New Axle - Fiberglass RV
Old 07-04-2009, 04:36 PM   #1
Trailer: 1978 Surfside
Cool
Just thought I show off the new axle that I bought from Standens here in Calgary. First the old one and then the New one
kentj is offline   Reply With Quote
Old 07-05-2009, 03:09 PM   #2
Trailer:
A question for you - aren't those suspension arms on backwards? I expect to see the suspension arms fitted on the same side of the axle tube as the long side of the mounting brackets - just like on your old axle.
As it stands in the new axle photo, the weight of the trailer is being carried outside the mounting brackets, putting extra strain on them, plus the bolt at the opposite end will be permanently in tension as the mounting bracket tries to pull away from the frame.
I'm not saying I know it's wrong - just that it would be worth checking if it's right.
Andrew
axle
To re-axle or not to re-axle Greg G. Care and Feeding of Molded Fiberglass Trailers 11 05-02-2010 08:50 AM
Need a new axle? Rarebird Towing, Hitching, Axles and Running Gear 2 01-31-2008 02:56 PM
axle is an automotive axle on my casita tracy.c Towing, Hitching, Axles and Running Gear 26 07-30-2007 04:50 PM
Axle JohnWalker Towing, Hitching, Axles and Running Gear 5 04-21-2006 07:57 AM
To re-axle or not to re-axle Cherylw Modifications, Alterations and Updates 0 01-01-1970 12:00 AM
