New Project - 76' Scamp - Page 3 - Fiberglass RV
Old 08-02-2011, 09:01 AM   #29
Paul Chet's Avatar
Trailer: Vixen Motor Coach
David,
fantastic work sir! i absolutely love the furnace ... its sleek and low-profile. can you give us a tip as to what and where you got it?
cheers,
-Paul
Paul Chet is offline   Reply With Quote
Old 08-02-2011, 01:36 PM   #30
Trailer: 1977 Scamp 13 ft
Originally Posted by lhanna View Post
Just a couple of suggestions for names - "Scrambled" since it was half way there with the broken shell and all or "Humpty" ''cause it looks like it had a great fall! Kudos to you - can't believe I'm worried about a little water! LOL! You and the other people in this group amaze me at the stuff you can do. I'm terrified to put a fan in my trillium or reseal the windows! The little broken egg is looking fab!
Laurie
Thats funny! My wife and I were joking about that. I told her I was going to have to hire all the Kings Men to fix this one! Thank you for the complements!
4 years ago I knew nothing about FGRvs, you spend enough time around here and in the classic boat forums on other sites, and it wont be long before you are popping out windows and fixing them as a weekend project. As for water! that is nothing to small, Water is all of our worst fears I think! I cringe every time It rains!
David Morgan is offline   Reply With Quote
Old 08-02-2011, 01:44 PM   #31
Originally Posted by Paul Chet View Post
David,
cheers,
-Paul
The heater came with the trailer, It's seventies vintage. It's very similar to the Mr. Buddy flame grid heaters but significantly thinner. Sure puts out the heat though! It actually roars when it is going! it was previously mounted below and in front of the sink. It needed a bit of RnR to get it back to running order. It was pretty beat. I am hoping that over there it was be in a less traffic area.
I am a huge fan of the Wave 3 catalytic heaters. They are super safe and are even much smaller. A lot of the folks here use them. They put off less condensation than the flame grids do as well as being more efficient. When my pocket book affords I will probably upgrade to one of those. That was my master plan, because I was not certain I could resurrect that one. But now that it's fixed up I really like it!
Old 08-04-2011, 02:32 PM   #32
Interiors are finished! Yey!!!
Old 08-04-2011, 11:56 PM   #33
After much research, I have concluded that the axle is indeed aftermarket. And is specifically lower profile. The mounting brackets were slightly wider than the frame and there was some angle welded on to accommodate. The spring seams pretty good. And the arms have a slight up angle to them. But the camber is correct so if it's a flip job they did it correctly i guess. What a relief I was sure I was looking at a replacement.
1978 Scamp project $650.00 Jim_B Referrals: Molded Fiberglass Trailers 2 04-16-2011 11:12 AM
New Scamp owner & New member. 1992 Scamp 16 project LanM Hi, I am.... 16 01-31-2011 08:05 PM
82 Scamp 16' (Project) Kevin K Referrals: Molded Fiberglass Trailers 0 04-23-2010 02:14 PM
Scamp 16 Greywater Project Chris Krumm Problem Solving | Owners Helping Owners 5 06-25-2008 06:30 PM
'76 Scamp project Legacy Posts Problem Solving | Owners Helping Owners 29 03-11-2003 11:34 PM
