Paint for Fiberglass? - Fiberglass RV
Old 05-08-2012, 12:03 AM   #1
Trailer: havasu
I'm in the process of refurbishing my Havasu and I want to paint it. The products I've found thus far that I'm considering trying are "White Knight" for the outside and an insulating paint called "Insuladd" on the inside. Has anyone tried either of these products? Any feedback you wish to share? Any other products you've had positive experiences with you care to enlighten me with? I don't think I have it in me to try and build and interior wall or glue on insulation (unless it's cheap and easy) so that's why I'm considering a paint on insulation. I'm just worried it might crack with all the movement, etc. Maybe "White Knight" on the outside AND inside? Would appreciate any thoughts/ suggestions/feedback ya'll might have for me...
Kevin
havasu is offline   Reply With Quote
Old 05-08-2012, 12:14 AM   #2
Robin G's Avatar
Trailer: 2007 Casita
Kevin, Welcome to Fiberglass, glad you joined us!
I have no experience in painting fiberglass, but have read that many recommend marine paint. Like they use to paint boats...... But I am sure other's have used most paint options. So you can do a search for other options. Just put painting fiberglass, egg, trailer, in the search box above and there should be lot's of info for you.
But if your looking for something that works with fiberglass, I would assume boat paint would
We would love to see pictures of your trailer and your reno in progress!
Old 05-08-2012, 12:22 PM   #3
Trailer: 77 Scamp 13
True marine paint is expensive, hard to work with and designed for a different environment. I don't know what folks have used but am interested as I may do some minor spot touch up on my egg.
As for wax, read this thread. Not sure how it will work over your art work but am pretty sure some of these are painted trailers.
http://www.fiberglassrv.com/forums/f...ell-43004.html
Old 05-08-2012, 04:34 PM   #4
Spanke's Avatar
Trailer: 1978 Trillium 1300
Cumberland, Indiana
Here's a thread that probably gives more if info and methods for painting fiberglass than you thought possible
Do a search, there are many more!
Painting the exterior
Welcome to the forum!
Spanke
Trilliums Rock!
Old 05-08-2012, 05:30 PM   #5
Spanke
After reading that thread I stand corrected on hard to use. I never considered rolling it on rather than spray. But I did use small rollers to paint my school bus conversion and that turned out pretty good so....
It did answer my question Enamel will work, I'm just using an eraser to put drop of paint in some chips and might do a little blended spray work on a couple of small spots for now.
But did add that thread to my bookmarks, thanks for providing.
Old 05-08-2012, 06:14 PM   #6
Wait... we have two different discussions going here. One that wants new paint on the outside and one that wants to preserve something that's already on the outside.
Be sure you are replying to the correct question. A moderator should probably split this topic...
Old 05-08-2012, 07:40 PM   #7
cpaharley2008's Avatar
I split the other post s to a new thread here
http://www.fiberglassrv.com/forums/f...tml#post306620
Old 05-08-2012, 08:09 PM   #8
Chuck says this, which is a lot like the Havasu: Professional Exterior Painting by Chuck
BTW Welcome to FiberglassRV Kevin, I kinda blew by the welcome message!
Old 05-09-2012, 06:43 AM   #9
Trailer: scamp 13
first you have to decide how you want to paint it.
are you going to paint it by hand?
are you going to spray paint it?
any good autimotive paint shop can sell you the proper paint if spraying is an option,,,same stuff they use on corvettes for example.
if you hand painting , a good marine paintjob can be had with a roller. looking almost as good as a spray job.
a good source for info on this is "good old boats" website. or magazine.
they are targeted towards rehabing old fiberglass boats... just like our goals with trailers.
Old 05-09-2012, 06:45 AM   #10
Trailer: 13 ft Boler 1986
We painted our boler four years ago with dear old "Tremclad" which has an RV White (same colour as our boler). We lightly scuffed the surface and rolled it on with a small Hi-density foam roller. It lives outside through Canadian winters, hot Ontario summers etc. and has NEVER changed or had any problems over those four years. Looks as good today as it did when we finished it.
We looked into a marine 3-part paint which was going to cost an arm and 3 legs and take me a good portion of my life-time to finish. A fiberglass body-man gave us the hint on Tremclad, so we tried it and it works really well.
Vivian L is offline   Reply With Quote
Old 05-09-2012, 08:37 AM   #11
Trailer: havasu
Tremclad
I think rolling on Tremclad is the route I'm going to take. Since we just spent crazy money remodeling the house (my back still hurts) cheap and easy sounds real good to me. I wil have to do some more investigating as to wether or not the "Insuladd" additive is worth trying or not. I gotta hurry as summer is almost here! Thanks again to everyone for welcoming me and sharing your thoughts and ideas.
Kevin
Old 05-09-2012, 08:46 AM   #12
Victor Benz's Avatar
Probably noted before, but have a look here:
Rickwrench, Alfa GTV, Falcon Squire, Corvair
and here:
moparts: paint job on a budget!?
Vic
Victor Benz is offline   Reply With Quote
Old 05-09-2012, 09:38 AM   #13
Trailer: havasu
good links!
lots of great information here! I'm ready to tackle this and cant wait to see results!
Kevin
Old 05-09-2012, 04:15 PM   #14
Kevin
Friends of ours also went the Tremclad route and were able to find colours from them very close to the original two colours of their boler. Theirs was badly faded and now it really jumps yet retains its original look. It too went through the winter stored outdoors (no tarp or anything) and held up beautifully. Good luck and enjoy the spare cash.
Vivian
paint
Paint on Fiberglass - Erased it !! barryra Problem Solving | Owners Helping Owners 1 07-07-2011 06:22 PM
Removing paint from fiberglass Angelo F. Problem Solving | Owners Helping Owners 13 09-07-2010 04:15 PM
Fiberglass paint Alan Nordskog Problem Solving | Owners Helping Owners 0 08-16-2007 08:38 PM
Fiberglass Paint etc Legacy Posts General Chat 5 08-12-2003 05:52 PM
Fiberglass, gelcoat or paint? How can I tell? Legacy Posts Problem Solving | Owners Helping Owners 2 07-12-2003 01:26 PM
» Trailer Showcase
Casita
Sheryl
Fuzzy
paulaj
