Our complete Burro 13'. - Fiberglass RV
Old 07-07-2011, 03:09 PM   #1
Trailer: 1983 Burro 13'
ID:	37678[attach]37678[/Click image for larger version
Elie BBBurro is offline   Reply With Quote
Old 07-07-2011, 03:20 PM   #2
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
Old 07-07-2011, 04:23 PM   #3
Vickie B.'s Avatar
Trailer: 1988 Perris Pacer ('Bean') / 2015 Ford F-150, 2017 Winnebago UltraLite 27BHSS
Nebraska
Great job--love the colors!
Vickie B. is offline   Reply With Quote
Old 07-07-2011, 05:28 PM   #4
I didn't know this project was an obstacle in my life that needed. Now everything is cool.I lost sleep over it, found myself driving on highway frontage roads in wheat fields with four hours of sleep looking for goodies. I'm 36, it was like one-hundred days till X-mas like never before. I'm broke now. To start. This Burro wasn't abused too badly, it was local,I was lucky. I think the interior is inferior to other fiberglass campers. I'm glad this is the one. I started gutting it before a snowstorm on March 2nd the day i got it. I put new lam floors, interior, replaced the door latch with a real door latch(old type is junk),rewired all, bought proper led(48x2)on both sides. I also have battery type too; Don't want to be in the dark. I also added a Fantastic 4000 tech fan. I went to a carpet store chose the pattern, cut it my self, and called Stan the binding man. My talented girlfriend Little Bear did all the sewing, without her I don't know... I tried my hardest not to drill holes, and did well. I need to have some crankin tunes so I found a sterio that has all the inputs added an amp 12in sub for home use. The 50w solar panel powers everything. Since it gets hot here I put my rolling A/C(not solar) unit up front and vented it through the window. Some tools, and materials were found at the local Recource yard. Seals were at the upholstery shop. I am so glad it's done.
Old 07-07-2011, 06:26 PM   #5
Thanks for sharing the picture and the story! May you find all the work you did gives you plenty of camping experiences and makes lots of great memories too.
Old 07-08-2011, 07:06 AM   #6
Green Frog's Avatar
Trailer: '83 Burro
Virginia
All I can say is WOW!
That is the most beautiful interior in a Burro that I have seen after months of searching. One question... were the shelves already hung in front and back when you got it, or did you add them? They make such a great difference in the storage space available. It appears that they have recessed lighting (can lights?) installed. Is this the case? How are they working out for you? (OK, so I asked more than one question, you were showing it off, right?) Thanks for sharing what is a real treasure of a build... nothing really radical, but obviously done with lots of planning and great ideas.
Regards,
Froggie
Green Frog is offline   Reply With Quote
Old 07-08-2011, 08:27 AM   #7
DannyH's Avatar
Trailer: 1976 Scamp 13 ft "Siesta"
Elie, fantastic job on the interior. I think this story is a familiar one with many of us, I didn't know what I was getting into and how much time and work it was going to be to finish. Now that it's done, you have a completely custom trailer for your needs, and one that looks cool to boot. Great job.
Dan H
DannyH is offline   Reply With Quote
Old 07-08-2011, 08:52 AM   #8
jen b's Avatar
Trailer: 1980 13 ft. burro
It's lovely! I would like to hear more about the overhead shelves, too.
jen b is offline   Reply With Quote
Old 07-08-2011, 11:47 AM   #9
For the lighting on the shelves I used cheap battery powered for versatility. The primary LED lights are at the end of the cabinet on each side. Each have 48 LED off solar. They give plenty of light, and the fiberglass reflects well. I payed $9 apiece.
Old 07-08-2011, 11:53 AM   #10
The shelves.
The shelves were there. I am lucky this one had them; I just reinforced. Every one is different.
Old 07-09-2011, 08:17 PM   #11
Rusty01's Avatar
Trailer: 84 Burro 13 ft
Very nice. Jen, the shelves are much like mine. They are made from a repurposed shower stall using the edges for shelf ledges. Make a cardboard template. Cut the shelves from the outside edges. Attach with hinges (for brackets) and use rivets to attach the hinges through the interior layer of fiberglass. Put masking tape around the drill bit so you know how deep to go -about a quarter inch. They make a nice sturdy shelf. rb
Rusty01 is offline   Reply With Quote
Old 07-14-2011, 01:12 PM   #12
Laurie T's Avatar
Trailer: 17 ft Burro (Dance Hall Edition ''The Casbah'')
Great remodel!
I really would love to know how you are mounting your tv? I have a 17ft burro and am having a difficult time deciding how and where to mount a 22 inch vizeo tv with a non standard mounting bracket.
Seeing your install, I am inspired because I never thought about mounting it up front about the table.
I would love to hear details on your install.
With much appreciation,
Laurie
Laurie T is offline   Reply With Quote
Old 07-15-2011, 11:44 AM   #13
Monitor install.
Originally Posted by Laurie T View Post
Great remodel!
Laurie
I had an older Dell monitor sitting around with a strong base with swivel. The ledge for the bunk looked sturdy so I cut a piece of lam wood (the same as floor) glued it and put an aluminum trim around to finish. I then cut the excess metal from the base to fit, drilled two 1/4 in holes through and used bolt-wing nut combo with washers. It comes out in a minute. Then I ran wires to the back (audio). I covered the VGA cable with white duct tape. Not a TV. We use it to stream videos off the computer via cell phone connection. I hope this inspires you.
Old 07-19-2011, 12:58 PM   #14
Trailer: 85 U-Haul
You did a great job!! It gives me inspiration to get back to work on ours!!! It is a lot of work but soooo worth it in the end- happy camping!
~Christina
Christina is offline   Reply With Quote
burro
Free complete set of cushions from a 1985 burro 13 (need recovered) Mark Shaffer Classified Archives 6 04-05-2011 07:58 AM
Our Project is Complete Bonnie and Roger in WA Modifications, Alterations and Updates 18 02-20-2011 11:33 AM
Complete Fiberglass Business ttmatson General Chat 12 05-05-2006 10:24 AM
I am a complete newborn Liz Kissell General Chat 10 05-01-2006 05:03 PM
