New to campers 19' scamp "fifth wheel" - Page 25 - Fiberglass RV
Old 03-30-2013, 10:34 AM   #337
Jared J's Avatar
Trailer: 1984 19' scamp
Kansas
It was a foam roller. I'm going to get some floetrol before the last coat and see what that does. It's ridiculous that it takes this much to get paint to work anymore. Somehow I wonder if using 5x as much of it is any more friendly. Pretty soon spraying will be the only option.
Old 03-30-2013, 11:39 PM   #338
Jared J's Avatar
Kansas
It's still not right, but the Floetrol helped. I give up, it's a camper, time to move on. It matches great, at least. The paint looks darker in the picture than it is.
It's not dry enough for the trim, yet. Tomorrow I'll start the other side. I want to get that and the cabinets in the bunk painted before I do the carpet. I try not to tempt Murphy.
Old 03-31-2013, 07:48 PM   #339
Jared J's Avatar
Kansas
Ok, I lied. I put part of the carpet down, I'll just cover it to do the cabinets. I need to order new screw washers/caps from scamp, and don't want to wait to do the carpet.
I'm going to take the trim off the other support and prime/get one coat of paint on it tonight.
Old 03-31-2013, 07:51 PM   #340
Trailer: Bonair Oxygen, formerly owned: Bigfoot CB17, Scamp 19, Trillium 4500
Loon Lake Wa. and Boulder City, Nv.
The carpet squares look really nice!
Steve Hammel is online now   Reply With Quote
Old 03-31-2013, 07:52 PM   #341
PS I got my caps at the local Ace Hardware.
Old 03-31-2013, 07:57 PM   #342
Jared J's Avatar
Kansas
Thanks, and thanks. I have one by me, I'll check them tomorrow. I'm hoping I can just loosen the screws for the cabinets enough to drop them down and get painters paper behind them without removing them, as I'm doing all of this on my own, and can't imagine mounting them back up by myself. If I can do that, I'll just put new caps on one screw at a time.
The carpet squares are a hair different color (different box), but not enough that I care for a camper, especially since 95% of the carpet will be covered by the cushions 95% of the time.
I found lots of (what I'm pretty sure is) mold where scamp ran the carpet so far up the walls. I don't think the windows leaked, I think it's from the ensolite sweating and being covered by the carpet pad. That's why I made mine much shorter, even though a few stains show.
I'm tired of moving stuff around the camper, I want to get the carpet done, the support and cabinets painted, so I can just pile all the cushions up there and quit moving stuff. The only other thing to do will be curtain rods. If I find caps at Ace, I might install them before putting stuff back up there, also.
I'm giving dad measurements for the cabinet doors tonight, and making a paint sample to send to mom so she can get material for curtains and make them for me.
Old 04-01-2013, 12:30 AM   #343
Jared J's Avatar
Kansas
I found some metallic *gasp* silicone, and filled the horrid gap under the sink.
I found a shelving unit, cut a hole for the light switch box, and put it in. I also put a double coat hook in, so a few things can still be hung up. Other than a coat or two, I have no need to hang things up. I'm not taking my suit and tie camping.
I removed the trim, sanded, primed, and got one coat of paint on the other support. I should be able to put another coat on before work, and put the trim on after work, and go back to the carpet.
Old 04-01-2013, 05:53 AM   #344
Closet looks nice did you cut it out, it looks a bit wider? I put a couple of hooks above to the right of the exterior door (entering) by the bunk.
When I took my sink out I was surprised to see that the fiberglass counter conforms to the bottom of the sink. A lip rises up about 1/4 inch so that it doesn't leak.
Old 04-01-2013, 05:57 AM   #345
On the black stains on the ensolite I used "Clorox spray on cleaner" and let it sit for a few minutes. It took it right off but don't get it on any fabric or it will bleach it out. Kills any mold though.
Old 04-01-2013, 07:01 AM   #346
Trailer: 2014 Escape 21
Hey guys. I found white epoxy floor paint at HD. It was about $30 a gallon. Last time I painted a floor I could only find gray epoxy. I plan on putting the back end together today. I finally got all the parts lined up. My big issue is how to cover the wall table board. I had to cut the ensolite away 2" around the board to make the repair. I covered it already with refletix and plan to use a light ID/OD tan carpet.
Eddie
Old 04-01-2013, 11:36 AM   #347
Jared J's Avatar
Kansas
The cabinet opening is stock. I thought about hooks above the couch, but it wouldn't be handy with the screen door there.
I got all the black stains off. There are orangeish stains from the carpet backing still there. I used bleche-white tire cleaner on it, worked great for the rest of the stuff. I'm guessing the orange stains aren't going to come out. Everywhere else, it cleans the ensolite very well.
I need to find some ensolite, I need to remove the piece under the rear window, and replace it.
Old 04-01-2013, 11:47 AM   #348
Francesca Knowles's Avatar
Trailer: '78 Trillium 4500
Trillium Tom sells white Ensolite by the foot (cut from 57" wide bolt).
See it at this link
Link to order form.
Francesca
Old 04-01-2013, 12:01 PM   #349
Jared J's Avatar
Kansas
Awesome, thanks. I really didn't want to replace it with something else. I think I'm the oddball that still likes the stuff.
Old 04-01-2013, 12:13 PM   #350
I like Ensolite, too, mostly for its washable qualities. I like to hose the trailer out periodically...
I'm sorry that Tom doesn't carry it in the original color that matches older Trilliums like mine, though. Good thing for me that mine's still in good shape...
Francesca
Wanted; 14" OR 15" WHEEL COVERS Joe Lacey Classified Archives 2 04-21-2010 08:04 AM
"U" Molding & Cabinet doors needed 76' Scamp Dave Baston Problem Solving | Owners Helping Owners 4 06-03-2008 04:27 PM
5th wheel "misjudgment"... steven jones General Chat 1 04-23-2008 05:31 AM
