Oh my door.. with pictures - Page 3 - Fiberglass RV
Old 09-29-2013, 11:16 AM   #41
Trailer: 1973 Love Bug '13
Marty,
Thank you for the links. I have several links and docs that I can send to you if you want. It did not sound like you're being critical at all. I do understand being tactile, I do lots of drawings for my DH. I am happy that I can visualize dimension in my mind. I think it comes from years and years of seamstress work.
I considered all sorts of options for door. We will build a new door but not now, unless my current plan fails. I am posting pics on my web album as we go.
Here is what we have done to establish the correct curve on the door. We place a piece of pattern material, plywood, or foamcore. We used thin plywood. We held the plywood up to the side of the door frame and traced the curve. We did this on the hinge side and on the latch side. Then had out each of those used as a pattern piece. We continue to hold the plywood up to the door frame inside and make corrections until the curve matched the doorframe. This is as far as we have gotten right now. We are doing a little bit every day and I will be posting to our web albums. The link is at the bottom of my post.
Cat futrell is offline   Reply With Quote
Old 09-29-2013, 06:38 PM   #42
Trailer: Wilderness 5th Wheel
door repair
your windows look like they push out at the bottom and have a latch to hold it out. If you have problems or need to repair them this link could help.
Window seals & hardware for 76 Scamp tilt out windows - Fiberglass RV
Marty V.K.
Marty V.K. is offline   Reply With Quote
Old 10-05-2013, 06:47 PM   #43
Door Update
We have the door prepared to glue. Made pattern for brace with plywood using the curve of the door. Cleaned up the old door and cut the new pieces to be inserted. The door fits good. We are going to extend the braces towards the top of the door a few more inches. Will cut braces from the plywood pattern, glue everything, attach the new braces then clamp.
After door had dried we will remove clamps, try it on the camper then, if it fits, we will encase the entire door in fiberglass. Put on the door knob and go camping!
You can see more pics at my Picasa web album at the address below.
Old 10-05-2013, 06:49 PM   #44
You've put a ton of thought and work into this door. I hope every single moment of your first camping trip is WONDERFUL.
Old 10-05-2013, 08:16 PM   #45
Pam Garlow's Avatar
Trailer: U-Haul 1985
That door is a thing of beauty!
Redoing Burro door hinges - door fell off! AndyW Problem Solving | Owners Helping Owners 10 12-30-2015 12:39 PM
Final Escape 19 mod pictures/bed room door? Jack Allen Modifications, Alterations and Updates 2 05-31-2011 04:01 PM
Boler door hinge repair kit and fridge access door John Jesse Problem Solving | Owners Helping Owners 5 05-27-2011 12:32 PM
Door Risers.. Door Props.. Hatch Holder upers?? earl squirrel Problem Solving | Owners Helping Owners 2 05-23-2011 05:07 PM
How To Take Pictures Steve Dunkel General Chat 17 08-10-2009 05:41 PM
