New Vinyl Floor - Fiberglass RV
Old 01-31-2012, 07:24 PM   #1
TomB44's Avatar
Trailer: Casita Spirit Delux
Virginia
New Vinyl Floor
Tried of try to get the sand out of the carpet in our Casita 17' SD we decided to install a wood grain vinyl floor. Tom & Sandra
TomB44 is offline   Reply With Quote
Old 01-31-2012, 07:32 PM   #2
Denece's Avatar
Trailer: Compact II
Wow! Looks nice! Was it hard to get such a nice fit?
Denece is offline   Reply With Quote
Old 01-31-2012, 07:52 PM   #3
TomB44's Avatar
Virginia
I started by laying the first piece from the shower door to the front of the refrigerator .The next piece from the refrigerator down by the sink cabinet toward the back. This gave me a good starting point. The pieces next to the rest of the cabinets half to be cut to fit. Took about four hours to finish the job. We decided to use cove molding and attached it with a few brass screws. Tom
Old 01-31-2012, 08:51 PM   #4
WildBirder's Avatar
Very nice, I like the trim as well. Did you use the Allure brand?
WildBirder is offline   Reply With Quote
Old 01-31-2012, 09:20 PM   #5
stanintn's Avatar
Trailer: 2004 13" Scamp
Good looking floor..I did one of my other trailers with that same stuff
stanintn is offline   Reply With Quote
Old 02-01-2012, 11:51 AM   #6
TomB44's Avatar
Virginia
WB...I used Surface Sourse vinyl flooring from Lowe's. It was on sale for $16.70 a box. The total cost of floor, trim and screws came to about $65.00
Tom
Old 02-01-2012, 11:56 AM   #7
Fran L's Avatar
Name: Fran L and Dave W
Trailer: 2008 Escape 5.0
New Mexico
It looks wonderful!
What was your flooring before you put this in?
Did you have to remove the original flooring and, if so, how difficult was that?
Thanks,
Fran
Fran L is offline   Reply With Quote
Old 02-01-2012, 12:08 PM   #8
TomB44's Avatar
Virginia
Originally Posted by Fran L View Post
It looks wonderful!
Thanks,
Fran
The Casita had gray carpet which is glued to a plywood floor. I simply laid the vinyl over the carpet. I numbered the planks as I installed them. If by chance the floor gets wet I'll simply remove the vinyl, let it dry and replace it.Tom
Old 02-01-2012, 02:08 PM   #9
Fran L's Avatar
New Mexico
Did you use the 'Classic Chestnut' color?
Fran
Old 02-01-2012, 08:53 PM   #10
Mike Magee's Avatar
Trailer: Li'l Hauley
Yep, love that wood look. My trailer came with similar vinyl flooring, but I think the stuff you chose looks a bit nicer than mine.
How to prepare Tofu
Step 2: grill some meat
Old 02-02-2012, 03:34 PM   #11
TomB44's Avatar
Virginia
Fran
Fran. I used Winchester Oak
Old 02-02-2012, 03:52 PM   #12
Trailer: 78 scamp '13
Great job. That's a vinyl floor? It looks like a floating laminate. Did you put flooring above, under the table at the back wall? And if you did what did you do for trim? And how did you attach it?
XL milkjug is offline   Reply With Quote
Old 02-02-2012, 04:43 PM   #13
Name: Dave and Shelly
Trailer: 2001 Spirit Deluxe Casita "New Name: Eggspensive"
Iowa
That looks great. Nice job, thanks for the inspiration!
sfoss is offline   Reply With Quote
Old 02-02-2012, 05:43 PM   #14
TomB44's Avatar
Virginia
XL....When I went to Lowe's to pick out a floor the salesman referred to it as vinyl. As a result of your question "That's a vinyl floor" I went back to Lowe's today (to pick up something else) and checked the label on the box of the flooring I used. Sure enough it showed the floor to be laminate. And yes it floats. I covered the entire floor with the laminate.I extended the floor to the wiring at the back. I did not secure it per say, but when I reinstalled the table leg holder it secured the floor in place. I then used cove molding and secured it with a few brass screws. I then replaced the wire cover board to cover the wiring. TomB
Dying vinyl Dave Bese Problem Solving | Owners Helping Owners 6 04-20-2010 10:05 PM
Removing Vinyl Graphics Bob and Judy Care and Feeding of Molded Fiberglass Trailers 7 11-14-2007 05:11 PM
Vinyl Flooring help Nicole M. Modifications, Alterations and Updates 4 04-21-2007 02:55 PM
Nice floating vinyl floor Gina D. Modifications, Alterations and Updates 9 03-17-2007 10:30 AM
Removing Vinyl Graphics Bob and Judy General Chat 0 12-31-1969 07:00 PM
