No Dump Porta Pottie - Fiberglass RV
Old 03-10-2016, 02:48 PM   #1
clyle's Avatar
Got tired of carrying my PP to the bath house to dump. Decided to plumb a maserator to a Theford model 260P (marine toilet). The present design fits under the front bench seat and pulls out to use. That necessitated using a flex hose and some innovative pluming, but it works. A macerator can empty a 2.6 gal PP in a 5 second hurry. I have pics, but they won't upload for some reason.
clyle is offline   Reply With Quote
Old 03-10-2016, 08:14 PM   #2
CampyTime's Avatar
Trailer: Scamp 13' Standard
Wow. Pretty crafty I must say! I agree the drive to the dump station ain't no fun! However, I don't use mine for poop, so no need for the macerator on this end. You've got camping season coming up so plenty of time to test it out. Happy testing!😀
Old 03-10-2016, 08:18 PM   #3
clyle's Avatar
Already tested (using water). I'm in Florida and it's being used.
Old 03-10-2016, 08:20 PM   #4
And, where does the poop go if you don't have to make trips to the bath house?
Old 03-11-2016, 05:58 AM   #5
clyle's Avatar
Originally Posted by Glenn Baglo View Post
And, where does the poop go?
The macerator pumps it out of the PP holding tank and then out of the trailer through a garden hose into the RV park's sewer system. I don't know after that.
Old 03-11-2016, 11:34 AM   #6
So, there is no black tank and you need full hook-ups to make this work? It's not really "no dump" and restricts you to "RV parks".
Old 03-11-2016, 11:44 AM   #7
reeves99's Avatar
Trailer: Escape 13 /Hyundai Santa Fe
Great idea Lyle for those of us who often stay in serviced sites but don't have a trailer toilet.
It's not the size.....
reeves99 is offline   Reply With Quote
Old 03-11-2016, 12:14 PM   #8
Johnny M's Avatar
Deep South
I think it is pretty ingenious, and I don't think it would restrict you to only RV parks, lots of state and national parks here have dump stations so you can dump when leaving, unless of course it fills up before your departure. The no dump would depend on if you have the full hook up or not vs. using a dump station. Camco has a handy sewer cap plug with a garden hose adapter that would probably work well for you setup clyle, I use it with our shower for grey water when we do have full hookups, other wise we use a portable gray water tank.
Old 03-11-2016, 01:59 PM   #9
Scamper Jim's Avatar
Just curious
Lyle,
How does the "product" get into the pumping system? Do you have to tip the porta-potti on its side so it drains into the pump hose attached at the bottom tank?
How do you rinse the porta-potti tank after emptying it?
Jim
Scamper Jim is offline   Reply With Quote
Old 03-11-2016, 02:08 PM   #10
Another potential issue:
I've read on the forum, but not experienced that some parks require the use of a 'donut', a device that seals the septic dump pipe to the slinky hose.
That obviously wouldn't work with a garden hose.
Don't know if those parks have 'donut police'.
Old 03-11-2016, 02:14 PM   #11
clyle's Avatar
The "black tank" is the 2.6 gal holding tank on the Theford. A bit small, I'd admit, but it's a small trailer eh? It's got a small fresh water tank as well. Sure I need full hookup for the maserator system, RV parks are where I spend most of my time. The 2.6 gal holding tank is good for 4-5 days if I'm watchful and then I do need to pump it out in some manner. So I'm not restricted at all. I also still carry my older "dump" model Theford on those trips where I'll be spending extended time in parks w/o sewer hookups. The idea for doing this to begin with was to reduce or eliminate having to carry a couple of gal of liquid sh#* to a public toilet.
Old 03-11-2016, 02:18 PM   #12
clyle's Avatar
No Problem.
Old 03-11-2016, 02:18 PM   #13
Not my idea of fun either, but I have a 20 gal. black tank.
Never have understood the reluctance to use a sani-dump to empty the black tank.
I had a porta-potti years ago at my cabin and was thrilled to leave it behind when I sold the property.
I presume you don't leave the hose in the sani-dump when not dumping ( which is why some parks would require the 'donut' ).
Old 03-11-2016, 02:26 PM   #14
clyle's Avatar
Never have understood the reluctance to use a sani-dump ' ).
If a sani-dump is those wheeled plastic tanks then I personally consider them just a larger tank of sh#* to haul around.
Old 03-11-2016, 02:36 PM   #15
clyle's Avatar
Originally Posted by Scamper Jim View Post
Lyle,
Jim
The maserator is permanently "plumbed" to the Theford marine toilet which is designed to be pumped out. The maserator pumps the stuff out of the holding tank on the Theford, grinds it up such that it will pass through a 5/8-3/4 inch garden hose and then pumps it through the hose to the sewer system. What I did really is just a scaled-down version of what is on most larger RVs. Most of them have a maserator in addition to the flex sewer pipe setups. Cleaning is easy. Just dump a gal or two of clean water into the toilet and let it run through. Add a little chlorine if you wish.
Old 03-11-2016, 02:48 PM   #16
clyle's Avatar
Yes sir. That's the same setup I had going into this project. Just added a "Y" connector at the donut to add the pump out hose.
Old 03-11-2016, 02:51 PM   #17
Nope. Sani-dump is that pipe that the effluent goes into, via a 'stinky slinky'.
No hauling, no mess.
Old 03-11-2016, 02:58 PM   #18
clyle's Avatar
Oh! Well, I've got a 15 foot, 1978 model Trillium and do the best I can with what I got. When I get my $250,00 motor home, I won't be doing these things. Meanwhile.........
Old 03-11-2016, 03:19 PM   #19
A man's gotta do what a man's gotta do.
Old 03-11-2016, 04:50 PM   #20
Radar1's Avatar
Sounds like a good idea for those that just have a porta potti and not the black holding tank. You still have the flexibility to dump in the campground toilet, or use the macerator when camping longer term where you have full hookups.
Sharpsburg, GA
radar1-scamping.blogspot.com
trillium
Privacy curtain for porta-pottie Legacy Posts Modifications, Alterations and Updates 3 11-14-2022 09:45 PM
My Porta Pottie Slide Out Mod CampyTime Modifications, Alterations and Updates 3 10-06-2014 07:42 PM
Dometic porta pottie keekers Plumbing | Systems and Fixtures 8 01-12-2013 12:07 PM
Relocated dump valve Mike Taylor Modifications, Alterations and Updates 3 11-14-2005 03:26 AM
