New Silverware Drawer with Ventilation - Fiberglass RV
Old 07-06-2008, 12:03 AM   #1
peterh's Avatar
I finally replaced my "prototype" silverware drawer with a new, permanent one. This idea started when Lynne and I bought a sivlerware drawer organizer that fit perfectly right-to-left, but was longer front-to-back than our Scamp utensil drawer. To fit the darn thing in I had to take the back of the drawer off and screw the mesh organizer to the side rails of the original drawer. While I was at it, I removed the bottom of the drawer, which wasn't needed anymore. Problem solved . . . the mesh organizer was rigid enough that the drawer no longer needed its back or bottom, and the new drawer could work as a drying rack for damp utensils, too.
Now I'm replacing the door and drawer fronts in the kitchenette with new ones, I decided it was time to update the slightly klunky prototype with a final version.
This is the drawer without the front. It's made from 1/4" plywood, with the ply doubled up under the aluminum "U" brackets that serve as the drawer runners.
A scrap piece of 3/8 plywood slides in the aluminum "U" channel. When the drawer is closed, the ply panel keeps stuff that's in the drawer from bouncing out. (This is how Scamp did the original drawer, and I liked the idea.)
The sides of the drawer extend beyond the wire mesh organizer by a couple inches so these screws have a place to go. When screwed all the way in they hit the fiberglass cabinet front and serve as drawer stops so the drawer doesn't slide all the way out. (Also a Scamp original standard.)
This is the ply panel that supports the drawer. The two thin strips of wood on top of the support create a space between the thing the support is screwed into (which for us is the bottom of our gas stove) and the top of the drawer so the aluminum "U" slides have room to move.
Here's the drawer without it's front hanging from the plywood. Note the markings on the top edge of the drawer opening in the fiberglass cabinet and the center of the plywood support.
The drawer and front, open and filled with utensils and closed.
Changing from particle board construction to plywood is not only stonger, it's lighter, too. The 3/8 ply support panel is about half the weight of the original OSB support Scamp uses, ditto on the plywood sides and back.
Old 07-06-2008, 08:09 PM   #2
Trailer: 1986 19 ft Bigfoot
Another great job and innovative solution.
FredericL is offline   Reply With Quote
Old 07-07-2008, 08:19 AM   #3
Steve Hilby's Avatar
Trailer: Compact Jr
How are you keeping it from sliding open during transit?
Wait, hold that question--you must be using more of your powerful little magnets, right?
Steve Hilby is offline   Reply With Quote
Old 07-07-2008, 11:30 AM   #4
Sandra Lair's Avatar
Trailer: 1982 Scamp 13 ft
Verrrrrry nice! I love it!
Sandra
Sandra Lair is offline   Reply With Quote
Old 07-07-2008, 10:55 PM   #5
peterh's Avatar
Haven't decided on anything yet. I tried the magnetic catch, but found the offset created by magnet and strike set the drawer forward of the cabinet just enough that it looked like it wasn't closed all the way. Funny thing is the cabinet doors use the same system, but look just fine.
I'll probably still do the magnetic catch, but this time I think I may epoxy a higher power magnet inside the cabinet (higher power because the fiberglass will separate magnet and metal, so I'll need the stronger pull) and make a recessed area inside the bottom of the drawer front a metal plate or second magnet.
Old 07-08-2008, 07:44 AM   #6
Scott S.'s Avatar
Trailer: 1975 Surfside TM14 (front kitchen)
Manitoba
Send a message via MSN to Scott S. Send a message via Yahoo to Scott S.
I think the folks at Scamp should have you guys on their product development team.
very inventive ideas.
Scott S. is offline   Reply With Quote
Old 07-08-2008, 11:05 AM   #7
DaveK's Avatar
Trailer: 2011 Escape 5.0
I just finished a drawer under my stove, and I'm contemplating putting one of these on it for travelling safety.
http://www.childsafetystore.com/.sc/ms/dd/...0by%20Safety1st
It's a leftover from a recent grandchild-proofing project. Easy to use day to day, very solid, and when you don't need to latch the drawer, you can fold the catch down out of the way.
Dave
DaveK is offline   Reply With Quote
Old 07-08-2008, 05:34 PM   #8
peterh's Avatar
Ohhh, Dave, that's a great idea! My youngest just graduated from high school and none of my kids have kids yet, so I'd completely forgotten about Child Safety latches! Thanks!
I think Reace at Escape Trailers probably keeps tabs on the ideas posted here, but many of the changes aren't practical for comparatively budget-conscious fiberglass trailer buyers. Certainly his 5th wheel takes ideas and concepts from Mike & Nancy's remodeled Scamp 5er (as did I), but to sell their trailers manufacturers have to cut corners on everything from the materials they use to offering floorplans that will appeal to the widest range of buyers.
My remodeling work would be very expensive to reproduce and is really kinda specific to the needs of a trailer for two adults and the occasional one or two grandkids.
One example of cutting corners in these trailers is the heavy use of heavy MDF particle board. MDF's advantage is cost; not only is it 1/3 to 1/2 the price of plywood, it's also faster and easier to cut, so manufacturers can save a bundle on the cost of making the trailer over using plywood. MDF's downside is it is no where near as strong and weighs 70-80% more than the same thickness of plywood. Trailer manufacturers know they could make stronger, lighter trailers if they replaced MDF particle board with plywood, but their production costs would rise as a result, too, making the trailers more expensive to buy and harder for their target consumers to afford.
The good news is that someone like me, who is willing to spend hours and hours of time re-doing the inside of an almost-new (2005) trailer, can turn a plain Scamp trailer into a deluxe-feeling rig that weighs the same or less than the original.
Old 04-01-2013, 06:32 PM   #9
Radar1's Avatar
Name: Dave (and/or John)
Looks nice. I have my utensil drawer out and want to replace the MDF. This is a great idea. Did you make the support piece wider and cut the fiberglass at all, or just keep the same width?
John-Dave and Marilyn
Sharpsburg, GA
04 Dodge Dakota V-8 and 17 Dodge Durango V-6
radar1-scamping.blogspot.com
Old 04-01-2013, 06:59 PM   #10
D Davis's Avatar
Trailer: u-haul ct13
Virginia
Love, love, love it! great job!
D Davis is offline   Reply With Quote
Old 04-01-2013, 08:05 PM   #11
Trailer: '77 Scamp
Thanks for sharing the detailed plans for the rest of us. I don't have a drawer in my '77 and have been laboring over ideas for attaching the rails without putting more holes in the exterior wall. This certainly is a good solution. Great job!
Otters is offline   Reply With Quote
Old 04-10-2013, 07:23 PM   #12
Radar1's Avatar
Great idea PeterH!
Thanks to PeterH I got the inspiration to rebuild my silverware drawer. The material in the original drawer would swell up and bind anytime we got it wet, and the bottom was starting to come off too.
I used the same idea as peter but used 1x4 lumber to make mine, and I expanded the opening a little to allow the drawer to be slightly wider and deeper.
Haven't decide on the final drawer front yet, this is just simple pine with clear gloss, but that part will be easy to replace if I decide on a different style or color.
First 4 pictures show the ventilated insert and how it matches up to the original drawer size.
Sharpsburg, GA
Old 04-10-2013, 07:27 PM   #13
Radar1's Avatar
This group of photos shows different stages of construction, and shows that the slides on the new drawer are farther apart than the old slide distance. I cut a new piece of 1/2" plywood at the correct width and mounted that under the stove like the original piece.
Sharpsburg, GA
Old 04-10-2013, 07:30 PM   #14
Radar1's Avatar
These last photos show the completed drawer ready to use for this weekend's camping trip to Buck Hall recreation area in SC. Eventually I plan to replace all the original doors in the camper so they match.
Sharpsburg, GA
Old 04-10-2013, 07:40 PM   #15
carlkeigley's Avatar
NE Oklahoma
That's a great mod.
Old 04-10-2013, 07:49 PM   #16
Trailer: '77 Scamp
Very nice looking drawer. I like the looks of the pine. I'm sure you and Marilyn will really appreciate it on your trip.
I have a couple of questions. You mentioned 1/2" ply under the stove. How is it attached? Are the rails attached to that plywood? How are the rails attached. I'm planning to do the same, and just don't know how I should attach the wood that the rails will attach too, since I don't want to go through fiberglass exterior wall.
Old 04-10-2013, 08:05 PM   #17
Radar1's Avatar
Peter's first post has some great shots of the plywood with the spacers attached. Scamp drills directly through the bottom of the stove and into that piece of plywood and attaches it with about 5 screws. You need about 3 hands when you do that though, as you want the drawer attached to the plywood so you know exactly where to position it so the front of the drawer is flush once you tighten it down.
That piece of plywood is what the two "C" channels attached to the drawer slide on. Pretty simple and it works out pretty good since it keeps anything in the drawers from bouncing up while bouncing down the road.
Sharpsburg, GA
Old 04-10-2013, 08:15 PM   #18
Trailer: '77 Scamp
THANK YOU JOHN! It sure adds a lot of usable space, which I can use.
Add A Drawer Steve L. Modifications, Alterations and Updates 7 05-28-2009 10:48 AM
Battery Enclosure Ventilation Mike Kratz Problem Solving | Owners Helping Owners 14 08-27-2007 01:17 PM
Utensil/silverware drawer DianeP Modifications, Alterations and Updates 10 04-21-2006 09:09 PM
ventilation Legacy Posts General Chat 3 08-15-2003 03:14 PM
13' Scamp Ventilation Fan Legacy Posts Modifications, Alterations and Updates 5 11-22-2002 05:01 PM
