New solar install.... - Page 12 - Fiberglass RV
Old 02-02-2012, 06:58 AM   #155
honda03842's Avatar
Name: Norm and Ginny
Wiring thoughts
We never leave our tow vehicle connected to the trailer when parked, even if we're not physically disconnecting from the ball. We do not want to charge or discharge the tow vehicle's battery from the trailer unintentionally.
We do have a dash board switch in the tow vehice that allows us to disconnect the tow vehicle's battery from the trailer. For us connecting the tow vehicle's battery to the trailer's battery is an intentional act.
The wires from the Converter to the battery are pretty substantial because they have to handle high currents, really much higher currents that the panels produce..
In retrospect it would have been better to wire the solar panel to the input of our Inverter. The wiring from the battery to our 1200 watt Inverter has to be capable of 100 amps.
In general the voltage drop caused by solar panel current is relatively small because the currents are relatively low. As well the distance from the solar controller to the Convertor are short. The distance from the Converter and Inverter to the battery even shorter.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 02-02-2012, 06:16 PM   #156
Kenny Strong's Avatar
Trailer: Bigfoot 13'
Utah
adjustable feet
Originally Posted by Don Dunsmore View Post
Kenny....you might consider these adjustable feet from AM Solar. They are made for curved RV roofs. They also have the tape needed to hold down panels, etc.
35mm Rocker Foot Mount Set | for Solar Panels
Don
I went to the site, and bought the feet, and the angel support brackets.
thanks ,,,, later, Kenny
Kenny Strong is offline   Reply With Quote
Old 02-02-2012, 06:25 PM   #157
Trailer: 17.5 Bigfoot
Originally Posted by Kenny Strong View Post
Don
Glad I could help Kenny. I'll be using them as well when I do my Solar install. You may have to adapt those mounts to your Solar Panel. They clip nicely onto the panels AM supplies. Here's some install info.
Mounts | RV Solar Education
http://www.amsolar.com/shop/images/I...ies_Panels.pdf
Don Dunsmore is offline   Reply With Quote
Old 02-03-2012, 03:41 PM   #158
Utah
Don
The 35 mm ( 25.4 mm to an inch) mount set, ( made for their OM series Panels) came from Am Solar, and they fit the 1 and 1/2 inch aluminum frame that my panel has, perfectly. The mounting feet have the 3m VHB adhesive pre installed. The method they have developed, to change the angle will be so simple to use. Thanks again. I bought a wire coupler, from an Amazon source; now I can have a wire separation on top of the EGG and be able to disconnect the panel if need be, without pulling the wire out of the trailer roof access port,( that Norm found, from a boating source ). I am going to buy one like Norm's.
Later Kenny
Old 02-03-2012, 03:46 PM   #159
Utah
I also bought a 12 volt electric twin blanket thru Amazon. read the reviews some are not considered so good.
Later Kenny
Old 02-03-2012, 08:33 PM   #160
Trailer: TrailsWest CAMPSTER 1970
SNOW LOAD question.
I store my '70 Campster outside all year long.
I am planning to install a 50W Ramsond panel on my roof...BUT I can't find any information of the dangers of SNOW LOAD. Snow gets darn heavy when soaked with rain water...
Got info ?
Doc the boonDOCer @ campfrugal.
campfrugal is offline   Reply With Quote
Old 02-03-2012, 09:02 PM   #161
Larry,C's Avatar
Trailer: Casita 17 LD
Kentucky
solar panel and snow load
I'm not sure how to help you. First, I think you have made a good choice with the Ramsond panel. They make a good product. As far as the snow load I don't think the panel will accumulate any more snow than your roof would. you may want to put some angle on the panel where you can maximize solar benefit and minimize snow build up.
Larry,C is offline   Reply With Quote
Old 02-04-2012, 07:07 AM   #162
honda03842's Avatar
Taped Panels and snow load
The taped down panels should be able to withstand any broad or even loads like snow. The maximum deflection is probably less than a 1/16th of an inch before the panel would be against the roof. Since it's flexible snow should not be an issue.
The bigger concern is point loads. Recently we parked under a Live Oak and were pinged by acorns with no damage.
Loading should also put little stress on the mounting tape considering the nature of the tape.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 02-04-2012, 09:16 AM   #163
Utah
Have you been reading the forum, about the fellow fixing his egg, where the top caved in because of snow load. the pictures are great. he is doing a great job fixing it. I use a big broom to push the snow off my egg.
Later Kenny
Old 02-04-2012, 01:04 PM   #164
honda03842's Avatar
Thru Hull Fitting
I received a PM on this topic and decided to republish the info on the fitting for the Solar Panel's wiring.
Glomex - The best in Marine Antennas - GAMMA PRODOTTI
I painted it white before installation and filled it with Lexel before installation to keep water out.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 02-04-2012, 01:08 PM   #165
cpaharley2008's Avatar
It's all in a foreign language, the link.
Old 02-04-2012, 02:35 PM   #166
honda03842's Avatar
Translator
In the upper right hand corner there are a bunch of flags. Click on the english flag for a translation or click on the following.
again RA140
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Old 02-04-2012, 04:11 PM   #167
Maximum load
Originally Posted by campfrugal View Post
SNOW LOAD question.
Got info ?
Maximum load from Ramsond is 200kg/m2 which is 0.02kg/cm2 which is 0.28PSI which is about 2' of 33% wet snow. I hope my math is correct.
Ramsond SunRay Pure Sine Wave Inverters
George.
Old 02-08-2012, 09:05 PM   #168
80W panel sale for $99
I just got notification for 80W solar panels sale for $99.
Solar Cell, Solar Panel, Solar PV, Solar Products, Charge Controllers, Solar Trackers
http://www.solarcynergy.com/images/P...V-SC100J12.pdf
George.
solar
Window AC install slbran Modifications, Alterations and Updates 12 06-27-2011 06:25 PM
A new way to install AC Jacob S. Modifications, Alterations and Updates 12 02-21-2010 07:51 AM
What to install? Gwenn Problem Solving | Owners Helping Owners 4 08-23-2007 11:37 AM
A/C install Legacy Posts Modifications, Alterations and Updates 8 02-04-2006 05:27 AM
A/C install Legacy Posts Care and Feeding of Molded Fiberglass Trailers 8 12-15-2002 07:49 PM
