New tongue box - Page 3 - Fiberglass RV
Old 07-11-2011, 08:21 PM   #29
Andrew GPSMapNut's Avatar
Trailer: Modified Trillium Jubilee
Now to really confuse things- this one is deeper, the tank should fit
Buyers Products 1701679 Polymer Trailer Tongue Toolbox White
This one is 17" high and (I think) that's on the outside so, a standard 20# tank will not fit. 10# should.
I wish to be one day at least half as good as I think I am today. Andrew Kalinowski
Photography: http://www.FotoCanada.ca
Maps: http://www.CanadianMaps.ca
GPS hobby: www.GPSNuts.com
Andrew GPSMapNut is offline   Reply With Quote
Old 07-11-2011, 10:38 PM   #30
Roy in TO's Avatar
Andrew,
The detailed description at the bottom of the link you quoted states: 18" high.
Old 07-12-2011, 07:00 AM   #31
Originally Posted by Roy in TO View Post
Andrew,
Quote directly from the link:
Quote
Measure your trailer before purchasing. Toolbox measures 36" wide across back, 18" wide across front, 19" deep and 17" high. Weighs 13 lbs. 7 cu ft capacity.
End Quote
So, it's 18" wide (at front) but, not that high and these are outside dimensions. Than again, other than the colour, I think that it is a virtual copy of the one from TSC so, the smaller tanks should fit.
Old 07-13-2011, 11:49 PM   #32
Roy in TO's Avatar
Andrew,
If I get the time before bolerama, I'll try to see if a 20# tank will fit into mine. It looks very similar and I got it from Princess Auto. Made by "Buyers" if I recall.
Or if you are ever in the 400/401 area, you can pop by and see mine. I would not mind meeting you to talk about photography, GPS's and wiring harnesses.
Roy
Old 07-15-2011, 04:29 AM   #33
Joy A's Avatar
Joy A. here....
I couldn't find a pre-made tongue box that was tall enough for a standard 20lb/5 gallon propane tank, also the tongue on a 13 footer is shorter than the 16/17 footers. I contemplated going with a smaller shorter tank but then I thought about dry camping in the cold climates. I'd be using the propane for not just the stove and fridge but also the furnace.
My generator/propane box is roughly 39 inches wide in the back and 31 inches wide in the front by 15 inches deep. It's roughly 21 inches high to accomodate a standard 20lb/5 gallon propane tank. The box on the side is removable and is an exhaust diverter. Oh, and I lined the generator box and divertor with that window bubble wrap sun shade. Used 3M spray on glue to adhere it.
I can't seem to locate the sales tag for the diamond plate I used and the tray that the welder fabricated for me. But as I recall it was in excess of $300 closer to $400. Aluminum diamond plate is very pricey.
Joy A. & Lily
and "Puff", too
No. Ca. Sierra Foothills
Old 07-17-2011, 04:29 PM   #34
cpaharley2008's Avatar
I wonder what your t/w is now?
Old 07-19-2011, 02:37 AM   #35
Joy A's Avatar
Heavy but OK. I had it weighed at the Oregon gathering 2 years ago. I'm just within the weight ratio for the tongue.
Joy A. & Lily
and "Puff", too
Trailer tongue storage box. sara maccalman Problem Solving | Owners Helping Owners 16 05-25-2011 09:25 AM
Black or White Tongue Box? Lisa H. Care and Feeding of Molded Fiberglass Trailers 19 06-01-2009 10:34 AM
Adding a tongue box Roy in TO Modifications, Alterations and Updates 6 06-03-2008 08:31 AM
Who's built a storage box on the tongue?? Vic&Kathy Modifications, Alterations and Updates 18 03-30-2007 07:26 PM
Tongue Box Barbara Gardin Care and Feeding of Molded Fiberglass Trailers 1 07-03-2006 08:03 PM
