07-07-2011, 03:09 PM
Trailer: 1983 Burro 13'
Our complete Burro 13'.
07-07-2011, 03:20 PM
Trailer: 1983 13 ft Scamp
07-07-2011, 04:23 PM
Trailer: 1988 Perris Pacer ('Bean') / 2004 Element
Great job--love the colors!
07-07-2011, 05:28 PM
I didn't know this project was an obstacle in my life that needed. Now everything is cool.I lost sleep over it, found myself driving on highway frontage roads in wheat fields with four hours of sleep looking for goodies. I'm 36, it was like one-hundred days till X-mas like never before. I'm broke now. To start. This Burro wasn't abused too badly, it was local,I was lucky. I think the interior is inferior to other fiberglass campers. I'm glad this is the one. I started gutting it before a snowstorm on March 2nd the day i got it. I put new lam floors, interior, replaced the door latch with a real door latch(old type is junk),rewired all, bought proper led(48x2)on both sides. I also have battery type too; Don't want to be in the dark. I also added a Fantastic 4000 tech fan. I went to a carpet store chose the pattern, cut it my self, and called Stan the binding man. My talented girlfriend Little Bear did all the sewing, without her I don't know... I tried my hardest not to drill holes, and did well. I need to have some crankin tunes so I found a sterio that has all the inputs added an amp 12in sub for home use. The 50w solar panel powers everything. Since it gets hot here I put my rolling A/C(not solar) unit up front and vented it through the window. Some tools, and materials were found at the local Recource yard. Seals were at the upholstery shop. I am so glad it's done.
07-07-2011, 06:26 PM
Thanks for sharing the picture and the story! May you find all the work you did gives you plenty of camping experiences and makes lots of great memories too.
07-08-2011, 07:06 AM
Trailer: '83 Burro
Virginia
All I can say is WOW!
That is the most beautiful interior in a Burro that I have seen after months of searching. One question... were the shelves already hung in front and back when you got it, or did you add them? They make such a great difference in the storage space available. It appears that they have recessed lighting (can lights?) installed. Is this the case? How are they working out for you? (OK, so I asked more than one question, you were showing it off, right?) Thanks for sharing what is a real treasure of a build... nothing really radical, but obviously done with lots of planning and great ideas.
Regards,
Froggie
07-08-2011, 08:27 AM
Trailer: 1976 Scamp 13 ft
Elie, fantastic job on the interior. I think this story is a familiar one with many of us, I didn't know what I was getting into and how much time and work it was going to be to finish. Now that it's done, you have a completely custom trailer for your needs, and one that looks cool to boot. Great job.
Dan H
07-08-2011, 08:52 AM
Trailer: 1980 13 ft. burro
It's lovely! I would like to hear more about the overhead shelves, too.
07-08-2011, 11:47 AM
For the lighting on the shelves I used cheap battery powered for versatility. The primary LED lights are at the end of the cabinet on each side. Each have 48 LED off solar. They give plenty of light, and the fiberglass reflects well. I payed $9 apiece.
07-08-2011, 11:53 AM
The shelves.
The shelves were there. I am lucky this one had them; I just reinforced. Every one is different.
07-09-2011, 08:17 PM
Trailer: 84 Burro 13 ft
Very nice. Jen, the shelves are much like mine. They are made from a repurposed shower stall using the edges for shelf ledges. Make a cardboard template. Cut the shelves from the outside edges. Attach with hinges (for brackets) and use rivets to attach the hinges through the interior layer of fiberglass. Put masking tape around the drill bit so you know how deep to go -about a quarter inch. They make a nice sturdy shelf. rb
07-14-2011, 01:12 PM
Trailer: 17 ft Burro (Dance Hall Edition ''The Casbah'')
Great remodel!
I really would love to know how you are mounting your tv? I have a 17ft burro and am having a difficult time deciding how and where to mount a 22 inch vizeo tv with a non standard mounting bracket.
Seeing your install, I am inspired because I never thought about mounting it up front about the table.
I would love to hear details on your install.
With much appreciation,
Laurie
07-15-2011, 11:44 AM
Monitor install.
Originally Posted by Laurie T
Great remodel!
Laurie
I had an older Dell monitor sitting around with a strong base with swivel. The ledge for the bunk looked sturdy so I cut a piece of lam wood (the same as floor) glued it and put an aluminum trim around to finish. I then cut the excess metal from the base to fit, drilled two 1/4 in holes through and used bolt-wing nut combo with washers. It comes out in a minute. Then I ran wires to the back (audio). I covered the VGA cable with white duct tape. Not a TV. We use it to stream videos off the computer via cell phone connection. I hope this inspires you.
07-19-2011, 12:58 PM
Trailer: 85 U-Haul
You did a great job!! It gives me inspiration to get back to work on ours!!! It is a lot of work but soooo worth it in the end- happy camping!
~Christina
07-19-2011, 02:44 PM
Trailer: '83 Burro
Virginia
I'm getting ready to cut a new table top for the larger (rear) table in my Burro (the original was missing.) Most of the time, the "table top" will actually be part of the "mattress support" as I have a one-piece foam mattress that a PO had made up specially for that spot. BUUUT, I want to make it usable as a table if the need arises, so I am wondering about using one of the flush mounted base plates that go down into the floor instead of having that big bump in the middle of what would usually be slide-in storage space. What do you think about that?
Froggie
07-25-2011, 02:32 PM
Trailer: uhaul, 84, 13CT
Massachusetts
What a fanfastic job. Looks great. I'd like to see a photo of your rolling AC unit. your Burro is similar to my U Haul 13 and I'm considering a portable unit. I am thinking about placing the AC unit in the closet but the dimensions are real close. Keep us posted. Nice job. h.mike
07-25-2011, 03:08 PM
Trailer: '83 Burro
Virginia
Rusty,
What material was used in the shower stall/shelf? Is it fiberglass or some sort of poly or plastic? Do you remember where they were sold? I'm really starting to feel like I need to put in at least the rear shelf... that's where my bed will be most of the time, I think, and having storage above that for clothing, linens, etc. would be a most useful addition. The original Burro instructions I have show a really neat shelf with a front lip, but I don't have any way of getting one of those!
07-25-2011, 03:09 PM
Trailer: '98 BURRO 17WB
Delaware
Great remodel!
Laurie
For the B17, should you change your mind and decide that you want your TV at the side over the rear dinette/master suite, try this undercab bracket: Amazon.com: VideoSecu Under Cabinet Mount Flip for LCD TV monitor Black LCD-CM 1MS: Electronics Worked for me but I had a standard rivnut pattern on the back of a relatively recent 19" flatscreen of reasonable weight and an easy thrubolt in the left side upper locker.
jack
07-25-2011, 07:13 PM
Froggie, Fiberglass shower stalls were used in the 60's and probably earlier and later than that. Ask any contractor who does remodeling and see if they will save one for you, or you can possibly advertise for one on craigslist. They have a "lip" which was attached to a 2 x4 during installation. good luck. rb
07-27-2011, 07:59 PM
Trailer: Compact Jr
Froggie
I put a flush-mount socket in the floor of my sister's friend Karen's Burro:
Worked just fine. Another thing I did that you might want to consider, is I built a hollow-core tabletop: A frame of 1x4 lumber with 1/8 plywood on each side, put together with plenty of glue, with Formica and an aluminum edge trim to finish it off. A bit of work, but much lighter than a solid plywood tabletop. Here are pics of the framework and the finished table:
