OurBoler.com 74 Boler rebuild - Page 13 - Fiberglass RV
Old 09-25-2013, 03:25 PM   #169
Beverly Jones's Avatar
Trailer: 1975 Boler
Wrap Around curtain rods?
I love the wrap around curtain idea!
Where did you purchase the rods?
Keep up the good work!!!
Originally Posted by Nelmes View Post
I did manage to get some body work done, but as it started raining again I was forced back into the garage.
I picked up the wrap around curtain rod, the idea being that over the counter it could hang storage, depending on what we need.
I have never used a rivet before, so I read the instructions on the back of the package and Riveted on the Starting point to the closet.
I installed the rod over the counter as well, and the bend that will allow the rod to wrap around to the other window.
The green tape is just to mark where the rod ends and the corner piece begins. Regrettably I need to Rivet through the shell to do the rest, so I will wait until after it is painted.
I stained the remaining wood pieces and cleaned the garage as I wait for the weather to improve.
Beverly Jones is offline   Reply With Quote
Old 09-26-2013, 09:39 AM   #170
Thanks Donna D, glad you like it, it has been a fun project
Hi Beverly, The curtain rods are from ikea, I used straight rods, but added a gentle bend to the ones at the front and back to get a curve. Racka RÄCKA Curtain rod - black, 70x120 cm - IKEA
Nelmes is offline   Reply With Quote
Old 09-26-2013, 09:41 AM   #171
Genital bend - sounds like it could be painful.
John
jaevans is offline   Reply With Quote
Old 09-26-2013, 09:52 AM   #172
Thanks John, didn't catch that
Old 09-27-2013, 08:28 AM   #173
As the summer cooled down I played with a candle heater idea I found online.
The idea is to use a ceramic pot to take the heat from a candle and instead of it moving to the roof, radiate it outwards to warm a small space. I only had 2 pots around the house, not the three that seems standard online but decided to give it a shot.
I used a propane heater to warm the trailer before bed, then used this to help keep the trailer warm. It did raise the temperature, but the tea lights only lasted for 4 hours, so I have since picked up some that have an 8 hour burn time. I usually used 3 candles, which was all the little tin could hold.
I plan to play with possible other fuel sources, venting options and set up s that support a few of the 8 hour candles as this seems like a great way to add simple heat when without hookups (which so far is always).
Old 09-27-2013, 01:41 PM   #174
slavandheather's Avatar
Trailer: 1978 Boler
Hey, how about putting rocks into your fire and when the fire dies down get them carefully into a ceramic/clay/metal pot and into the trailer? Should radiate heat for a while and no candle fumes!
Cheers,
Slav
1978 Boler - work in progress...
slavandheather is offline   Reply With Quote
Old 09-27-2013, 02:40 PM   #175
Be careful with heating rocks. If they have any gas or moisture locked inside, they may explode in the fire. Having said that, lots of folks have done this. Some backpackers will wrap hot rocks in cloth/heavy fabric and place them inside their sleeping bags at night. You just have to be careful.
Old 09-27-2013, 07:34 PM   #176
I like the heated rock idea, however I want to make sure I have a solution that always works. With fire bans common in the summer I don't want to depend on the fire, but will add it to the list of things to try (good warning about exploding rocks).
As for candle fumes, it is minimal and not something that poses any real risk for a couple candles. I also have detectors that are over sensitive in the trailer if it becomes an issue. I have looked at other heating options, and would vent outside if going with anything bigger.
Old 09-28-2013, 04:37 PM   #177
Cut up a board and made a cover for the sink
Just need to pick up some magnetic tape to keep it place when traveling.
Old 09-28-2013, 05:42 PM   #178
Trailer: '78 Trillium 4500
If the sink is stainless, magnets may not adhere.
Dave_L is offline   Reply With Quote
Old 09-28-2013, 08:39 PM   #179
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Don't think magnets will stick to stainless steel. Might want to test it first before you spend your money.
mszabo is online now   Reply With Quote
Old 09-28-2013, 08:45 PM   #180
mszabo's Avatar
RV Over The Sink Cover Cutting Board 13 3 4" x 11 3 8" | eBay
Bottom dollar has several diffrent cutting boards for sale cheaper that you can drive to the store.
Old 09-28-2013, 09:38 PM   #181
I have seen magnets stick to sinks, however I just tested and on this one they do not. I am sure another way to get it to stay on will show up.
Old 09-30-2013, 11:59 AM   #182
Trailer: 17 foot boler
chris , if the board goes past the sides of the sink just put a little on the counter and the edges of the board , no need to spend more money .
vette_boy is offline   Reply With Quote
boler
1978 Boler Complete Restoration / Rebuild slavandheather Modifications, Alterations and Updates 245 06-17-2017 10:10 AM
The 1972 Boler Rebuild bomni Modifications, Alterations and Updates 9 10-12-2013 10:13 PM
Newbie rebuild 74 Boler -13 Firesurfer30 Hi, I am.... 1 06-13-2012 06:43 PM
1974 Boler Rebuild KyleRuppel Modifications, Alterations and Updates 33 06-04-2012 09:17 AM
