New rim options for scamp - Fiberglass RV
Old 08-27-2013, 06:31 PM   #1
Trailer: 13ft Scamp
Wisconsin
What are options for a better looking aet of wheels that will fit on the scamps?
Mcmarkrazz is offline   Reply With Quote
Old 08-27-2013, 07:17 PM   #2
Basically anything that will fit the bolt pattern, zero offset (typical for Scamps) and are the right size wheel.
I had mine made at Stockton wheel... don't ask me what it cost... it was outragous, but it was important to me Can't take it with you!!!!
Old 08-27-2013, 07:54 PM   #3
Trailer: 2014 Escape 21, Lil Joe
Check out Eastern Marine in De. They have a fairly good selection at reasonable prices. Your bolt pattern for a 13 Scamp will be 4X4 or 5X4.5 .
Eddie
http://www.easternmarine.com/mag-alu...trailer-wheels
Looks like they only have 13 in. aluminum wheels in 5x4.5 now.
Old 08-27-2013, 08:08 PM   #4
As they say.. by the way (BTW) are you looking to "add" hub caps? Pay attention if the wheels have "innies" or "outies" makes a really big difference when buy "moonies."
Old 08-27-2013, 09:09 PM   #5
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
What bolt pattern, what size tires? Steel? Aluminum?
I accidentally (luckily) found out Ultra made trailer wheels that matched my pickup wheels. Easy choice.
Old 08-27-2013, 09:19 PM   #6
IllAnnoy
Originally Posted by Mcmarkrazz View Post
What are options for a better looking set of wheels that will fit on the scamps?
We used trim rings and hubcaps on the stock wheels.
Old 08-27-2013, 10:06 PM   #7
Trailer: 13ft Scamp
Wisconsin
We have the wheel trim on the wheels..were did you get the hub caps they would be perfect.. Also the lug nuts are all rusty are they specail kinds or just standard? Even a replacement ss bolt would be great im guessing
Old 08-27-2013, 11:15 PM   #8
Borrego Dave's Avatar
pictures?
Old 08-28-2013, 07:25 AM   #9
Google the wheel size and bolt pattern you have or want and add "image" you will get about a gazillion choices to weed through. But read carefully, not all will fit your trailer.
For example: "13 inch 4x100 wheels" returned more images than I could count....
Old 08-28-2013, 09:54 AM   #10
IllAnnoy
Any real auto parts store will have studs to replace those bolts, which would then allow the use of chrome lugnuts.
OR... You could replace those bearing buddies with standard dust caps and fit an automotive hub cap or wheel cover.
If you like the bearing buddies then you could use a wheel cover and cut a hole in the center.
I put some old Ansen Sprints from a Pinto on my Lovebug, they need to be nearly zero offset though....click on the picture for a better look.
Old 08-28-2013, 08:06 PM   #11
Brian B-P's Avatar
Originally Posted by Bob Miller View Post
... For example: "13 inch 4x100 wheels" returned more images than I could count....
I expect so... that was a very common pattern for small cars (with high offset). If the trailer has 4-bolt hubs they're likely 4x4.00", zero or 1/2" offset.
Old 08-28-2013, 08:28 PM   #12
Jared J's Avatar
Kansas
As Brian pointed out, 4 on 4" is not 4 on 100.
Old 08-28-2013, 09:42 PM   #13
While 100mm doesn't exactly equal 4" it seems that they interchange both terms for the same wheels. But you can also google "13" 4 on 4" wheels" and get about the same images.
Old 08-28-2013, 10:20 PM   #14
Jared J's Avatar
Kansas
If you want to run wobble bolts and a hub centric spacer.
Ordering a 16' Scamp, what are the must have options? chuyler1 General Chat 32 03-26-2015 08:01 PM
Hello from TN. Questions on Scamp 13 options. SailorSteve Hi, I am.... 10 09-10-2012 11:40 PM
Help with Scamp 13 options oldchinahands Problem Solving | Owners Helping Owners 19 02-02-2012 08:12 AM
Question about Scamp Options Sharon G Problem Solving | Owners Helping Owners 36 09-18-2010 07:27 PM
76 scamp rim options jimtesla General Chat 2 08-28-2009 08:34 PM
