OurBoler.com 74 Boler rebuild - Page 10 - Fiberglass RV
Old 07-15-2013, 04:14 PM   #127
GMike A's Avatar
I like that even better Tom.. When were kids we used to mold with clay and then you could bake it gently in the oven and it would harden. May not even have to let it harden since the epoxy would be light and not distort the image. cool!!!
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 07-15-2013, 10:04 PM   #128
I love the ideas. Home depot didn't have it, so I will look around and give making a new logo a try. This project has been full of learning opportunities.
Nelmes is offline   Reply With Quote
Old 07-15-2013, 10:59 PM   #129
i am hoping to go camping this weekend, so my long term plan for the tongue is not an option, so I found a few parts around the garage to hold the propane tank on.
Old 07-16-2013, 08:58 AM   #130
Since i plan to cook outside I wanted to keep the kitchen organized. I took this box from home depot and used some left over 1/4 plywood cut to shape. It rests on the ledge in the box. The center piece I reinforced and screwed to the box. The other two lift out. the holes make it easy to lift out, and also line up with the feet on the stove, so the stove fits without moving while driving.
When I get the fabric for the trailer I will also add a barrier between the two sides.
I took my dishes, pots, lighters and other kitchen stuff, it all fit with lots of room to spare. Should make setting up the camp kitchen and traveling with it my simpler.
Old 07-16-2013, 10:07 AM   #131
GMike A's Avatar
Are you one of those preppers who can take a tin can, a piece of string and turn it into a three burner cook stove using only a pocket knife and a piece of flint? Just curious as you are doing one Heck of a job on your Egg.
Mike
K5NAN
"Miss Adventures"
Old 07-16-2013, 11:55 AM   #132
No, I usually work with numbers and a computer, and wonder which way to turn a wrench. That is why this project is so much fun
Glad it looks like I know what I am doing.
Old 07-16-2013, 09:36 PM   #133
When doing the body work, i fixed most of the gap at the bottom of the door, however when I installed the door one side had 15 mm more to go. First step was a washer between the door and the hinge. this helped a little.
That helped, but wasn't enough.
So next I decided to build a rack at the bottom of the door to hold books, magazines, bug spray and sun screen. This rack could hold the curve of the door. I took a piece of paper and traced the curve onto the paper. Held the side that worked for the pieces for both sides.
This fixed the door. I wanted to get the trailer ready to camp, so I left this for now as it does not need to be done to camp.
Old 07-17-2013, 10:47 PM   #134
I wanted small clean looking LED marker lights. I picked up something close, removed the mounting plate. to mount them I broke the heads off small bolts, used a self taping screw to get some threads started and threaded the bolts in. Added some glue to be safe, then soldered on a ground wire.
The light on the right if after the work. I then added some butyl tape and installed them. I added a small flame to each light, so far I like them.
Old 07-18-2013, 05:56 AM   #135
GMike A's Avatar
Chris you were spot on up until now. The wind was blowing from the other direction on those flames. People will know its not real.
Mike
K5NAN
"Miss Adventures"
Old 07-19-2013, 08:38 AM   #136
To make to roof support I used a curtain rod, same as the wrap around one in the trailer, just bigger. It was perfect, strong enough and had a plastic piece on the end that worked great between the counter and rod, and it came with a screw to secure it to the counter.
I also plan to make a bunk rail from the support to the other rail, for the odd trip where we want to sleep 3 kids. I am also watching for the right mini projector to attach to the rod, turning the back splash into a large TV on those rainy days.
Old 07-19-2013, 08:38 AM   #137
Today is a cleaning day, need to get the trailer ready for it's first outing this weekend
Old 07-22-2013, 07:51 AM   #138
So I had the frame reinforced, and on the first trip it broke under the trailer. A new frame was on the list, but with the frame reinforced I thought it could wait until next spring.
The damage to the trailer was minimal, as the tongue lifts up, it lifted the front of the trailer, so it did little damage, and the propane tank made a small mark in the front.
It was the same price to have the trailer reinforced again so I can tow it home, or have it towed all the way. So I am having the frame fixed. With that i still need to find a way to build a new frame.
Old 07-22-2013, 08:12 AM   #139
GMike A's Avatar
Man I am sorry that happened... Could have been worse but thats always easy to say. At least no one was hurt.
Mike
K5NAN
"Miss Adventures"
Old 07-22-2013, 09:10 AM   #140
slavandheather's Avatar
Trailer: 1978 Boler
Huge bummer! This is further proof how bad these were made originally. Good to hear that the shell was not damaged or anyone hurt.
Slav
slavandheather is offline   Reply With Quote
boler
1978 Boler Complete Restoration / Rebuild slavandheather Modifications, Alterations and Updates 245 06-17-2017 10:10 AM
The 1972 Boler Rebuild bomni Modifications, Alterations and Updates 9 10-12-2013 10:13 PM
Newbie rebuild 74 Boler -13 Firesurfer30 Hi, I am.... 1 06-13-2012 06:43 PM
1974 Boler Rebuild KyleRuppel Modifications, Alterations and Updates 33 06-04-2012 09:17 AM
