08-11-2013, 10:10 AM
#21
Trailer: 2003 Scamp 16' SD
Utah
That's all pretty major surgery. Did you consider using pressure-treated plywood so it wouldn't ever dry-rot out again?
08-11-2013, 10:23 AM
#22
Trailer: Escape
New Mexico
Brilliant work, great pictures!
08-11-2013, 01:45 PM
#23
Trailer: Scamp Fifth Wheel
South Carolina
I am agog!
After all of this, a trip to Backus to aid Kent in a redesign is in order?
08-11-2013, 01:52 PM
#24
Trailer: 2007 Scamp 16 ft
Originally Posted by KamperBob
Thanks so much. I'm really glad you found a good home for your old Scamp. I hope you're enjoying that Escape 5.0 this season. I can't wait to visit you all again for a personal tour!
We are indeed enjoying the Escape. Tows like a dream and feels really spacious. Just finished wiring up the rear view camera that we used to have in the Scamp. The counter space is about equivalent but separated from the cooking area which takes some adjustment. And the double pedestal table doesn't leave much room for legs and feet underneath but other than those two things, it is all good! Dave is loving the extra height...he can even stand up under the a/c and not bump his head!
Let us know when you are headed this way and we'll prepare the culdesac for you!! :-)
Fran & Dave
08-12-2013, 02:18 PM
#25
Yes I did consider treated plywood. In my experience however treated woods (usually lumber but same idea I figure) usually come damp to wet. They have to dry out before anything else can soak in like paint for example. The edge of the floor needs to be fiberglassed to the shell. I was skeptical how well resin would bond to new treated plywood. That's another reason I choose real plywood over OSB. I figured clean thirty surfaces might better attach to thick fiberglass resin. OSB with thin chips and higher glue content (besides being needlessly heavier for camper floor use) affords shallower surface penetration of fiberglass resin. I may be wrong but that was my thinking for material choice on this project.
08-12-2013, 02:20 PM
#26
Thanks! Sometimes it's not easy to get good pix in confined places. A macro lens might help. Sometimes I get lucky. I'll take it.
08-12-2013, 02:23 PM
#27
Originally Posted by DixieViking
I am agog!
Thanks! I have offered design feedback to Backus in the past based on documented problems and member solutions. Such ideas didn't usually go over aw well as I hoped. I blame my diplomacy skills and gave up at some point.
08-12-2013, 03:17 PM
#28
Do you feel the ply is about the same weight as the OSB?
And no, I dont think ANYONE will have any luck changing Scamp....unless it's a liability issue. That's unfortunate.
Darral
08-12-2013, 07:11 PM
#29
Trailer: 1984 19' scamp
Kansas
I used treated, but I let it dry for a month before installing, and I also put POR-15 on the frame, and an adhesive on the frame to isolate the wood from the frame. Treated wood will rust metal.
08-13-2013, 05:27 AM
#30
Darral
OSB feels heavier. Higher glue content?
#31
Very good points!
08-20-2013, 02:32 PM
#32
Progress
I'm attaching a few progress pix. The first pic shows the new floor being fiberglassed to the shell around the edge. The second one shows the beefed up frame behind the axle (dinette area). The last pic shows a closer view of the prop arm (cantilever support behind wheel well).
09-03-2013, 03:16 PM
#33
Resuming progress
I got the Scamp put back together just enough for a family campout August 16-18th at Burt Lake State Park in Indian River, MI. At that time the dinette area was completed but not the main isle. Then a funny thing happened in norther lower-peninsula Michigan. Summer finally arrived! I ended up staying in Mackinaw City almost two weeks. The weather was gorgeous! Then I returned downstate to the Flint area for more family plans on Labor Day. Today I resumed the floor project but finishing the vinyl flooring.
The new floor theme just feels right. It visually binds together all the black trim elements against the white fiberglass cabinets. Like it was always meant to be this way. Better 22 years after birth than never right? LOL
With leftover scraps I'm not planning to vinyl cover the table top but I want to try a door panel insert and see how that looks. Maybe compare one lined up horizontal and vertical with one turned 45 degrees. It's time to defrost the freezer anyway so that looks like tomorrow's chore.
09-03-2013, 03:27 PM
#34
That looks GREAT!! You're gonna need new cushion covers now....maybe RED!
I suggest you do either an all black or all white door panel for the fridge...using the squares may make it hard to tell which side is up!!
Great job!
Fran
09-04-2013, 01:26 PM
#35
Great job!
Fran
Thanks!!
The door panel was black before. I didn't like that. Too dark. I'm actually on the fence about all white or the chessboard pattern. Open for opinions.
09-05-2013, 07:26 PM
#36
The all white makes things look more open ....but....the black & white is kind of cool. I suppose you could switch them out when you get tired of one or the other. But those cushion covers have got to go...any solid color would work. Maybe there's another Scamper out there who sews and would barter new covers for work on their trailer......
09-06-2013, 02:38 PM
#37
Gee thanks Fran. Those plaid covers I custom ordered for the wraparound dinette mod in 2007 now clash. Suddenly I hate them. LOL
09-07-2013, 04:18 PM
#38
You could just leave the lights off.....
09-07-2013, 04:23 PM
#39
NE Oklahoma
Or you could hang pictures of "Tool Man Taylor's" buddy every where
and hang plaid shirts in the closets.
09-10-2013, 12:24 PM
#40
Now that's a simple solution.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
New floor
Janice M |
48 |
01-23-2012 08:34 PM |
floor
stink |
5 |
09-03-2011 11:14 AM |
New floor!!!
Christi V. |
2 |
09-16-2006 10:31 AM |
MY NEW FLOOR
Dan Quinn |
6 |
05-04-2006 11:06 PM |
Floor
JIMZ |
3 |
01-15-2006 03:15 PM |
