New to campers 19' scamp "fifth wheel" - Page 19 - Fiberglass RV
Old 03-14-2013, 04:23 AM   #253
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
I might do that, steve. I would like real metal, but that might be too picky.
This converter install is really annoying me with the crappy instructions.
The a/c side was fine, the dc side is really bogus.
1. There are no provisions to running a hot wire to the "120v hot" bus, to power the wire going to the converter. It also doesn't say if it's supposed to be on a circuit breaker. I'm hoping not, but thinking so. I might have to rearrange circuits then. I already have all 6 in use. *Sigh*
2. It doesn't say what gauge wire to run to the battery. I ordered 8 and 12 gauge marine wire to do it, and now that I consult the chart (great idea to do it after, right?), it looks like I should have 4 gauge for a 14' run. Argggh.
3. It also doesn't say if it should have a circuit breaker by the battery, I would guess it should.
They really need to get better instructions.
I have it temporarily wired so it's running off the pd4045, so I could ditch the boat anchor of the old converter. I'm already liking having all the lights on one switch.
Old 03-14-2013, 05:52 AM   #254
Trailer: Bigfoot, Trillium, Scamp 5th Wheel
Spokane Wa. and Las Vegas, Nv.
One of the posters on this board has installed several of the pd4045's. I'd start a new thread and have people walk you through it. No use reinventing the wheel. (plus I'm going to need that info also)LOL.
Old 03-14-2013, 05:55 AM   #255
PS Cute kitty.
I stole the "battery/convertor" switch out of my old boat anchor convertor before I chucked it. I'm sure I'll find a re-purpose for it down the road. Those heavy switches are pricey.
Old 03-14-2013, 06:22 AM   #256
Jared J's Avatar
Kansas
I'm actually going to keep mine. I'm going to add some leads and alligator clips to it, and use it as a small 12v power supply for testing things.
I just ordered new tail lights. I'm still on the prowl for a license plate light, and backup lights I like.
These are 38-39 Lincoln Zephyr led tail lights.
Old 03-14-2013, 11:28 AM   #257
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Cool!
Trust Lincoln to think of LED's years ahead of everyone else!
Francesca
Old 03-14-2013, 11:49 AM   #258
cpaharley2008's Avatar
I do not think the original's were LED, they are retro-fitted. Cool looking though, I remember the ones with the little blue light in the middle, deemed illegal later on when each state's rules came under the Fed's regulations in the 50's.
Old 03-14-2013, 12:27 PM   #259
Nice lights, I had picked out something similar, they were generic teardrop lights and I could have also had tear drop side marker lights. I decided not to yet because the side marker lights were like $12 each and I couldn't justify the bucks for something I really don't need. I might change my mind though.
Old 03-14-2013, 01:35 PM   #260
Jared J's Avatar
Kansas
Well, pd's customer service makes up for what the instructions lack.
The converter 120v wire needs to be on a 15 amp breaker, so I have some residing to do.
The battery wire needs to be rated for full amperage, they won't give size due to liability. So, I just ordered some 4 gauge wire, I'll have to get a breaker, also. *sigh*. Anybody need some 8 gauge?
Old 03-14-2013, 01:40 PM   #261
What are you doing about a stove? I pulled the grates, clips, and knobs before I chucked it if you want em?
Old 03-15-2013, 02:24 AM   #262
Jared J's Avatar
Kansas
Thanks. I decided to get a new one, one way or the other. I thought about an oven, but it seems like a royal pain to pull off, if it worked, the space would be very tight.
I'm debating between a stainless cooktop, or one of the glass ones. I'm a little lost with the glass ones, is the glass down while you cook, or is it just a cover? Some of them have the burner controls under the glass, which leads me to believe it would have to be up (that and the whole needing oxygen thing).
This is the stainless one I like:
RV Direct Online Store
I found some led clearance lights for the camper:
License plate light:
Backup Lights:
I didn't like the old (new) faucet, and drilled holes for a new 8" faucet...much better.
Old 03-15-2013, 05:36 AM   #263
This is the one Scamp uses, it's very nice.
Suburban RV camper Black Cooktop LP Propane Stove 2 Burner 2937ABK Propane New | eBay
Old 03-15-2013, 06:03 AM   #264
This is the one I bought. I put one of these in my Trillium and it worked fine.
Adth 2 Burner LP Gas Black RV camper Range Top Drop in Stove J 5 4 | eBay
Old 03-15-2013, 07:36 AM   #265
Brian B-P's Avatar
There are diesel cooktops which heat through a flush glass surface and vent externally, but not propane as far as I know. The hinged glass top on Dometic's stoves (Smev brand) which are now becoming popular is definitely just a cover which must be open to run a burner.
Old 03-15-2013, 07:41 AM   #266
Jared, Those sleek glass topped stoves are made in Europe- Smev is the Italian manufacturer, Airstreams use them in the Sport models, the glass lifts up on hinges, use the stove and close, likewise for the sink, you can also get combo sink and stove models. I believe Trillium is using a model with a removable glass top similar to Smev units. Be sure and get the self igniting model though.
Wanted; 14" OR 15" WHEEL COVERS Joe Lacey Classified Archives 2 04-21-2010 08:04 AM
"U" Molding & Cabinet doors needed 76' Scamp Dave Baston Problem Solving | Owners Helping Owners 4 06-03-2008 04:27 PM
5th wheel "misjudgment"... steven jones General Chat 1 04-23-2008 05:31 AM
