Painting Boler with Brightside marine paint - Page 2 - Fiberglass RV
Old 06-28-2013, 11:43 AM   #15
Maybe you won't have to wax it or overcoat it..... As expensive as it is, it's still seems to be the #1 choice for fiberglass boat peeps. It's what I used on my Hunter Compact-II and it's beautiful.
That said, I just painted an older tent trailer and used the (hard to find in CA) Rustoleum Marine paint and it went on about as smooth and good looking as the Brightside product @ 1/3 the cost.
I can tell you already, the Briteside is a lot harder to scratch or scuff......
BUT.... lets look at these two trailers over the next 5 years and see the aged results.
Old 06-28-2013, 06:31 PM   #16
Roy in TO's Avatar
Originally Posted by kootenaigirl View Post
We used 2 quarts of pre kote primer (1 white and I grey for the blue) had a chunk left over. Then used 3 quarts Brightside - 2 for top - hatteras off white and 1 medium blue for bottom
It looks great!
Did you do 1 or 2 coats of the pre kote primer?
I wanted to double check on the colour. The Interlux colour chart I have in front of me has 2 different brightside hatteras off whites (4208 and 4218). Both of them look more yellow or "buttery" from what I see in your pictures. Yet the tire cover and tank look like the whites I would expect them to be. The blues (4353)are also very close comparing the picture to the chart. Any chance you used the Off-White (4381)?
Given your descriptive review, I think I'll do some practice runs using the gravel guard then door before attempting my trailer. If I'm only doing the top, door and gravel guard on mine, it appears that I only need 1 quart of primer and 2 quarts of the white. Is that correct?
Old 06-28-2013, 07:22 PM   #17
Trailer: 2010 Escape 17B
Hi Roy
We used 1 coat of primer, it is really thick and covers well.
Used the hatteras 4218, I thought it would be more of buttery colour too so maybe try the other one.
Yes, your quantities sound good.
Try and avoid hot days with direct sun as I think that was part of our problem.
Good luck I will be looking forward to your pictures.
kootenaigirl is offline   Reply With Quote
Old 06-29-2013, 07:14 AM   #18
Roy in TO's Avatar
Thanks kootenaigirl,
It may be a while. I'll have to finish replacing the wooden mezzanine with warehouse racking in the garage. Then enlarge the garage door before I can fit the trailer into the garage to paint. I'm planning on the Brightside Off-White 4381. I'll definately post pictures here: Restoring Our 1972 Boler American.
Old 06-29-2013, 07:21 AM   #19
GMike A's Avatar
Originally Posted by frank_a View Post
Problem with Brightsides is ya better not try polishing it or waxing it, it loses its shine! Been there, done that. Plus ya can't overcoat it with anything!
Frank
What would you consider an alternative that would allow it to be shined and waxed or coated? Brightside is an investment and may have to consider an alternative. I know I know but I have seen some who use Rustoleum.
Donna is there a thread on finding the "perfect" paint? (I have excluded having it professionally gel-coated as a cost factor?)
thanks
Mike
K5NAN
"Miss Adventures"
If you Rest, You Rust
Old 06-29-2013, 07:42 AM   #20
Don't Raise the Bridge, Lower the River
Rather that go to the work and expense of raising your garage door, consider using much smaller rims/tires while parked. Some on here have gone as small as using bare 8" rims to roll their egg in & out of a garage.
How much more clearance do you need?
BTW: I painted my Hunter outside, using Briteside White.
Old 06-29-2013, 08:06 AM   #21
Roy in TO's Avatar
Good suggestion Bob, but not feasible in my situation. The single car length driveway to the garage slopes down from a 4 lane major city artery.
As for expense - the existing wooden mezzanine was poorly built and needs replacing as it is starting to collapse. The garage door is on it's last legs. If I have to replace those already it is not that much more to go from a 7' high to 8' door. Bonus is I won't have to pay for offsite storage and it gives me a place to work on the trailer out of the elements. Plus I won't have to swap tires/rims twice on a hill every time we use the trailer.
Do you have pictures posted of your Hunter painted?
Old 11-27-2017, 01:23 PM   #22
Trailer: Boler 1300
BC
Is theis "bikini Blue" color?
adammarktodd is offline   Reply With Quote
Old 11-27-2017, 01:39 PM   #23
It was called medium blue.
Old 11-27-2017, 01:53 PM   #24
frank_a's Avatar
Trailer: 2012 ParkLiner #006
I really don't know about single stage paint. Two part automotive paints (base coat/clear coat) are easy to polish, and done right, can really gleam!
Another tip for a really well covering primer (if you have a compressor and spray gun set-up) is polyester primer. You could tape a quarter to your trailer and bury it with this stuff. I'm using it this coming spring on a hot rod body I bought that needs major help. I'll prime it, then block sand it to get it smooth and straight.
Frank
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
frank_a is online now   Reply With Quote
Old 01-03-2018, 07:55 AM   #25
Saskatchewan
I am considering using the Rust-Oleum product do you have any pics
Tacoman7 is offline   Reply With Quote
boler, paint, painting
Painting the boler. How much paint? colin k Modifications, Alterations and Updates 15 05-18-2018 10:16 AM
Interlux Brightside Before and After lespnd Modifications, Alterations and Updates 13 10-05-2012 06:48 PM
Painting Mural, What Paint? Emily R. Problem Solving | Owners Helping Owners 7 01-24-2011 09:39 PM
Some Advice for Painting with Interlux Brightside Janine Problem Solving | Owners Helping Owners 2 08-04-2007 06:23 AM
ICI DEVOE or INTERLUX BRIGHTSIDE Paint for Boler? Suzanne P. Care and Feeding of Molded Fiberglass Trailers 16 07-13-2007 04:39 PM
