New Scamp 13D gets the McGiver treatment - Page 4 - Fiberglass RV
Old 08-05-2018, 06:11 PM   #43
Massachusetts
Centrifugal Fans
Mark - good find. I have a pair on hand for another application..., They're great for a concentrated stream of air.. For cooling the generator compartment a wide wash of air is important so went with a 140mm fan type.
ACHINBAC is offline   Reply With Quote
Old 08-05-2018, 06:58 PM   #44
Massachusetts
DCDC Tow Vehicle Charger for Trailer Bank with Solar MPPT Input
In response to a PM request am posting pics of our charger (could not see how to attach pics on a PM??) The unit is very compact @ 7" x 4.5" x 1.5", has nice marine grade tinned heavy gauge leads, fast bulk charging @ up to 40 amps, & a dedicated MPPT Input for solar. It is made by REDARC, model# BCDC1240D. It will be mounted in the battery/ propane box to be built for the front of the Scamp. As a side note, perhaps someone could chime in here - I do not trust the task of charging our battery bank with the the Factory Converter that came with the Scamp yet - it seems to hang always at 13.7 volts (even with it's internal "charge wizard") I believe the model is a PD9000 something, 2017, am about to call the company though any input is appreciated!
Old 01-13-2019, 11:14 AM   #45
Massachusetts
Rustproofing
Brought the Scamp to Uncle Bob's Monster Garage for additional rustproofing.... Recoated the inside of the frame rails again w/ 3 cans of Quicksilver Corrosion Guard, a marine rustproofer - drys to a waxy film fairly thick. I used a 9' nylon tube w/ a 5 hole brass tip that was rotated as it was drawn out of each rail. We cooked it for a couple days till it gelled.
Old 01-13-2019, 02:44 PM   #46
Massachusetts
Storage
Scavenged some storage space in front of the curbside wheel well - I sized the opening to match a stock Scamp door which I'll order from their factory along w/stock hardware. Other closet light switch pics are regarding a recent PM..... They are lighted cause my Ol' memory is starting to fail now HaHa!
Old 01-13-2019, 04:00 PM   #47
Massachusetts
Solar Panel Cover
Solar panel cover is complete short of a couple coats of paint. It protects the panel while stored on the rear carrier. Made from 1/4" ply overlayed w/fiberglass. The aluminum angle perimeter is rabbetted flush to the finished surface.
Old 01-13-2019, 04:13 PM   #48
Massachusetts
Solar Panel Stand
The cover doubles as the panel's stand. It also serves to identify the correct angle for the panel: If it shadows the panel the angle is too high for optimal performance & the panel is then dropped down to where the sun shines a bit on the inside of the cover.....
Old 01-13-2019, 04:28 PM   #49
Massachusetts
Anchor
I found this online @ American Earth Anchors (we use smaller versions to spin in with my portable DeWalt for our overhead tarp guy lines) it anchors to the panel with a steel line to keep it from getting knocked by the wind + keeps it from walking away under someone else's power.....
Old 01-13-2019, 04:37 PM   #50
Massachusetts
Panel Cables
Made up a pair of 10' 8 gauge (I know, over kill) extensions for the panel w/ a waterproof Anderson plug on the end to tie into the charging outlet on the Scamp....
Old 01-13-2019, 04:43 PM   #51
Massachusetts
Hitch Jack
Another use for that DeWalt drill - welded on a cut off 1/2" stainless bolt to the crank on the front Jack - same head size as our rear Bal jacks - makes setting up & breaking down eazy peazy.
Old 01-13-2019, 06:52 PM   #52
Trailer: 2016 -13' Scamp
Massachusetts
I'd love to see a wide angle shot of the overall door installation.
herons is offline   Reply With Quote
Old 01-14-2019, 11:04 AM   #53
Massachusetts
Dave,
Great work, "You are the Man". Love the idea of the third stop light. Will definitely look into that. Thanks for all your ideas, especially getting under the rat fur.
Jack
Lockman is offline   Reply With Quote
Old 01-14-2019, 05:21 PM   #54
Massachusetts
Peg - I can't get a wider angle shot for you in this tiny trailer, but will give you more info if you choose to cut.... My cutout is 10 x 7⅛ w - it was chosen for the factory available door in the pic (11 x 8) - it is narrower than the stock door above because of the GFCI I installed near it that also powers an outside outlet to the left of the door. I initially bored a 3" inspection hole before I made the cut - plenty of room in there was found & nothing in the way of that sized door.
Old 01-14-2019, 05:44 PM   #55
Massachusetts
Peg - also, I believe you have a fiberglass cabinet - if you use a jigsaw for the cutout pick up a reverse tooth angle blade (it cuts on the downstroke & will be less likely to shatter the gelcoat) & tape off the face. Also your structure will still be strong enough to support the roof after - Though I myself would glue on some stringers on the backside of the cuts cause just takes a few minutes. In the pic is a "Bell" cover for the outside outlet - well made & nice look, also a marine grade lockable w/ a twist 12v outlet made by Marinco.....
Old 01-17-2019, 09:12 PM   #56
Massachusetts
New toy to hack came in the mail today; a 5000 btu AC unit that will become a portable ducted unit for the Scamp after a few tweaks.... 16" x 16" x 12" & only 40 lbs. Very quiet, though will foam it's insides & will quiet it down even more. Tested it on the Honda 2000 gen & @ 4 ˝ amps in ecomode the Gen was no more than ⅓ throttle - when the compressor kicked in the Gen barely felt it - pretty good capacitor on the AC unit.....
Treatment of slightly oxidized fiberglass bobblangley Care and Feeding of Molded Fiberglass Trailers 16 07-31-2018 01:13 PM
Window Treatment Cissy Modifications, Alterations and Updates 11 06-11-2013 07:09 AM
Window treatment ideas wanted.... cpaharley2008 Care and Feeding of Molded Fiberglass Trailers 17 08-29-2011 07:29 PM
scamp gets new axle jeff y Modifications, Alterations and Updates 0 07-14-2008 08:17 PM
Blackwater treatment Kevin F Care and Feeding of Molded Fiberglass Trailers 5 07-11-2006 08:39 AM
