New heater install - Fiberglass RV
Old 12-18-2012, 03:28 PM   #1
cpaharley2008's Avatar
New heater install
Today I finished installation of a new electric wall heater. I wanted something more permanent than the portable ones with plugs all over the floor and they are also very noisy. I found a very quiet Broan in wall 1000 watt heater with the option of reducing the wattage to 500 watts by disconnecting a wire during installation. I ordered it on Amazon and upon inspection I decided to add a switch to the unit to allow
either one heat element @ 500 watts or dual elements @ 1000 watts. I installed the unit at the end of the dinette to disperse the heat evenly throughout the trailer. I also installed a wall switch that has a red light when the unit is on. I tapped into an existing outlet for my power and also converted that outlet to a GFCI unit that will cut off power to the heater in the event of any electrical issues. The unit was around $80 on amazon and it is more quiet than the furnace, really impressive. It draws 4 amps on low and with the switch thrown jumps to 8 amps. Completely encased in metal, I fell it is a lot safer than the portable units.
Old 12-18-2012, 03:28 PM   #2
more pictures
Old 12-18-2012, 03:29 PM   #3
more install pictures
Old 12-18-2012, 03:30 PM   #4
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Great idea, especially if you generally camp with AC power.
Old 12-18-2012, 03:52 PM   #5
honda03842's Avatar
Name: Norm and Ginny
Jim.
Is this a fanless heater?
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
honda03842 is online now   Reply With Quote
Old 12-18-2012, 03:57 PM   #6
No, it has a small fan that is like your refer fan, very quiet but move the air.
Old 12-18-2012, 03:57 PM   #7
These units are made for bathrooms and closets.
Old 12-18-2012, 04:59 PM   #8
Thomas G.'s Avatar
Amazon.com: BROAN 170 Residential Electric Wall Heater,White: Home & Kitchen
Old 12-18-2012, 05:40 PM   #9
Huh, I paid $86?? wonder why it went up?
Old 12-18-2012, 05:53 PM   #10
Some places online still have it for $70-90 if you search a little bit.
Nice install. Thanks for the idea.
ericw is offline   Reply With Quote
Old 12-18-2012, 05:58 PM   #11
I just realized, my GFCI outlet is upside down?? Maybe in the spring I'll flip it.
Old 12-18-2012, 10:09 PM   #12
hotfishtacos's Avatar
Trailer: 2012 Escape 19' /2010 Honda Pilot 4WD TV
Escondido, California
There is no code for residential applications but for commercial OSHA & OSHPD applications the ground pin orientation must be up. I've seen this recently in a new hospital. For household use some molded cords have the ground pin down such as those on refrigerators. Most home outlets have the ground pin down. For trailer use you should be fine. I put an inverter in my trailer with a GFI outlet and put the ground pin up. This would make a great 20 page forum discussion!
"No Generators"
hotfishtacos is offline   Reply With Quote
Old 12-18-2012, 10:27 PM   #13
like do you put the toilet paper roll paper down or up!!
Old 12-19-2012, 07:26 AM   #14
Ice-breaker's Avatar
Looks good Jim. What is the depth from front of heater to back?
Ice-breaker is offline   Reply With Quote
Water heater install wayne s Modifications, Alterations and Updates 3 06-04-2006 06:01 PM
Wave 3 Heater install Gina D. Modifications, Alterations and Updates 14 06-04-2006 01:41 PM
Water heater install General Chat 0 12-31-1969 07:00 PM
» Trailer Showcase
Scamp
chefjj
Bean
Lew Harpelle
