New LED Tail lights - Scamp 13' - Fiberglass RV
Old 08-27-2013, 10:50 PM   #1
Trailer: 2002 Scamp 13' Std, Rav4 - 6 cyl
Finally replaced the original Bargman 92 series lights with LED Bargman 07 series. So much brighter! Wiring was pretty straight forward... ended up removing the table, passenger side bench to access the wire bundle to wire into the main Scamp wiring. Did not remove the driver's side bench b/c of the converter and an electrical outlet are mounted into the bench and did not want to unwire all that.... so did a nice headstand in the hatch to access the wiring on that side. The wires mate up under the rat fur about 8" up from the floor so made a little slit into the fur for access (it is hidden behind the benches so doesn't show). Sealed the light to the Scamp by stuffing 1/2" closed-cell backer rod (also known as caulk saver poly cord) into the channel around the edge of the light. Made a nice seal. Two of the screw holes matched up perfectly; had to drill 2 new holes. Sealed the old holes with PC-11 marine epoxy and caulked where the wires enter in from the outside. Purchased from eTrailer.
Since the table and bench are out.... replacing carpet with Allure flooring...will post when complete.
Back of light
Basic wiring:
Shannon Thompson is offline   Reply With Quote
Old 08-28-2013, 07:58 AM   #2
cpaharley2008's Avatar
nice work...
Jim
Never in doubt, often wrong
Old 08-28-2013, 05:53 PM   #3
It's GREAT to be SEEN!
Old 08-28-2013, 06:48 PM   #4
Radar1's Avatar
Name: Dave (and/or John)
Looks nice. No pictures of the headstand?
John-Dave and Marilyn
Sharpsburg, GA
04 Dodge Dakota V-8 and 17 Dodge Durango V-6
radar1-scamping.blogspot.com
light, lights, scamp, tail lights
LED Tail lights Scott H Modifications, Alterations and Updates 8 02-24-2011 09:45 PM
LED lights in Original light sockets - tail lights Cam A Modifications, Alterations and Updates 75 02-15-2009 11:54 PM
LED tail lights tarek Problem Solving | Owners Helping Owners 2 03-12-2006 01:20 AM
LED tail lights AndyW Modifications, Alterations and Updates 1 02-07-2006 07:38 PM
