Our '72 Compact Jr. project - Page 3 - Fiberglass RV
Old 04-24-2009, 02:44 PM   #29
Bobbie Mayer's Avatar
Trailer: 2011 Escape 15A
I took the thing apart in just over an hour yesterday. I put it back together tonight in under an hour (if you don't count the wire-brush scrubbing then priming and painting of all related welds and parts). And, with the exception of a quick call to Larry (sorry for waking you Carrie) to ask about just HOW tight to tighten those spring bolts, I did it under my own steam.
Wow, I am so impressed, Jen. I had mine done by someone else- I am afraid to do anything that leaves the trailer un-towable if I can't finish it.
Bobbie
Old 04-24-2009, 09:37 PM   #30
francene's Avatar
Trailer: 13 ft Compact II
Hi Jen,
I would like to build a table like yours. So it flips down to become the bed supports? My Compact II came without a table.
Fran
francene is offline   Reply With Quote
Old 04-25-2009, 02:51 AM   #31
JenPB's Avatar
Trailer: 1972 Compact Jr
Red face
Hi Jen,
Fran
Yeah...this table works wonderfully. I don't know if it was stock, but it's well designed and feels more stable that our outside camping table.
Can't tell for sure, but it looks like your Compact II has a wraparound bench seat (that goes under the front window) rather than then separate benches (one left, one right, nothing under window). My table relies on the window wall for support. HOld on...let me snap some pix....
snip, snap, flash...
WHEW!
Here ya' go...
Jen
The Blog - travels and more
The Book - what we do around these parts
JenPB is offline   Reply With Quote
Old 04-25-2009, 02:53 AM   #32
JenPB's Avatar
Red face
and some more details...
Jen
Old 04-27-2009, 08:57 AM   #33
Steve Hilby's Avatar
Trailer: Compact Jr
Very clever table support, especially the sliding-block-and-knob bit!
Steve Hilby is offline   Reply With Quote
Old 04-27-2009, 05:01 PM   #34
Raya's Avatar
That IS clever, and so nice to see the photos with your comments right on them. I would hate to try to figure that out from just a written description with no photos!
Makes me wish I had a flat wall at the back, just so I could use it (even though I keep the bed made up all the time). It's just so cunning
Old 04-28-2009, 12:01 AM   #35
JenPB's Avatar
Cool
Well, to be quite honest, we keep the bed set up about 85 percent of the time, too. (It comes down for laundry day, and when the bees, skeeters or thundershowers are too heavy. Heck, we'll STAY OUT for rain, but them bitin' bugs...FUHGEDABOUDIT!)
Jen
Old 08-19-2009, 02:27 AM   #36
JenPB's Avatar
Like so many things in our lives, this trailer improvement project goes in bits and spurts. Since reconfiguring the tongue to make room for a spare tire, the gas tank AND the battery in APRIL I finally rewired the trailer last week! Moved the battery from its spot under the kitchen sink (yes, inside a precious cabinet and under the propane stove - have I ever told you about the lessons I learned about charging a battery while running a propane stove?).
Of course, I couldn't just move the battery and rewire the two lights that ran off it. OH no! That's not the way these things work, is it?!
We've pulled in to some camps darn late at night, and I decided I wanted a back porch light. i bought one last fall...it's been awaiting this battery system rework. So, I installed that. (BUGGER of a wire kept coming apart INSIDE the wall...after I pulled it...and hooked it up, and tested it. ARGH! Can you say soldering iron!?)
And the trailer's taillights/side lights were screwed up when I bought the thing. While I made it work with what was there, it was time to rework it so the wires were no longer on the floor where every blessed thing dragged in and out of the cupboards dragged across them! (another ARGH!) I was going to try to just reroute them, but the harness was too short, so I thought I'd just splice in some new wire and work from front to back. But the old wires were, well, old, so I figured I might as well do it right while I had everything apart.
The old harness had the four wires solidly plasticized side by side from the front of the trailer, down the passenger side to the back lights, then through a hole on the floor, under the trailer, through another floor up to the driver's side rear. The NEW harness involved all free wires which were easy to divide and send down the appropriate sides of the trailer. (Two old holes filled in the back, one new hole in the front to accommodate driver's side entry of wires.) The old wire set, however, had a ground that ran all the way to the back. The new set came with a short ground, which I suspect was because they expected the user to ground the frame. I did run it that way, and we'll see how it goes. (At the light end, the grounds already ran to the frame AND the old ground wire.)
I routed the wires up under the cabinetry, using a "hot" glue gun to hold them in place with dabs every foot or so along the wire. We'll see how those hold.
Jen
Old 08-19-2009, 08:20 PM   #37
John and Jaci's Avatar
Trailer: 1972 Boler American ('The USS NeverSail')
Your redo and modifications look great. Hope ours turn out as well as you have done. We need all new insulation for our. How do you like the reflextics that is in yours? Does it insulate well enough in hot summer weather so that A/C can keep it cool inside?. Do you have any idea what the previous owner used to secure it?
Thanks
John and Jaci
John and Jaci | Our furry friends Chief and Scampy
1972 Boler American - The USS NeverSail | 2012 Jeep Wrangler Unlimited
John and Jaci is offline   Reply With Quote
Old 08-19-2009, 09:56 PM   #38
JenPB's Avatar
Thanks
John and Jaci
Thanks JohnAndJaci!
I don't like the APPEARANCE of the Reflextics inside at ALL. I should have decorated in a Martian theme if I was going to leave it out! But I KNOW it works to keep the heat out, and I believe it works to keep some heat in when needed. I think the kid used some really cheap (perhaps even inexpensive) spray-on adhesive to stick it to the walls. (There was evidence of spray adhesive on other unintended points throughout the interior when we got it.) Unfortunately, while it stays up under it's OWN weight, I can't do anything with it at this point. To cover it, I'm going to have to take it off and reglue it properly, then carry on. Or simply take it down and go with some other sort of insulation. I sure would like the insulation to have more of the "rat fur" feel and appearance than my current Area-51 sensation.
And...did you say A/C?! Funny. REEEEAL funny! I know some folks have installed A/C in theirs, but with four folks already trying to squeeze into this home away from home, we don't do A/C. (It's also because we live on my native Central Coast of California where we just don't THINK about A/C - summer temps average mid 70s; winter temps average mid-60s...it's a tough life, but someone has to live here).
I'm CERTAIN that with the Reflectix AND A/C we'd be wonderfully comfortable!
Jen
Jen
Old 08-19-2009, 10:18 PM   #39
Thanks for your info on the reflectics. We have been looking at all the different options for insulation and was interested in it from its "formability" to the Boler shape. We would definitely cover it with a wall covering so as not to have the "area 51" appearance as you put it. That is part of the issue is to figure out how to cover it. In order to have a comfortable night sleep in the summer we must have A/C as daytime highs in Memphis are 90s to 105 and the nighttime "low" is frequently over 80, all with high humidity. Glad to know that you feel that it would meet the need to keep it cool inside with the combination of Reflectics and A/C. Now to figure out how to use it as hidden insulation.
Old 08-27-2009, 05:17 AM   #40
JenPB's Avatar
So,there I was lying flat on my back under Jr., taping up the last of the wire from the rewire project, when I noticed it - a crack. The frame's forward crossmember under the body and behind the tongue had a completely broken vertical weld!
Check the other side.
Sure as shootin' - that one was broken, too! And on the eve of our drive to Big Sur.
GIven that this wasn't the frame's MAIN support, I opted to head north anyhow. Today, on our way home, I stopped in to my favorite welding shop in San Luis Obispo, Ca. (American Muffler and Trailer Hitch). What luck! It was 4, and the shop was empty. After a quick look, they had me back in, and in less than 15 minutes and only $30 lighter I was back on the road, feeling much safer about my little trailer.
While there, I finally caved and bought the Draw-tite J-pin with lock to help keep down some of the noise. While I have the trailer weight well distributed, it still bangs around when we get onto bumpy roads or head over driveways, or pull through bumpy campgrounds (especially annoying late at night when I'm trying to SNEAK in). Installed it tonight. I'll let you know what I think after we tow with it for a bit.
Leaving Monday for Utah/Nebraska/Colorado loop over the next three weeks. Anyone headed that way?
Jen
Old 08-27-2009, 06:45 AM   #41
Raya's Avatar
Hi Jen,
If you already told us this and I forgot, I'm sorry, but what are you holding your hitch bar in with now, if not a J-pin (or, is the usual thick pin with a 45 bend at one end and a hole in the other that receives the hair-pin not a J-pin?)?
Is what you have now something thinner that allows the draw bar to move around?
Yay for you in having a good, reasonably priced welder so handy
Thanks,
Raya
Old 01-25-2010, 04:04 AM   #42
JenPB's Avatar
Question
Never even SAW this response, Raya! Not sure why...but I'm here to update, and VOILA, here was your question.
I was using the typical heavy-duty 45-degree bend pin with the R-clip (hairpin cotter pin). I tried the shim mentioned elsewhere on these boards, but it didn't work out so well for me. (Fell out on the road, fell out on the driveway, fell out at camp...even after attempting to squeeze it in with a bit of extra umph from My Little Helper).
The J-pin lock is wonderful. It was well worth the bucks. The trailer rides silently now. I feel a lot better about it, too, now that it's not banging around back there.
Hi Jen,
Thanks,
Raya
Jen
Compact/Compact Jr./Hunter, etc. owners POLL JenPB General Chat 22 03-17-2014 09:31 PM
Compact/Compact Jr./Hunter class owners JenPB General Chat 21 06-05-2009 02:10 PM
WANTED A COMPACT JUNIOR OR COMPACT II IN VANCOUVER, B.C. Angela Mattice Wanted: Molded Fiberglass Travel Trailers 0 01-20-2007 12:19 AM
My Project Robin Bunker Modifications, Alterations and Updates 21 05-21-2006 07:22 PM
Someone here might need a project... Lizbeth General Chat 15 11-14-2005 02:04 PM
