New counter tops?? - Fiberglass RV
Old 06-19-2014, 10:21 PM   #1
Trailer: Burro 13'. 1982
Montana
New counter tops??
I'm thinking about changing out the wooden counter top to something nicer.......not sure what. This is my only counter top.......where the stove and cooktop sit. Is this a major project or something relatively simple? Got a jig saw, circular saw, and a chop saw........decent skills.
Lfoxmont is offline   Reply With Quote
Old 06-20-2014, 12:20 PM   #2
Montana
Here's a pix.
Name:	ImageUploadedByFiberglass RV1403288426.030837.jpg
Old 06-20-2014, 12:39 PM   #3
Timber Wolf's Avatar
North Florida
I am pondering this myself. I am planning to remove the gas (three burner)cooktop in my Scamp 16 and replace it with a smaller (two burner) electric top leaving a hole. I am actually considering wood which would add a little weight (not much though) or laminating the whole top with some Formica. I just don't know how that would work with the curves in the front and back at the backsplash though. Some thin (hard)wood with an inlaid poly cutting board would be cool.
Old 06-21-2014, 06:28 PM   #4
Unless you gain major functionality or cleanliness.. why the change? I've seen (on the CaisitaForum) someone that changed their countertop to Corian. Absolutely, positively beautiful but added a bunch of weight.
Old 06-21-2014, 07:04 PM   #5
Montana
Donna........I just don't like the dark, heavy wood. I replaced the door to the left of the refrigerator with a curtain made from the window curtains materiaI. Will probably sand the remaining doors and paint them something light. Maybe that would be the easiest thing to do....just sand and repaint the kitchen counter with a good semi gloss......
By the way.....what does YMMV mean when you sign off of a post?
Old 06-21-2014, 07:11 PM   #6
YMMV = Your Mileage May Vary
My thoughts/ideas may not be the same as yours.
I like the idea of a good quality paint. May really brighten up the area! If it doesn't work out, then you can move ahead with something else. So... I'm cheap
Old 06-21-2014, 07:13 PM   #7
Why not a laminate?
Old 06-23-2014, 03:42 AM   #8
Trailer: 1972 Trillium
Nova Scotia
Originally Posted by Glenn Baglo View Post
Why not a laminate?
There's no reason you couldn't use laminate, but it may be heavier than what is there now.
Harvey
Harvey9 is offline   Reply With Quote
Old 06-23-2014, 05:56 AM   #9
Laminate weighs next to nothing, certainly compared to tile or Corian.
Old 11-30-2014, 09:20 AM   #10
Trailer: 1983 13' Scamp
South Dakota
My stove was removed so I pulled out the sink. Using a piece of 1/2" plywood I cut a piece to fit the entire top. A local church minister had been a cabinet maker and had a scrap of laminate just the right size. He installed the laminate. I used rv caulking to glue it to the fiberglass reinstalled the sink in its original holes added faucets and rope molding to the edges. Nice big countertop and not too heavy.
SimplyLesa is offline   Reply With Quote
Old 12-01-2014, 07:44 AM   #11
Trailer: Airstream 23D International Serenity
Actually, there are a couple of us who have done this (Corian countertop), maybe more. While Corian is heavy as all get-out, there is so little of it left after making the sink and stove cut-outs, I considered it a non-issue. The problem I found with Corian is that it's so darned hard to locate.
Rob
Rob & Linda
Our EX-Casita photos: http://www.flickr.com/photos/rfpd300/sets/72157626742329244/
Rob and Linda is offline   Reply With Quote
Old 12-01-2014, 11:45 AM   #12
Trailer: 13' Scamp
If you are going to replace the counter top. I would replace the stove and sink with a combined unit with a glass top. That would give you more counter space and the amount of work would be the same. I vote for laminate counter top. I glued some directly onto the fiberglass and it cleans much more easily then paint ever will. Replacing counter top is a lot of work by the way because you pretty much have to take everything apart.
KevinScamps is offline   Reply With Quote
Old 12-01-2014, 12:50 PM   #13
tractors1's Avatar
Trailer: Escape 21 - Felicity
Corian can be tough to locate, but can be ordered in 1/4 inch thickness to keep the weight down if you overlay the existing surface. Because it is actually a thermoplastic, it works pretty easy with standard woodworking tools. It is bonded with a specialized 2-part adhesive that is spendy - $42 a tube (including mixing nozzles.) It can also be shaped by heating to create an edge radius.
Charlie Y
Charlie Y
Old 12-01-2014, 04:18 PM   #14
Dudley's Avatar
Trailer: 1998 Casita 17 SD
If the countertop you have now is in fairly good shape and is still stuck down to the wood , you could just ruff it up with sand paper and glue the new laminate over the old. Of course, you would have to pull the countertop and remove the sink, taps and stove. You would need a router and laminated trimming bit to trim it down. I used aluminium trim on mine when I did the Ventura countertop. I know Rona hardware up here sells 2'x4' laminate for about $5 and a can of contact cement and a paint brush or roller = a cheap redo!
Cool New Counter for My Trillium Emily R. Modifications, Alterations and Updates 17 08-12-2013 05:50 PM
My new counter uhaulin Modifications, Alterations and Updates 20 05-14-2013 05:45 PM
Counter Extension Don N Problem Solving | Owners Helping Owners 8 07-24-2009 09:51 PM
ceramic tile counter and back splash Robert W. Problem Solving | Owners Helping Owners 14 02-18-2008 02:01 PM
