Paint! - Page 2 - Fiberglass RV
Old 03-05-2015, 03:44 PM   #15
Trailer: 1975 Trillium 1300
I'm trying to keep my costs down. I'm now thinking that this year I will polish and wax her up nice and then in a year or two possibly look at painting. The body is really not that bad... Will have to have a closer inspection though.
Lilly The Trilly - 1975 Trillium 1300
PrettylilTrilly is offline   Reply With Quote
Old 03-05-2015, 03:54 PM   #16
Jim Bennett's Avatar
Trailer: 2017 Escape 5.0 TA
As long as you stay dry inside, that is the main thing. Rebuilding these trailers can really drain the pocketbook, that's for sure.
2017 Escape 5.0 TA
2009 Escape 19 (previous)
ďMost folks are about as happy as they make up their minds to be.Ē ó Abraham Lincoln
Old 03-05-2015, 06:10 PM   #17
Ok so new paint question. Can I use house pain on the inside insulation and fiberglass?
Old 03-05-2015, 06:46 PM   #18
I only use "House Paint" (aka Interior Latex) on wood surfaces. It's primarily held in place by air pressure and may not do well on the flexible insulation.
There are a number of paints for Auto Upholstery that may work. Here is a vendor:
<<<jjautoupholstery.com>>>
Old 03-05-2015, 09:49 PM   #19
Thanks Bob for the info, the link didn't really tell me much but I gather that a vinyl paint is what I should use on the insulation fabric?
Old 03-06-2015, 06:00 AM   #20
Ian G.'s Avatar
The key to successfully repainting the interior insulation is first prep, making sure it is very clean. They use a high adhesive primer, these types of primers are often used to paint over ceramic tile, this is followed by a high quality latex paint, latex breaths so it allows any moisture that penetrates the surface to evaporate, oil based or enamel paint will trap moisture and blister.
I recommend Zinsser Bulls Eye 1-2-3 for the primer and "Rustoleum Painterís Touch" for the final coat. These are both available at local home improvement stores.
Full details on repainting the interior are documented in the Cleaning and Decorating the interior tab on my website
Proud Canadian-Cleaning & Decorating
Old 03-06-2015, 08:19 AM   #21
Vynyl/Insulation Painting
If you call Joe at J&J Auto Fabrics, and tell him what you want to paint, he will suggest the best product for the surface, including a brand name and any prep you need to do first. You can also send him a small sample for evaluation. Very good peeps at J&J...
I repainted the entire inside of a Sunrader FGRV with what he recommended and, 5 years later, it's still looking great.
A Caution..... Autosuply store vinyl/upholstery sprays aren't the same quality as what you get from a commercial supplier. Get the right stuff the first time (it will cost a bit more) and you won't have to do it again 3 years later.
paint, trillium
Interior Paint--Remove or Paint Over Lora Care and Feeding of Molded Fiberglass Trailers 7 12-15-2014 10:30 PM
Paint over resin paint? Joan of Shark Modifications, Alterations and Updates 4 08-02-2014 08:25 AM
Insulation - to paint or not to paint? Trillium.Stella Problem Solving | Owners Helping Owners 23 09-04-2012 10:46 PM
To sand and paint, to paint, or to leave it be...these are the questio JenPB Care and Feeding of Molded Fiberglass Trailers 8 12-07-2008 10:39 AM
To paint or not to paint andrew ferguson Care and Feeding of Molded Fiberglass Trailers 8 08-14-2007 07:02 PM
