New external hatch - Fiberglass RV
Old 06-13-2009, 11:58 AM   #1
Roddy D's Avatar
Trailer: Scamp 16 ft
I added a new external hatch to access little used space under the back table booth seat. Peterh's article and help was greatly appreciated. First I cut the opening for the hatch and epoxied supports around the opening.
I then ran a bead of marine grade silicone around the outside of the opening and attached the hatch using #10 1" stainless steal screws.
The final product installed and ready to use.
I don't have any of the fancy magnets Peterh used to keep his hatch open so I have a temp solution. I used a bar clamp attached to the belly band, shown in the last photo. Thanks for your help peterh....
Roddy D is offline   Reply With Quote
Old 06-13-2009, 09:33 PM   #2
Roy in TO's Avatar
Great idea Roddy, I'll be adding hatches to mine in the future and had never considered using supports. Thanks!
Old 06-16-2009, 06:28 PM   #3
james kent's Avatar
Trailer: Boler 1984
Roy.
If you hang the hatch with the hinge at the bottom, instead of on top, then it will hang down when opened and you don't have to hold it up while reaching inside.
I have put one into both rear storage benches.
Old 06-16-2009, 11:05 PM   #4
Roddy D's Avatar
I thought of putting the hinge on the bottom, but knowing myself, if I did not secure the hatch door properly there might not be a door left on the hatch.
Old 06-16-2009, 11:45 PM   #5
Herb Sutton's Avatar
Trailer: 2002 Casita 17 ft Spirit Deluxe
The other consideration with a bottom hinged door is that if it touches the ground, it will get crunched if someone steps into the trailer while it is open and causes the trailer to drop down.
Herb Sutton is offline   Reply With Quote
Old 06-17-2009, 09:25 AM   #6
Trailer: 19 ft Escape
Our outside access hatch is also also hinged at the bottom. It is right in line with the stabilizer jacks and so has to be locked when I'm putting down the jacks. Hinging at the top with a clip would be so much handier.
Ellen Smith is offline   Reply With Quote
Old 06-17-2009, 10:17 AM   #7
james kent's Avatar
Trailer: Boler 1984
I buzzed out and took a couple of quick pics of one of the the hatches on our Boler. Here's the hatch on the road side. I had to relocate the marker light further back and also drilled a few more holes in the outer bracket for the stainless fasteners.
Old 06-17-2009, 02:36 PM   #8
Roy in TO's Avatar
They are all good ideas, keep them coming so I will know exactly what I want to do before I do it.
I prefer my fore sight to have perfect vision and not wanting to be be affected by my hind sight. The latter lasts longer.
Old 06-17-2009, 02:58 PM   #9
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
Where is a good place to buy an insulated hatch door? Anyone have any links?
2017 Escape 5.0 TA
2009 Escape 19 (previous)
Old 06-28-2009, 06:53 PM   #10
Roddy D's Avatar
I have looked around for insulated hatches with no luck. You might be able to glue some type of insulation onto an uninsulated door!
Good luck.
Old 06-28-2009, 07:34 PM   #11
Trailer: 1970 Campster
Check out PeterH's mod last August where he added a hatch. Always with an eye for detail, Peter provides a great tutorial and shows how he insulated his hatch. He also added magnets to both the interior wall of the trailer and the inside of the hatch so that the door would stay open without any unsightly catches. Take a peek... you'll be glad you did!
Lisa H. is offline   Reply With Quote
Old 06-28-2009, 08:20 PM   #12
peterh's Avatar
The Adding a Hatch topic I did last year is here . . . And thanks for the compliment, too.
Old 07-29-2009, 11:12 PM   #13
Trailer: 94 Casita Spirit Deluxe
The kind of insulated hatch shown is post #7 is available from the Casita factory. It costs about $75.00 including shipping.
AZCharlie is offline   Reply With Quote
External Air Conditioner Project Parker Buckley Modifications, Alterations and Updates 14 09-29-2008 11:57 PM
Replacing external access hatches Tim Ryce Problem Solving | Owners Helping Owners 8 08-25-2008 01:18 PM
External Electrical AC Outlets Parker Buckley Problem Solving | Owners Helping Owners 3 05-06-2008 06:54 AM
Generator External Fuel Tank! Kent Modifications, Alterations and Updates 10 08-20-2006 07:27 AM
External Air Conditioner Project Parker Buckley Problem Solving | Owners Helping Owners 0 12-31-1969 07:00 PM
