New Table Strength question - Fiberglass RV
Old 05-16-2015, 02:35 PM   #1
DaMScampers's Avatar
Our '93 Scamp has a well worn original table. We plan to:
1. Replace it with a plywood table
2. Epoxy a vintage map onto the top
The original table appears to be 5/8" thick. No such hardwood ply is available to me locally. But, 1/2" hardwood ply is available, and the epoxy folks advertise that it adds 1/8" thickness - making 1/2" ply into a suitable 5/8" replacement.
Questions:
1. Any thoughts on the suitability of 1/2" ply as not only table top, but bed? Will that be strong enough? Will the epoxy add strength? I could add a couple of lateral strips on the bottom in order to add lateral strength. But do I need to?
2. Epoxy: Have you had a great experience with epoxy that you could point me to? Any suggestions at all?
DaMScampers is offline   Reply With Quote
Old 05-16-2015, 05:02 PM   #2
Trailer: 2014 Escape 21
Virginia
For Scamp table tops I use 3/4" oak plywood with golden oak stain. I use 1/2" oak plywood for the cabinet doors. I have seen several stock Scamp table tops crack. Usually by people placing their weight on their knee in the center of the bed.
Epoxy without fibers adds little or no strength.
Eddie
Old 05-16-2015, 06:29 PM   #3
Trailer: Escape 5.0 TA
W. Mass
I've built tables from good 3/4" hardwood ply, Eddie has it right. I would pass on 1/2".
Bob & Deb
padlin00 is offline   Reply With Quote
Old 05-16-2015, 06:45 PM   #4
John Linck's Avatar
Madison, Wisconsin
Eddie
I too used ¾ oak plywood on my 91 Scamp. ½ inch is too thin and the flexing might delaminate your epoxy. I am about to do it again in my newer Scamp and ¾ will be my choice. Fortunately ¾ ply is lighter weight than the fiberboard Scamp chooses. I chose satin polyurethane as finish.
John
John Linck is offline   Reply With Quote
Old 05-16-2015, 07:04 PM   #5
honda03842's Avatar
Name: Norm and Ginny
My table top is glued pine. I believe it's 1/2 inch but will check in the morning. I believe this is our fourth year.
Coated with urethane.
Preparing a 1991 Scamp 16
7 Years ago I made a similar table and used oak stair treads. Worked well but much heavier. Pine seems fine.
I measured the pine this morning and is a 1/2". I purchased a sheet of glued up pine from Home Depot. I believe 30" wide and just had to cur it to length. It was the lightest table solution and has served perfectly for the bed. I oak stained it and than urethaned it, the final coat a poured coat for extra thickness.
Norm and Ginny
2014 Honda Odyssey
1991 Scamp 16
Water tank fiberglass support strength Storm Problem Solving | Owners Helping Owners 3 05-21-2011 08:48 PM
Class I Hitch Design/Strength Question KarinP Towing, Hitching, Axles and Running Gear 13 09-21-2009 09:50 PM
Dinette Table question WriterGal Problem Solving | Owners Helping Owners 2 10-20-2007 11:42 AM
Stupid Question - I can't scamp table back up Dawn Gundermann Problem Solving | Owners Helping Owners 9 10-18-2007 07:32 AM
Table Decoration idea/question Mike Watters Modifications, Alterations and Updates 8 05-23-2007 08:15 PM
