New entry stool - Fiberglass RV
Old 08-01-2014, 05:12 AM   #1
frank_a's Avatar
Trailer: 2012 ParkLiner #006
New entry stool
I can't easily get in and out of our egg. I got tired of looking for a stool to buy (none were just right), so made my own!
Scrap rough 3/4 plywood. Still needs sanding and finishing.
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
Old 08-01-2014, 06:23 AM   #2
I put rubber stair runner on top of the one I made. Kept it low and wide to prevent tipping if we stepped off center. When traveling it is upside down just inside the door and holds our front stabilizers and wheel chocks.
Old 08-01-2014, 06:33 AM   #3
frank_a's Avatar
Good idea. I was thinking of sprinkling sand in the polyurethane for the top, but stair runner is a better idea. I don't think this one will tip over very easy.
Frank
2012 ParkLiner #006
Old 08-01-2014, 06:50 AM   #4
Steve L.'s Avatar
Trailer: 2003 Casita 16' SD
That looks like a rock-solid step. Good job. I usually use spar urethane (Minwax) for outdoor wood projects that are unpainted. UV and weather resistant but it doesn’t want to go over paint . Sand in the finish, outdoor carpet (a cut piece out of a door mat), synthetic turf or a rubber strip are all options. I’m thinking you’d want any ribs in the top surface of the rubber to be oriented side-to-side for maximum slip resistance stepping in or out. That or find some sort of non-directional surface design.
From a slightly different perspective, I’ve gone through a number of steps over the years. Most of them were that small folding plastic step that hinges down the center and folds flat. Inexpensive, compact and light. The eventual problem with that was that it was too small of a target (I have a small issue with fine motor control for foot positioning others may be familiar with) and it didn’t always present a flat level surface due to ground slope outside the door. I eventually went the adjustable leg folding step. Really kind of expensive (~$100) but in the end I’ve decided it’s probably one of my better purchases.
But I didn't get the satisfaction of making my own.
Old 08-01-2014, 06:59 AM   #5
I agree with Steve, if you use the rubber stair runner put the ridges side to side for more slip resistance. Our step is 7" high, 20" wide, 18" deep, and it will tip if I step on the edge so I'm careful to position it correctly in front of the door. I really like the one that another member here recently posted he made where the sides taper out to make it more stable.
Old 08-01-2014, 07:31 AM   #6
The Minimalist's Avatar
Louisiana
I also put some red reflective tape on the front and rear edges of mine to make it easier to see in the dark. Our porch light is none too bright.
Clif
Old 08-01-2014, 07:39 AM   #7
frank_a's Avatar
Another excellent idea! I love fgrv!
Thanks.
Frank
2012 ParkLiner #006
Old 08-01-2014, 07:46 AM   #8
Timber Wolf's Avatar
North Florida
Nice, I even have some suitable scrap plywood in the "inventory". The only problem is I don't think I have time to knock one out before we leave next week. I have the step the PO left with the rig but it is too heavy although it works well enough. I like the idea about flipping one like the Frank made over and storing stabizers in it. I did not like all the flexing going on entering and exiting the Scamp so bought a little screw-jack to put under the frame in camp and the upside-down step would be a great place to store it on the road.
Old 08-01-2014, 07:48 AM   #9
There is yellow or red floor marking tape available that I used on the edges of stair treads in the retirement home I worked at part time, but I couldn't find it locally and ended up buying a big roll online.
Old 08-01-2014, 07:53 AM   #10
I did not like all the flexing going on entering and exiting the Scamp so bought a little screw-jack to put under the frame in camp and the upside-down step would be a great place to store it on the road.[/QUOTE]
Our Uhaul has the flip down telescoping stabilizers in the rear but nothing in the front. I had to shorten a pair of the screw type to fit under the front corners. With our step flipped over I also keep the rear stabilizer handle and a few short boards for under a tire for leveling or under the stabilizers on soft ground.
Old 08-01-2014, 08:11 AM   #11
TomK's Avatar
Looks like a real nice step Frank. Good and sturdy. I'll probably end up building a longer and wider box-type step for our Scamp 13. We probably don't need one for the low height entry, but it will serve to hold chocks, blocks, etc when traveling. I need it shorter, wider, and longer than your's to give our 14 y.o. dachshund better access. He doesn't do tall normal sized steps very well.
Another option for traction on the step is "Wing Walk" tape or paint found in most aircraft repair facilities. The paint is black, with a type of sand or grit mixed throughout. The tape version comes in wide rolls with peel and stick adhesive on the bottom. It is aggressive even if it gets wet, but wouldn't be hard on bare feet. If you have any friends in the aviation industry; the cost would be very low.
Good Job!
Tom
Old 08-01-2014, 08:20 AM   #12
Good Job!
Tom
Easier to find might be non-slip bath tub strips, found almost anyplace, or non-slip deck strips at any boating supply house.
Old 08-01-2014, 08:21 AM   #13
Go to your nearest skate board shop they have the abrasive peel and stick tread material. Just shove the young-uns aside and hang your pants down low so you blend in. Oh and don't forget to put your hat on backwards.
Old 08-01-2014, 09:18 AM   #14
Trailer: Casita 17 ft DLX SD
I built a deck style step/ platform out of treated lumber. The deck boards on top are spaced so water can drains. The back and the two sides are raised a 1/2" higher than the front. We place an outdoor rubber door mat on top of the deck . The mat provides a non slip surface ,drains water and allows you to wipe the dirt off your shoes/ feet when entering the trailer, The platform is 20" x 30" which is rather large but it is extremely stable . When traveling we flip the platform over and store our BAL trailer jack / leveler inside the step
New Entry Door Window Casita Greg Modifications, Alterations and Updates 17 07-01-2013 10:26 AM
Will new Scamp Entry door Hinges fit on an 1981 13' Boler? idiotsniff Modifications, Alterations and Updates 29 01-19-2012 06:35 AM
New Entry Door Source Carl G Problem Solving | Owners Helping Owners 3 11-07-2010 10:39 AM
Camper/RV 2 Position Folding Step Stool-$35 Tom T. Classified Archives 0 05-15-2009 05:45 AM
New Entry to the Molded FG Trailer Market Charlie C General Chat 5 11-25-2005 07:55 AM
