New to campers 19' scamp "fifth wheel" - Page 11 - Fiberglass RV
Old 02-03-2013, 02:21 AM   #141
Trailer: Bigfoot, Trillium, Scamp 5th Wheel
Spokane Wa. and Las Vegas, Nv.
That looks really nice. What did you use for the backsplash?
Old 02-03-2013, 02:47 AM   #142
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
It's actually meant for that. It's plastic. I got it at Menards. It's not cheap, $20 a piece, IIRC, and I needed 4 to do both sides. The edge trim is for a different product that was right by it.
Old 02-03-2013, 02:43 PM   #143
Jared J's Avatar
Kansas
I replaced the trailer plug/wiring lead somebody had put on previously. The splices weren't waterproofed, and it was to short to reach the side of the pickup bed. I also put a runaway brake switch on it, just because. All connectors are adhesive heat shrunk, and I put adhesive heat shrink over the insulation on both sides also, should stay nice and dry.
Old 02-03-2013, 03:01 PM   #144
Is the landing gear motor working yet? If so how is it?
Old 02-03-2013, 04:34 PM   #145
Jared J's Avatar
Kansas
Yep, works great. Faster than cranking by hand.
Old 02-09-2013, 11:09 PM   #146
Jared J's Avatar
Kansas
Well, more bad weather so I couldn't replace the back subfloor again. I cut out the new flooring instead. I was going to remove the other stuff I put down, but the glue stayed on the subfloor instead of the cheap flooring, so I just laid the new stuff on top. It doesn't get glued, so I can deal with the old stuff later if it becomes a problem.
I was hoping to keep a 12" pattern across the vertical part, but my remnant was just long enough to cut the two large pieces out of, with 1/4" extra, talk about luck. I got it centered at least.
The heater is going to be permanently mounted under the sink, with the new converter above it. I'm going to remove the door and make a new wood panel to cover the hole to mount them in.
Old 02-10-2013, 01:08 AM   #147
Jared J's Avatar
Kansas
On another note, I have enough of the side of the vinyl left to cover the table. Anybody see a good reason not to glue the normally glueless vinyl down to the table? I'll jsut paint the edge of the table turquoise. I'm also rethinking painting the cabinets with that floor in there. I think I might paint the benches, the couch, and all the doors in the camper tropical turquoise, and leave the rest of it alone. We'll see. It matches the floor quite well. The cushions are loaded up in the car, I'll get them to the upholstery shop monday...I'm afraid that's going to hurt.
Old 02-10-2013, 01:27 PM   #148
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Except that it's not heat resistant like laminate, I see no reason not to use the vinyl on the table top. I'd think it would be fine so long as you don't set anything hot down on top of it.
Francesca
Old 02-10-2013, 02:04 PM   #149
The floor looks really nice! I've always liked that black/white pattern. For your table I'd consider just painting on the squares and then put liquid plastic/Varathane over it.
Old 02-10-2013, 04:10 PM   #150
Trailer: Chalet
Send a message via Yahoo to Lynn Musgrave
Both of theses are very good ideas...
and I know for a fact that stick on tile would make a pretty nice table top,but like has been said Don't put anything hot on it, and we want talk about how I know both of those facts. Lets just say after a long hard job of covering a table I am still upset at myself
Lynn Musgrave is offline   Reply With Quote
Old 02-14-2013, 05:41 PM   #151
KamperBob's Avatar
Trailer: 19' Scamp 5th Wheel
Somewhere USA
Looking good, Jared! I've considered chess board for when I redo my floor. I thought half black might be too dark. I like light. Seeing yours, maybe not. BTW, are you saving a piece for the fridge door insert?
KamperBob is offline   Reply With Quote
Old 02-14-2013, 06:56 PM   #152
Cyndi B.'s Avatar
Trailer: 2010 Scamp 5th Wheel/2007 Toyota Tundra/2015 Tundra
Montana
And wives left to discover melted things.
Cyndi B. is offline   Reply With Quote
Old 02-14-2013, 08:58 PM   #153
Francesca
Maybe I shouldn't tell you about the whoppin' I got for putting a hot clothing iron down on a formica counter top when I was a kid... laminate is NOT tile.
Just about anything can melt or distort. Maybe this should be an "education" moment?
Old 02-14-2013, 11:11 PM   #154
Jared J's Avatar
Kansas
I'm going to paint it turquoise to match the upholstery.
I put the vinyl on the table, also. I subscribe to the Darwin theory.
It looks like this weekend should be nice enough to tear out the gray water tank and replace the rear subfloor.
I got the quote back from them, $1200, yikes! 22 yards of marine vinyl. It's going to be turquoise on the front panels, ivory on the sides and back, with black piping.
I have to bring a bench in tomorrow so we can match the color.
Wanted; 14" OR 15" WHEEL COVERS Joe Lacey Classified Archives 2 04-21-2010 08:04 AM
"U" Molding & Cabinet doors needed 76' Scamp Dave Baston Problem Solving | Owners Helping Owners 4 06-03-2008 04:27 PM
5th wheel "misjudgment"... steven jones General Chat 1 04-23-2008 05:31 AM
