quote
Old 09-24-2013, 06:24 AM   #5
dondon's Avatar
Trailer: 1989 Burro
I love the cork! Great job installing too.
Don & Marilyn
dondon is offline   Reply With Quote
Old 09-24-2013, 08:06 AM   #6
Trailer: 2010 Escape 17B
Really like the look, great job.
kootenaigirl is online now   Reply With Quote
Old 09-24-2013, 01:32 PM   #7
Trailer: '77 Scamp
Beautiful installation job. Its amazing what a difference new flooring makes in our little trailers.
Otters is offline   Reply With Quote
Old 09-24-2013, 02:16 PM   #8
Trailer: asdf
Alabama
On my todo list as well. I love the cork wood at the local Lowes. Real wood (laminate of course). I like the lighter color.
That is pretty stuff.
jwcolby54 is offline   Reply With Quote
Old 09-24-2013, 05:09 PM   #9
Lil M.'s Avatar
Trailer: '84 13' Scamp & '14 homebuilt Benroy Teardrop
Looks great Shannon!
I love the ottoman idea. Will have to execute it out of some scraps from my floor installation job.
Lil M.
“When one tugs at a single thing in nature, he finds it attached to the rest of the world.” ― John Muir
Lil M. is offline   Reply With Quote
Old 09-24-2013, 06:53 PM   #10
Trailer: Chalet
Send a message via Yahoo to Lynn Musgrave
Sorry Shannon....we cant beleave you made it IF we don't see a picture!
Really it does sound interesting and a picture would be great. Love the flour,much better than carpet and throw rugs will take care of the cool toes.Plus throw rugs are easy to shake out and wash.
Lynn Musgrave is offline   Reply With Quote
Old 09-24-2013, 07:47 PM   #11
Lil M.'s Avatar
Hi Lynne,
You can see it in the 4th picture-the one with the table leg. It's straddling the upper floor and resting on the ledges where the table rests in bed-mode.
Lil M.
Old 09-24-2013, 07:59 PM   #12
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Looks great.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 09-24-2013, 11:29 PM   #13
peterh's Avatar
Nice looking job. As for your having gone "really slowly and multi-measured and dry fitted EVERYTHING before I cut or laid anything down," I still do that on most things.
Old 09-25-2013, 12:00 PM   #14
Hey Lynn -- so bossy!
Attached are a couple pics.... the ottoman idea was kind of an after thought idea when doing remodel to Scamp but has turned into one of my favorite useful upgrades. When sitting at the table, I'm not tall enough to reach across to the other bench and put my feet up, so the ottoman solved that issue. It is so nice to 'lounge' at the table when reading or futzing on computer, or whatever.
As far as building... simply an 8" wide piece of board (I used scrap from the redo of cab doors -- 1/2" Baltic birch ply); finished it with Helmsman Spar; rounded off the lower edges so it seats well into the groove for the table/bed and allows it to slide easily to where you want it. Then used a 2" piece of foam, some batting, cloth stretched and stapled to the bottom side and voila -- ottoman. (have you ever reupholstered a dining room chair? Same idea) When not in use, I just slide it to the back wall out of the way or put it in the upper stow.
Flooring Allure Brian E Moon Modifications, Alterations and Updates 31 08-06-2014 05:43 AM
new Scamp flooring beardrum Modifications, Alterations and Updates 6 09-04-2013 12:40 AM
Allure flooring. Install <65 degrees F? Tonia Modifications, Alterations and Updates 31 07-19-2013 12:12 AM
The Allure's done cannibal53 Modifications, Alterations and Updates 1 06-26-2013 08:33 PM
Allure flooring? How did you finish the edges? Liz&Kev Problem Solving | Owners Helping Owners 12 05-08-2010 12:18 PM
