02-10-2012, 12:39 AM
#181
Originally Posted by Thomas G.
Please continue to share good deals like that one. I was just about ready to buy when it faded away.
Will do. From all solar installations I still prefer Norm's flexible panel installation. But, I have my rigid panels and I am still happy with them. Our US wide trip, still in planning stage, this year will be a good test.
George.
02-23-2012, 06:48 PM
#182
02-23-2012, 07:56 PM
#183
02-24-2012, 05:54 AM
#184
This flash sale only lasted 2 hours. If you are in the market, sign up for alerts from Solar Blvd (see left column on home page).
06-16-2012, 10:29 AM
#185
Name: Norm and Ginny
10,000 miles and counting
Flexible panel report.
Since there seems to be continuing interest in our solar solution.
The two 40 watt panels seem to do the job for us, supplying adequate power for LED lamps, water pump, TV, Sat dish, occasional electric blanket and charging of computers and the like.
We've had our 80 watts of Solar panels for about 10,000 miles of travel, been buried in two snow storms and seen months of rain. They are still solidly attached to our roof and have not had a single issue, either minor or major.
Many of the concerns expressed in this long post, all reasonable concerns, have turned out not to be problems:
The panels stuck to the Red Max Pro 3; moisture under the panels, if any, has not been a problem; the panels have not increased the inside temperature to any noticeable degree; there's no visible heat damage to the gel coat; neither high outside temperatures or snow have done any damage; there has been no signs of panel lifting; though we've had no significant branches fall on the panel, we've had numerous hits by acorns and the like without a scratch; the thru hull fitting has never leaked and we've seen many inches of rain in the NorthWest.
The only negative is the panels cost, higher than the more traditional variety.
Another less obvious advantage is no fear of theft, only people who read this site are even aware that we have solar panels.
We choose not to have tiltable solar panels, not wanting the bother of having to tilt the panels and not wanting to impact the smooth surface of the trailer. As well with our travel philosophy of minimizing loose items we decided against internally stored panels.
On this long 11 month, 14,000 mile trip we like the fact that the panels are charging the battery as we drive and not stored in the trailer or our 2004 Honda CRV.
We are about to install a similar installation on our son's 1977 Scamp 13. He has chosen a single 70 watt panel that should fit nicely on the Scamp.
Safe Travels
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
06-16-2012, 11:42 AM
#186
Trailer: U-Haul ct-13
Quebec
Thanks for the report. Looking forward to upgrade are uhaul with solar soon.
Fred
06-16-2012, 01:48 PM
#187
70 Watt Solar
Coincidence.
My son received his 70 watt Solar Panel today. Early next week I plan to install it.
The picture shows the trailer under a plastic canopy. We put up the canopy so we could work in this rainy climate and to keep pine needle off the trailer as we gave it multiple coats of Red Max Pro 3.
His trailer is nearly ancient, a 1977 Scamp 13, soon to be modernized with thin Solar Panels.
As well he bought a rather interesting solar controller that has an LCD display. The display shows voltage, load current, charging amp hours, discharging amp hours. It also allows the setting of a number of levels like maximum charged battery voltage. He bought it on Ebay, a Solar 30.
I can't wait to give the controller a spin.
The blue painter's tape is of course temporary, just to check that it fits and to prevent it from blowing away.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
06-16-2012, 03:59 PM
#188
any pictures of the display?
06-16-2012, 05:48 PM
#189
Solar Controller
Jim,
If you double click on the thumbnail picture you'll be able to read the various screens. If you study them for a couple of minutes you'll be able to understand the ability of the controller.
The first screen simply shows battery voltage, charging and discharging state and battery level. From this screen the load can be enabled or disabled.
The second screen shows battery temperature, really ambient. A temperature sensor is provided and the controller compensates for temperature. Not too useful because the batteries are outside and the sensors are inside the trailer though I suppose the sensor might be capable of being remoted.
The third screen shows the amount of current being produced by the solar panel.
The fourth panel shows the current being supplied to the load from the battery. This requires wiring the loads appropriately.
The fifth screen shows ampere hours from the solar panel to the battery. This screen is resettable to zero.
The sixth screen shows ampere hours from the battery to the load.
The seventh screen shows the minimum voltage the battery is allowed to discharge before the load is electronically disconnected from the battery . Certainly 10.6 is too low. This number is adjustable by the user.
The eighth screen shows the recovery voltage, the minimum battery voltage where the load will be electronically connected to the battery. This voltage level is adjustable by the operator.
The ninth screen indicates the voltage at which the solar panel will electronically be disconnected from the battery, the fully charged battery level. This level is adjustable by the operator.
The tenth screen is rather unusual. It allows you to control for the period of time that the controller supplies battery current to the load. It can be set for continuous by selecting 24 hours, probably the normal mode for most. However it can be set up to provide power for any number of hours once darkness arrives from 1 to 23 hours. There is also a third mode where power is supplied after dark and shut off once daylight arrives.
The controller has short circuit and overload protection on the load side. It also detects the presence of the panels.
Hope that helps. All info is from tne data sheet because I won't have it connected until next week.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
06-16-2012, 05:53 PM
#190
thanks, Norm
06-16-2012, 07:24 PM
#191
Norm,
Thank you for the update. I would definitely use flexible panels like yours if I would be installing again.
Regarding the controller, is it MPPT type? I assumed that measured load is for devices attached to controllers just like in Morningstar controller. If you have devices directly attached to the battery the controller will not be able to distinguish between charge and load currents. In my case all devices are connected via shunt to the battery so I can measure battery load by measuring voltage on the shunt.
George.
06-16-2012, 09:02 PM
#192
Trailer: Boler 13 ft
Thank you very much for reporting on your install. We are definitely going to do something similar on our trailer.
François
06-17-2012, 10:05 AM
#193
Solar 30
George,
What I most like about this controller is that it can directly display current to and from the battery. I'm sure there are other controllers that do this but I haven't seen one.
It seems most people want to know how much 12 volt power their trailer uses and this controller measures it instantaneously. As well it acccumulates and displays ampere hours drawn from the battery by the load and ampere hours supplied to the battery by the solar panels.
"How much 12 volt power used?" is a most commonly asked question and the answers are rarely definitive. This controller easily provides that opportunity to know power usage. This specific controller is limited to 36 amps current draw from the battery before an overload is reported.
On my son's trailer I intend to run the entire 12 volt load thru the controller.
I suspect the controller uses field effect transistors (FET) to control flow from and to the battery, possibly with a current sensing lead or simply just measuring the drop across the FET
As to MPPT, the controller states it operates as an Intelligent Pulse Width Modulation Controller.
Measuring the voltage drop across a shunt is a way to measure power draw, what's neat about this controller is it accumulates usage and displays it, a Solar Controller I have not seen before.
(Sorry I'm so repetitive but I suspect most forum members may not understand what this controller offers.)
I'll follow up wwith another report once I hook up this controller this week.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
06-17-2012, 11:31 AM
#194
Trailer: 93 "Lil" Bigfoot 13.5'
Utah
pics of AM Solar mounting brackets
06-17-2012, 12:26 PM
#195
Trailer: 2008 Taylor Coach 17 ft
So Norm what is the name, model number of your controller?
Cheers John
06-17-2012, 12:37 PM
#196
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
06-18-2012, 10:42 AM
#197
Trailer: Bigfoot 2500 truck camper
Thanks for the detailed report Norm. I purchased a controller very similar to this one. Mine is a Steca PR3030 also available on Ebay for a bit more. The Steca is made in germany rather than china. The big advantage is of course the system monitor built into these controllers. System monitors are often expensive options on many controllers. I cannot imagine trying to use my solar system without actually knowing what is happening. I also do not think that MPPT controllers are cost effective on small systems. Better to spend your money on a larger panel or battery bank.
06-18-2012, 03:48 PM
#198
Trailer: 1980 Burro
Since there seems to be continuing interest in our solar solution...
Safe Travels
Norm,
I would appreciate any insight you could give us on how well the panels charge in low light conditions. For example if parked in the full shade do they produce usable power? Same if there is part shade, like the shadow of a large tree branch across the middle of the panel. How about overcast weather?
Thanks,
Andy
06-18-2012, 05:06 PM
#199
Andy B,
This is not a real test but it provides a data point.
We're just north of Seattle, and have been parked in our son's drive way for 3-4 weeks. We are surrounded by trees and generally mostly in the shade (LOL), is there any thing else since's it's overcast 90% of the time. I can honestly say we have had less than 24 hours of sunny skies since we've been here.
I just measured our battery and it's at 13.02 volts and the convertor is and has been off.
This all must be qualified. The only thing running on 12 volts is the lights.
For us the only significant load is the water pump when we're boondocking other than that we draw little 12 volt power because the other items, computers, TV, sat dish, and lights draw very little power.
Of course I realize, our use of the panels and trailer is different from most on this site. On this trip we're driving about 100 out of 330 days we get 4-5 hours of non-shaded sunlight every 3 or 4 days, along with parked charging it seems to be enough.
After I install the solar controller that shows energy accumulation and energy use I'll have a better idea on how effective the panels are. So far I am pleased with the panels.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
06-19-2012, 03:02 PM
#200
Trailer: 1980 Burro
Andy B,
Thanks for the detailed reply Norm. It sounds like the panels are producing some power under adverse conditions since you have been parked in the shade for weeks and still read 13 volts. I look forward to when you install the controller and can determine the accumulation and energy use.
The reason I was asking is because I almost always camp in the shade so low light performance is very important.
Thanks,
Andy
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Window AC install
slbran |
12 |
06-27-2011 06:25 PM |
A new way to install AC
Jacob S. |
12 |
02-21-2010 08:51 AM |
What to install?
Gwenn |
4 |
08-23-2007 11:37 AM |
A/C install
Legacy Posts |
8 |
02-04-2006 06:27 AM |
A/C install
Legacy Posts |
8 |
12-15-2002 08:49 PM |
