Off to chop up the Burro - Fiberglass RV
Old 07-23-2006, 10:46 AM   #1
Gina D.'s Avatar
West Coast USA
At the Oregon Gathering, I saw SO many 13s with the front dinette mod. I actually had only seen Lizs until then, and the jury was out at the time..
The more I see them, the more I like. Seeing that there ISN"T that much loss of space, I am goin' ahead with it.. but in a fashion I can reverse (Like most of them are.)
Porta Potti can live under the bed, Dogs can lounge ON the bed instead of stinkin up my goucho, and I don't have to futz and worry about the cushion coverings as much. I saw some chaise lounge padded covers in the right color I am going to chop to bits to make the seats.. off to Lowes!!!
(Wheres my Credit card???)
Old 07-23-2006, 11:05 AM   #2
BOBSMITH's Avatar
Trailer: 2002 Casita Freedom Deluxe / 2007 Nissan Frontier King Cab
Happy chopping!
BOBSMITH is offline   Reply With Quote
Old 07-23-2006, 04:52 PM   #3
Clint's Avatar
Trailer: 1977 13 ft Scamp
Gina are there any pic's of the mod your talking about? You have sparked my interest.
Thanks, Clint
ps. I went to see the Trails West Camper you had given me the link to. It was very nice but my wife thought it was too small, so it will be a 13' egg. Thanks Again!
Clint is offline   Reply With Quote
Old 07-23-2006, 05:12 PM   #4
Gina D.'s Avatar
West Coast USA
The bed is done, that was easy. It's it's normal set up with the big table down and the cushions in place. I put foam on top of that and have two of the same 25 degree bags that are rather festive made into one big double bag (Well, it will be when I get down to Freds to get one of them back)
The front table is already up. That was fairly easy as the former owner FINISHED the cubby covers just like the cabinet doors, in maple, so the piece was already cut, trimmed and finished
Hey, take the easy way out when you can.
I used the pole and sockets from the big table. Have to stop at Camping World and get new ones in case I ever want the big table up again, to seat more than three.
I am working on the cushions now.. also will be easy, but I will save the pics til a little later. I only came inside to cool off in the shower.. for the 3rd time today.
Old 07-23-2006, 07:05 PM   #5
Cant wait to see your new mods!!
Old 07-23-2006, 09:45 PM   #6
Tirah's Avatar
Trailer: 1985 Scamp 13 ft
Send a message via Yahoo to Tirah
Gina, if it's anywhere near as hot there as it is here, you must be melting! I can't wait to see pics of what you are doing. I too, am curious about the modification.
Tirah is offline   Reply With Quote
Old 07-23-2006, 10:14 PM   #7
Gina D.'s Avatar
West Coast USA
It has cooled down to 90
OK.. Here is what I USED to have:
a place that the dogs lived on and a very heavy cushion that added to my tongue weight, collected "stuff, and in general, was not usable unless the kids stayed home (That doesn't happen often.)
This is what I have NOW:
A bigger table, but not the monstrosity the Burro supplies, a place for 3 to eat (With an extra chair) and an area closer to the heater, which is directly opposite the seat with the door under it there.
I can leave my computer set up, no tearing down at nite and stowing on the kitchen counter, and with my swing TV opposite the dinette, I can watch movies etc from either the bed, or the table.
Old 07-23-2006, 10:23 PM   #8
Gina D.'s Avatar
West Coast USA
The table top was already made. It was the support between the two seats. As mentioned earlier, I simply used the hardware from the big table to fasten it. I had to add a spacer to the bottom so the screws would not penetrate the top. A bit of my nieghbors excess flooring scrap did the trick.
I glued the scrap on and drilled, put the socket on. The I inserted the pole, fastened the floor socket to it, positioned the floor socket, drilled and installed hardware. I used caulk in to screw holes just in case they went thru the floor to the outside world. Didn't look like they did tho.
As you can see, the former owner went a little overboard on the cubby covers.. his work.. my gain.
Old 07-23-2006, 10:32 PM   #9
Gina D.'s Avatar
West Coast USA
Those cubby covers are a little crunchy. I did NOT want to butcher the gaucho cushion, so I went in search of an alternative.
Ended up with 4 2x22x22 foam craft squares from Micheals Crafts. I stacked 2 together for each cushion and cut out the contour for the curve at the wall..
On top you see doubled sided foam tape.. I am using this to secure the covering I bought. Cant sew for.. uhm.. beans, so I used a cut a square and tuck method. The tape is gooey and real sticky.. keeps the covering from sliding on the foam. (Yes, it really works!)
I took the car upholstry racing red faux leather and wraped and tucked.. leaving me with this:
Old 07-23-2006, 10:38 PM   #10
Gina D.'s Avatar
West Coast USA
Even tho the foam width was a perfect fit for the seat, there still is a sizable gap behind. My solution was a couple therapuetic pillows I had lying around. They are the same foam, but 4 inches thick. A perfect fit to fill the gap.
I cut each pillow so there would be a backrest and a small arm rest. This worked out perfectly.
Old 07-23-2006, 10:43 PM   #11
Trailer: Fiber Stream
Talking
... and it don't L K "chopped" at all.
Old 07-23-2006, 10:43 PM   #12
Gina D.'s Avatar
West Coast USA
Now, as mentioned earlier.. I can't sew.. the flying monkeys are better at it than me..
BUT, even tho I have this female domestic malfunction, I CAN do what ALL women can do from birth. Wrap Presents.. I used this ingrained skill to cover the pillow foam.
Using rag rugs and red cording, I made little packages. Everything is double knotted and tied at the junctions. It will be holding together for the cockroaches to enjoy after the holocaust
Thanks Liz.. an offshoot of the rug idea comes to life!
Old 07-23-2006, 10:50 PM   #13
Gina D.'s Avatar
West Coast USA
Table and hardware = $0 (already had it)
Price of foam = $24
Obnoxious Red Covering = $40 (I have enough to cover all the other cushions under the bed, to keep them dry in case of window leaks)
Rag rugs = $1 each (Big Lots!!!!)
Big fluffy bed I don't have to manufacture every nite = Priceless.
Don't look at that Porta Potty and junk under there. Pete will be making me a dust ruffle shortly.
Old 07-24-2006, 04:44 AM   #14
Roger H's Avatar
Trailer: Y2K6 Born Free 32RQ on the Kodiak chassis, 1995 Coachmen 19' B-van and 1996 Precision 21' Sailboat
Iowa
Gina... I am SO disappointed... your job looks great. It a pro upholstery job. I looks like a factory install. It'll work perfectly. It improves the Burro tremendously. It's just that I was expecting... well... I dunno... a CHOP job... like:
or...
You know... CHOPPED!
Roger
burro
Burro Widebody, Burro and UHaul Nancy Reeves Problem Solving | Owners Helping Owners 15 06-27-2011 08:41 PM
Project Burro- 1978 Burro 13 foot Scott B. Classified Archives 0 08-09-2009 11:19 PM
I've got a Burro Manual and Burro Waxing Tips!! Amy P Problem Solving | Owners Helping Owners 9 07-28-2009 08:20 AM
Still looking: for Burro or Burro clone, wide body, 14' to 17' Penney H. & Mike E. Wanted: Molded Fiberglass Travel Trailers 0 08-29-2007 07:48 PM
