Outside outlet Placement - Fiberglass RV
Old 07-12-2010, 03:27 PM   #1
Trailer: 1999 Burro
I am adding several new outlets to my Burro this week and am planning on adding an outdoor outlet. Somewhere near the door on the curbside is probably the best location, but I have a couple of concerns with that and want some feedback.
First, I am reluctant to mount the box on the fiberglass side of the camper, and second, getting power chased to the curbside is fairly difficult. With the way a Burro is put together, there is not a good way to get power from the road side, unless I put a piece of conduit between the two sides at the front or back.
I am considering mounting the box underneath the camper. Any downsides to this approach?
joelh is offline   Reply With Quote
Old 07-12-2010, 06:19 PM   #2
Myron Leski's Avatar
Trailer: 19' Escape
NM
Not if you never drive rough terrain or take it out in the rain.
Myron Leski is offline   Reply With Quote
Old 07-12-2010, 06:51 PM   #3
Alf S.'s Avatar
Trailer: 2014 Escape 5.0TA / 2010 Nissan Frontier
Hi: joelh...Here's a pic of our outside recepticle placement. It is weatherproof and located where we set our table under the awning. Great place for the toaster as it won't upset the smoke alarm out there!!!
Old 07-12-2010, 07:36 PM   #4
Pam Garlow's Avatar
Trailer: U-Haul 1985
With the burro's double wall construction, I would think that there is enough space between the shells to run the wiring around the perimeter and then where the seam falls between the seats bring it across by using a surface mounted wire cover ? This would put you in the 'curb side' seat area, and you could mount the plug where ever you want on that side.
Old 07-12-2010, 09:08 PM   #5
Trailer: Fiber Stream
Talking
My Fiber Stream ran a rigid conduit under the floor from the street side converter/110 power cord connections to the curb side Refrigerator and Microwave outlets.
Old 07-12-2010, 09:38 PM   #6
Ian-Vicki's Avatar
Name: Ian or Vicki
Trailer: 17 ft Burro Widebody / 2007 Explorer Sport Trac
Joelh,
My plan (which I hope to do in the next couple of weeks) for our Burro is to mount the box in the channel iron that was used for the rear bumper, running tec cable from the converter to the box. This works for us because we usually set up a small table just behind the curbside wheel for out electric kettle and lights for the awning.
hope this helps
cheers
Ian
Ian-Vicki is offline   Reply With Quote
Old 07-13-2010, 03:40 AM   #7
Trailer: 1999 Burro
I was also thinking of the rear bumper. Easy access and it should be very protected.
Employee Placement Benita Jokes, Stories & Tall Tales 0 08-14-2007 07:10 PM
Burro roof a/c placement Christi W Problem Solving | Owners Helping Owners 17 02-06-2007 11:43 PM
Microwave Placement LeBoutillier Modifications, Alterations and Updates 13 04-05-2006 01:45 PM
water tank placement Legacy Posts Modifications, Alterations and Updates 2 11-11-2002 08:46 AM
Coleman Black Cat Placement Legacy Posts Problem Solving | Owners Helping Owners 5 10-30-2002 09:21 PM
