OurBoler.com 74 Boler rebuild - Page 17 - Fiberglass RV
Old 05-05-2015, 04:58 PM   #225
I picked up some babymoons at a local hubcap store and decided to paint the wheels white with a small green pinstripe.
The pinstripe didn't work out, a little more research and I will try again, but they are good enough for now.
Another local Boler owner was nice enough to pick up a drip guard for me, so I installed that as well.
Nelmes is offline   Reply With Quote
Old 05-05-2015, 08:10 PM   #226
Chris, you're doing a fabulous job. Thanks for sharing the pictures and letting us all follow along on the rehab!
Old 05-05-2015, 11:01 PM   #227
Trailer: Shopping
Originally Posted by Nelmes View Post
Hi Rick,
I priced out an new axle, but also had the old axle checked and it was said to be good. The xle did have a twist in it, but when we where welding up the new frame we also fixed the old axle. The axle is only held on by 4 bolts, making it really easy to change in the future if it is needed.
I am curious why would you recommend brakes? I have always found it stops fast enough, and I am looking at trucks for this summer so we can bring more toys camping (bikes, canoes ect), and will have a 6500 lb towing capacity.
Brakes are light & relatively cheap. You may not need them most of the time. However it only takes once when you stop a few feet shorter or can manually hit the trailer brakes to stop a fishtail to pay for them several times over. Trailer brakes are also cheaper & easier to replace than the ones on your tow vehicle.
Sent from my K00C using Fiberglass RV mobile app
Fallon is online now   Reply With Quote
Old 05-06-2015, 12:25 PM   #228
dleverton's Avatar
Trailer: Trillium 1300 1973
I'm towing with a Subaru Forrester and it specifies a larger towing weight if the trailer has brakes, so I need them to be legal. I spent many years towing a rally car on a single axil trailer and the trailer brakes saved the day a couple times when the rig got sideways on a slippery surface.
Doug L
Doug
dleverton is offline   Reply With Quote
Old 05-06-2015, 12:50 PM   #229
Thanks Donna.
Great comments on the brakes! Thanks.
Old 05-10-2015, 12:56 PM   #230
Johnny M's Avatar
Deep South
I shifted back to the outside, as it is the biggest part of the project holding up our camping adventures.
I test fit all the windows and vents and with a metal file adjusted the fit.
I taped up all the windows to keep the inside clean while I work on the exterior. I then scraped off some body fill that was used over a year ago, but never hardened (I am sure it was operator error.) I then added a couple layers of fiberglass to the patches on the outside. I cut the vents for the 3 way cooler. With the fiberglass dry it was time for the Bondo.
You can see the Bondo and the vents for the cooler. A hatch was cut out of this side to serve coffee out of this trailer, which is a lot of the Bondo work.
The cooler vents from the inside of the trailer.
Test fitting the cooler, it has lots of clearance behind it and room for the vents and fan.
Put the tongue jack on, the old one was seized and the top was missing or bent. The wheel makes it easier to move it in and out of the garage.
What brand and model is your 3 way cooler? I have seen 110/12 volt coolers but not a 3 way for LP, just the 3 way RV refrigerators...did you give $209 for it new? Where? How well does it work for you?
Old 05-10-2015, 05:45 PM   #231
I sold the cooler as I was unhappy with how it worked. It did not have a level bubble and was tough to tell if it was level. If it was not level it would still burn, but not cool so it was not obvious. We had everything spoil twice due to this. It was tough to light.
I got an old fridge, and a new regulator and hose. Got the propane working on the fridge and love it. It is worth the extra money to get a fridge.
Old 05-18-2015, 07:25 PM   #232
Trailer: Flat top Boler
Manitoba
Boler emblem
Hi!
I have no emblems on my Boler and am hoping to buy one casted from somebody. Can anyone help me out?
Bolero47 is offline   Reply With Quote
Old 05-19-2015, 08:17 PM   #233
Hi Erica,
I think we can figure something out, I will message you.
boler
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
1978 Boler Complete Restoration / Rebuild slavandheather Modifications, Alterations and Updates 245 06-17-2017 10:10 AM
The 1972 Boler Rebuild bomni Modifications, Alterations and Updates 9 10-12-2013 10:13 PM
Newbie rebuild 74 Boler -13 Firesurfer30 Hi, I am.... 1 06-13-2012 06:43 PM
1974 Boler Rebuild KyleRuppel Modifications, Alterations and Updates 33 06-04-2012 09:17 AM
