Painting the outer shell - the frugal way...? - Fiberglass RV
Old 04-21-2011, 08:12 PM   #1
Andrew GPSMapNut's Avatar
Trailer: Modified Trillium Jubilee
My Jubilee is slowly getting into shape.
See http://www.fiberglassrv.com/forums/f...hat-44761.html
The plugs for the new window is in. It's getting near the point of being prepped for the painting of the shell.
Call me cheap or frugal or whatever you want but, pro paint job just isn't in the budget. Still, we want it to look decent when we are done with it and we want the colour to match out TV - kind of old silver.
At the moment, the plan is to paint it with a roller. I was quoted $50 (Canadian) per litre (quart) of "good for fiberglass as well" automotive paint = some activator. Supposedly, I don't need a primer coat(?) From some other posts here, I figure (=hope) that I can do it with 2-3 litres but when I said that I want to paint with a roller, the guy behind the counter made VERY big eyes and just said something like "I guess it's possible..."
Aha, since you all like pictures and to give you an idea of the current "colour" of the Jubilee, I'm attaching a pix of the window plug in.
I appreciate any advice re painting with a roller or other simple means, source and type of paint I should use and any other idea. Keep in mid that I am in Mississauga, ON, Canada and the source needs to be local. I'm also cheap so... Well, you get the picture
I wish to be one day at least half as good as I think I am today. Andrew Kalinowski
Andrew GPSMapNut is offline   Reply With Quote
Old 04-21-2011, 08:39 PM   #2
Trailer: 1971 Amerigo
You can achieve excellent results by using the Roll and Tip method using paint formulated for fiberglass boats.
Everything you need to know can be found here
Restoration - fiberglassics.com
These tutorials were written by a professional and are both comprehensive and easy to follow.
Yes the paint isn't $5 per gallon - but for a reasonable expenditure you can come with a very good result and after all the prep work you do to make ready for paint it's a shame not to have a good looking finished product.
Peter_Crowl is offline   Reply With Quote
Old 04-21-2011, 08:53 PM   #3
Thanks. Roll and tip looks a bit scary for automotive type of paint - I was told that it sets (cures) quickly and I am a bit concerned of, how much of the paint will I waste before I master the technique... I did talk to couple boat places and the prices for marine type paints are... well, just for the cost of the paint, I could have the whole job done for by a car body shop!!! I guess, I'm looking for an impossible - an idiot proof and cheap way to do first class job...
Old 04-21-2011, 08:53 PM   #4
Talking
I have a photo of a 13' Burro that was painted with a roller. The person who painted it doesn't own that particular trailer now and she is presently traveling so I'll share what I remember...
ID:	35185 Click image for larger version
If you want a smooth automobile-like finish: pass on the roller, spraying is the only way to get that quality IMHO.
A roller will leave a texture in the paint, and the result on this trailer made a child exclaim, "It looks just like an Igloo Cooler!" That kid nailed it.
Old 04-21-2011, 09:02 PM   #5
South Carolina
If you have an air compressor you can get tractor paint from Tractor Supply Company for around $30 per gallon and end up with a pretty nice paint job.I painted my VW Thing with it and it turned out real nice.It came out to $49.83 with the hardener and reducer.Here are a couple pictures of the finished product.
Brian Bran is offline   Reply With Quote
Old 04-21-2011, 09:04 PM   #6
Greg H's Avatar
Trailer: 72 Boler American
Indiana
You can get pretty smooth with the weenie rollers. I painted a food concession trailer that way a few years ago. Maybe even better if you let it cure then go back and wet sand it even smoother and then clear coat it.
Old 04-21-2011, 09:25 PM   #7
Frederic,
"Looks just like Igloo..." Love the line! and kind of hope that mine will look at least as good Thou, somebody here had a better luck with a roller ref. http://www.fiberglassrv.com/forums/f...ior-26260.html
Brian,
I don't think that the Tractor Supply Company has any Canadian presence.
All;
I have air and paint guns and a painter. The trouble is, the trailer is way too big too fit in our paint booth area and I hate the thought of having overspray all over the are where I'm working on it. I really can't safely seal it off. I'm lucky enough to have my boss brake the company rules and let me have the trailer at my workplace. I don't want to push my luck. Actually, my luck I could push but some things may make people look at it them very differently especially that, after all, I am a VP in our company so, I should lead by example and a good one to that. Yes, I know, I'm weird...
Old 04-21-2011, 10:39 PM   #8
DannyH's Avatar
Trailer: 1976 Scamp 13 ft
Andrew, here is a link to when I painted mine http://www.fiberglassrv.com/forums/f...ler-42870.html
I did the roll and tip method and I'm happy with the results. I just did a wax job on it to make cleaning up the bugs easier, and found 4 to 5 small runs in it. Most people that have seen it don't notice them, but if you want a perfect paint job, I would spray. Like the link says, I had about $250 in paint and supplies, but at least I know how to touch up the paint in the future. I ended up with three layers of primer to cover up the glass work I did, so I'm not sure if you can get a good coverage with 2 to 3 coats of what your using for paint. I went with Pettit paint because I was doing it by myself and wanted time to tip the paint (get the bubbles out). The other types would have dried way to fast and there was no way to roll out the paint and not get air bubbles in it, I tried.
Keep us posted on your progress.
Dan
DannyH is offline   Reply With Quote
Old 04-25-2011, 10:47 AM   #9
Roy in TO's Avatar
Brian,
All;
Tractor Supply Company = TSC stores up here.
TSC Stores
If you have a spray booth, can you build a cheap temporary extension to it? That way you can use the air flow / filtration of the booth. I'm thinking of some drop sheets, plastic (vapour barrier) and a frame like I used for my winter cover.
http://www.fiberglassrv.com/forums/f...tml#post135840
Alternatively, given your location, I know there are marina's nearby. Most the cost of painting is the prep work. Have you priced out just a spray job at a Marina? They are familiar with the materials. If not, how about a body shop that works on big trucks. There should be something close to you.
Old 04-25-2011, 12:29 PM   #10
TSC Stores
Aha. Thanks.
Unfortunately, no room for that.
Alternatively, given your location, I know there are marina's nearby. Most the cost of painting is the prep work. Have you priced out just a spray job at a Marina? They are familiar with the materials. If not, how about a body shop that works on big trucks. There should be something close to you .
Port Credit marina... absolutely nothing is cheap there. I am going to check a body shop that is close to my work. I was told that they do have reasonable pricing so, maybe they will do the paint job.
I tried some roll and tip. I'm just not any good at it. I will have to find a way to spray paint it.
Old 04-25-2011, 12:52 PM   #11
james kent's Avatar
Trailer: Boler 1984
I painted mine with a roller and it still looks great. I painted the top crown first and was able to lean on the roof from a step ladder to reach the centre. Then painted the sides of the roof to the edge where it starts to curve down. Finally I painted the sides to the belly band and then the lower parts. Where I rolled the paint fully out it is as shiny as if I had sprayed it. The rest had some small runs. A touch of thinners, a light coat and more rolling would have been even better. The marine paint has a tendency to sag just a bit so that it eliminates the roller marks. Finally a gentle wisking with a dry brush removes any bubbles raised by the roller.
Old 04-28-2011, 08:38 PM   #12
How about a $50 paint job using Rustoleum?
Paint Your Car With Rustoleum
Here's another: http://www.rickwrench.com/index79mas...llarpaint.html
Old 04-28-2011, 09:17 PM   #13
You can do really good work with Krylon / Rust Oleum spray cans.
Back in my Scooter days at the annual Vespa Club rallies we had a Krylon King award for the best rattle can paint job and there were some amazing entries.
I'd be sure to research the veracity of those paints on Fiberglass. Perhaps with the right primer...but really, you'll spend as much on them as proper shell paint when all is said and done.
Considering all the prep work it takes to achieve a good result, the cost of paint is really a negligible expense...IMO.
EDIT: Just read the FA. Note that they strongly recommend a proper epoxy clear coat. Considering that Fiberglass flexes a lot more than sheet metal I have to believe Rust Oleum would not be a good choice for a camper - if you want the finish to last.
JMO
Old 04-28-2011, 10:30 PM   #14
You also could use a product called liquid mask
Take all the stuff you can't wash out
Spry the liquid mask an everything else
Spray and when your done rinse it all off with water
Siris is offline   Reply With Quote
Old 04-29-2011, 10:17 AM   #15
Trailer: Scamp 19
Use good Paint
Having been in the marine industry for many years and painting boats, let me add that if you use good paint Awl-Grip or Sterling, or some other product like that you will not only get a good job, but something that will last a number of years.
I wouldn't short cut on the primer. Looking at your pictures, it looks like you have light and dark spots on the trailer, and they will show up, light and dark in your final paint job. A good primer will make the base all one color, and the finished paint job-all one color
Another way to do the job is to find someone who paints boats or cars professional, and have them just do the spray painting part of the work. Prep work in the very time consuming and the most expensive part of any paint job, and something that you can do yourself. Do all the taping and masking yourself and have the professional just do the painting.
Give a thought to what you want the finished product to look like
captsteve2002 is offline   Reply With Quote
Old 04-29-2011, 10:34 AM   #16
Actually, after getting some quotes from local pain-shops, I'm seriously considering just rolling on Aluminium Tremclad. In fact, I have first coat on a test panel. Single coat doesn't look that great. Than, when I think of the quoted prices, I think that 3-4 coats topped of with Wet-Look Zep, will look just great.
Old 04-29-2011, 12:20 PM   #17
As long as you don't have a concern about eventual resale value it doesn't matter what you do.
Old 04-29-2011, 07:42 PM   #18
Originally Posted by captsteve2002 View Post
>>>snip>>>
Thanks a lot for all the comments and advice.
I though about it for months. The reality, as I see it is;
1. I want a practical trailer for my lady and me.
2. I have limited budget to do it.
3. I would like it to look perfect but, see #2
4. Selling it is not in the cards but,
5. If we ever want to sell it, we will get (more than likely) at least what we paid for it - the labour.
6. Most of the year, it will be sitting on a friends farm serving as a occasional weekend sleeper.
What is the worst that can happen if I go the "perfect" route?
1. I can put into it a lot of work and not have it usable before July which would force us to make the planned trip to Tadoussac with a borrowed trailer.
2. I may not get energy or patience or the money to do it perfectly.
3. Somebody will steal it.
4. My lady and I will be telling each other that we should've done it differently.
What is the best that can happen if I go the "perfect" route?
1. My lady and I will be complementing each other on the perfect job we have done with it.
2. I get good re-sale value.
3. People will be doing "wow" looking at it.
What is the worst that can happen if I cut corners on finishing?
1. My lady and I will be telling each other that we should've done it differently.
2. People will be telling us that our trailer is ugly.
3. We may get kicked out of an FGR rally or not allowed to a perfect RV resort.
4. Nobody will want to buy it when we decide to sell it.
5. Somebody will comment: "have you done it in your driveway at night?"
What is the best that can happen if I cut corners on finishing?
1. We will be able to have a perfectly usable trailer for our summer vacation.
2. Somebody will comment: "looks cheap but solid and it looks like all you need for very enjoyable camping."
3. My lady and I will be telling each other that it turned out fairly decent considering the expenditure.
Fill free to add to my list but, we are going for the last option = reliable, usable, fun and inexpensive.
In summary; unless somebody donates their time, place, equipment and skills to do it better, Tremclad and a paint roller it will be!
Old 04-29-2011, 07:47 PM   #19
Greg H's Avatar
Indiana
As long as you're happy who cares what anybody says, go for it.
Old 04-29-2011, 08:00 PM   #20
Perfect answer Greg!
painting
17' Casita on Outer Banks Chesley Sugg Classified Archives 2 11-16-2010 11:44 AM
Need Help Painting Shell!! harold f Problem Solving | Owners Helping Owners 18 07-22-2010 07:46 PM
Empty Shell Stoney General Chat 9 10-07-2009 05:37 AM
Empty Shell Help Heather V. Care and Feeding of Molded Fiberglass Trailers 8 09-07-2007 05:57 AM
What would you put in a 13 ft. shell? Kent I Care and Feeding of Molded Fiberglass Trailers 8 09-02-2007 01:38 AM
