New Rims for 17' Boler - Fiberglass RV
Old 04-09-2015, 11:43 PM   #1
Hello,
I have a 1978 17' boler and am thinking of putting some nicer aluminum rims on it. Anyone have anything that has worked well for them? I am not sure of the bolt size either if anyone happens to know. I have seen a few with rims from Ford Rangers so that might be a way to go. Also, are you limited to the rim width with the limited selection of trailer tires out there? All input welcome.
Thanks
TR
TimR is offline   Reply With Quote
Old 04-10-2015, 06:14 AM   #2
Ian G.'s Avatar
Most trailers use a 5X4.5" bolt spacing and have a zero (0) offset. This eliminates most standard vehicle wheels. Checking the specifications 5 bolt Ford Ranger wheels apprear to be the correct bolt pattern but have a -15 mm offset, this may work depanding on how much clearence you have in the wheel wells. Rim width is usually limited to around 6" but again it depends on how much room you have in the wheel wells.
Old 04-10-2015, 07:27 AM   #3
FRED SMAILES's Avatar
Trailer: 13 ft Boler
Kootenay's of BC
Our car club put some really nice aluminum wheels on our club cargo trailer.
I've seen the same wheels on some campers although not our eggs.
A tire/wheel shop would be able to show you what would replace your current wheel just take them one of your present wheels.
Fred
FRED SMAILES is offline   Reply With Quote
Old 04-10-2015, 01:02 PM   #4
Thanks Ian and Fred. I was going to ask you too Ian, where did you buy the small trailer tires that you use to get your trailer low enough to get into your garage? Was it a Princess Auto tire.
Also at this point I think I will have enough clearance for almost anything with the crazy suspension this one has. A torsion axle mounted on leaf springs! I plan on getting Standen to put a new one on this year some time and I think they can adjust the ride height to whatever works. I need to get it about 6" lower so it will roll into my garage that I had built with extra high 8' doors.
Old 04-10-2015, 07:31 PM   #5
Ian G.'s Avatar
Hi Tim
Yes these are the Princess Auto, they do go on sale. They bolt directly on a non-brake axle, with brakes they fit on backwards (valve stem pointing in)
4.80-8 Trailer Tire Assembly | Princess Auto
Old 04-10-2015, 07:44 PM   #6
Those should help a bit getting it into my garage. LOL might have to take off the vents though! Guess I should make an appointment at Standen's.
Old 04-10-2015, 08:34 PM   #7
Wheels? There's so many combinations used on travel trailers I wouldn't even hazard a guess what yours is. I know the wheels I run on my Scamp isn't what came from the factory because I did an axle change. Don't assume! Years ago, I put a 5 stud axle template out in the Document Center. Maybe you can see exactly what you need (before you order!). Hope it helps: Fiberglass RV - Document Center - 5-StudCircleTemplate
Old 04-10-2015, 09:33 PM   #8
Thanks Donna. Good point with all the other mods on this thing. I was going to measure the studs on mine first and maybe even take the spare before buying new rims.
Old 04-10-2015, 09:42 PM   #9
Trailer: Bigfoot B-17 CB
I have purchased 2 sets of tires and wheels from recstuff.com. They have lots of trailer wheels and some pretty good information on bolt patterns on their web site . It might be easier for you to buy in Canada but the web site has lots of basic info in wheels and tires.
Jack L is online now   Reply With Quote
Old 04-10-2015, 10:02 PM   #10
Excellent website Jack. Might have to have it shipped to somewhere in the lower 49 and make a trek down. Donna, you should see the template for measuring bolt patterns! http://recstuff.com/themes/default/D...leTemplate.pdf Not as simple as the one you sent but certainly informative.
boler
New tires/rims on my 72 boler Lisey Towing, Hitching, Axles and Running Gear 19 01-25-2013 08:36 AM
2 New 15" trailer tires and rims $200 Denis Wilkinson Classified Archives 5 09-18-2010 08:00 PM
3 Rims & Tires off my Boler ! John J. M Classified Archives 0 09-07-2009 05:37 PM
Boler Rims & Tires Jayson Wall Towing, Hitching, Axles and Running Gear 3 07-24-2008 06:53 PM
New Rims Lainey Problem Solving | Owners Helping Owners 8 08-16-2007 01:40 PM
