Opinion On Paint on My Play-Mor II - Fiberglass RV
Old 09-13-2019, 09:54 AM   #1
Ambaz's Avatar
Trailer: Play-Mor II
Hi,
I wasn't sure where to post this. If this is the wrong place, let me know.
I am looking for opinions on a paint issue I am having. One of the owners before me painted the camper in a cute white and teal combination, but they painted the window frames teal. The paint is flaking, so I am thinking about just removing it. This Play-Mor trailer is odd though, because all of the windows and center band are brown.
Should I look for a paint to match and just clean it up, or should I remove the teal and just let the brown show? If I do remove it, what should I use so I don't also strip the brown?
Here are a couple photos to show the issue. These are the extreme areas, some aren't really very bad.
Ambaz is offline   Reply With Quote
Old 09-14-2019, 05:30 PM   #2
Lightbulb Window paint solution
Depending on how bad the remaining trim is, I would sand lightly to loosen any further loose paint, then prime the trim with a super adhesion primer like Bin 123 by Zinzer. Then choose the trim colour you want (a good quality latex siding paint works well.)
Nicolas is offline   Reply With Quote
Old 09-16-2019, 11:12 AM   #3
Trailer: 1986 Play-Mor II & Scamp 13' Build date April 2019
Connecticut
I will do a sanding prime and paint. Looks like they painted over the brown with no sanding or primer.
CSiko is offline   Reply With Quote
Old 09-16-2019, 06:10 PM   #4
Ambaz's Avatar
Are you keeping the brown? If not, what are looking to do, neutral, black, matching? I don't mind the brown, but I'm not a fan either. Will the sanding remove the brown or just give a good surface for the new paint to stick to? I'm afraid to take the windows out, try to fix the paint issue and reseal them in case I make it worse.
Old 09-16-2019, 06:20 PM   #5
Connecticut
Will strip the paint and I will be painting black or will keep it brushed and clear coat it.
Taking the widows out is easy. Bunch of screws and the putty tape. I am resealing mine.
Old 09-16-2019, 08:43 PM   #6
Ambaz's Avatar
I'm sure it won't be bad, it's just scary the 1st time! I'm thinking about going black also with the windows also.
Old 09-21-2019, 02:10 PM   #7
Trailer: Borro
The standard rule is dull, dry, and solid. Scuff sand anything you are going to paint them clean and degrees it make any repairs needed clean it again then prime it.
I am a paint guy I deal with ití for a living
Gerry
Gerry648 is offline   Reply With Quote
paint, play-mor
21 inch vent opening in Play Mor II Mark Tyler Problem Solving | Owners Helping Owners 9 07-10-2018 09:35 AM
Play Mor II -- I bought it. Geron Problem Solving | Owners Helping Owners 19 10-01-2007 04:17 PM
Found a Play Mor II for sale, Info? Geron General Chat 9 09-18-2007 07:52 PM
SOLD 13ft Play-Mor II For Sale "The Brown Egg" Susan Tiller Classified Archives 3 01-13-2007 04:48 PM
Album Play-Mor II Susan Tiller Forum Admin, News & Announcements 2 09-19-2006 06:50 AM
