Parkliner Awning-on a lighter note - Page 3 - Fiberglass RV
Old 05-26-2013, 08:14 PM   #29
Trailer: 2014 Escape 21
Virginia
Jim
The GM canopy is 12 ft. which fits the 12' body of the 15 ft. Parkliner. I have used 10ft. canopy's on Scamp 13's since they have 10 ft. bodies. Not saying the GM 12' canopy won't work, just giving you something to think about.
Eddie
Old 05-28-2013, 09:42 PM   #30
Trailer: Scamp 13 & TDI tugboat
Ohio
Good point Eddie. It definitely fits different on the shorter Scamp box.
At first I tried it without the 2 legs but it awkwardly wrapped too far down around the ends of the hull. Then I realized the leg holes were right at the end of the hull, so the legs were stuck in their respective grommets. That seemed to work well with the legs right on either end of the hull and the edge of the fly running along the roof. The adjustable tiedowns were hooked to the rear bumper and front tongue, and the outer 2 poles were staked down with the adjustable tiedown ropes.
It's a decent unit for ~$50, but don't pay much more than that.
And somehow the 2 pics of the erected fly got lost between the camera and the computer.
Oh well, here's a pic of the tent pole, bright orange guy lines and newly mounted rear jacks.
FJ40Jim is offline   Reply With Quote
Old 05-29-2013, 07:18 AM   #31
KevinPete's Avatar
Trailer: 1995 Scamp 13
Any rubbing on the fiberglass?
KevinPete is offline   Reply With Quote
Old 05-29-2013, 07:27 AM   #32
deryk's Avatar
New Jersey
Since Im attaching mine pretty similarly, I havent seen any and Im looking. If it does, either pool noodles or fake lambswool will go against the fiberglass. If I remember right, the ParkLiner is 12'long, but a lil less at the top, I think its around 11'6", so Im useing 2 joined 6' poles through a sleeve at the top, so its not right against the fiberglass...might be a good idea.
deryk
Old 05-29-2013, 10:21 AM   #33
carlkeigley's Avatar
NE Oklahoma
Originally Posted by Tim Wood View Post
I found a couple dining canopies similar at K-Mart on sale.
Got them both for $37.50 each. I have awnings, but thought
these would be a good addition at times. And they don't
weigh near as much as those easy-up types.
Old 05-30-2013, 03:07 PM   #34
rabbit's Avatar
Trailer: '98 BURRO 17WB
Delaware
Variation on the theme. Thanks PL owners and Eddie L. 49$ shipped from Gander Mtn. Fits very nicely on the Burro. I put two of the dumbell suction cup lifters from Horrible Fright (6$ ea.) on the flat of the trolley top, drilled a hole in each for the hook and bungee which normally would attach to the D-ring at the top of the canopy pole. The two corner guys front and rear run to bumper and tongue. I began with the idea that I would run polyprop line thru the hollow handles of the dumbell lifters (I planned to use four spaced evenly along the trolley top) which would act (with grommets and plastic snap shackles on the one canopy edge) as a sort of halyard or outhaul which could be operated from the ground. While mocking this up for the first time, I discovered that one suction cup each end would do the job and decided not to make it more complicated than need be. I can attach the suction cups and hook the canopy from the 2' step stool shown but a 3 or 4 footer would be handier. I hope this works as well as cinching the edge below the reverse trolley pontoon of the ParkLiner? I had no trouble erecting by myself. The tension bows make the canopy rigid enuf to stand with only one outbd. leg inserted so it's not one of those "need three hands, teeth to make knots, tail to swish flies" operations. With one side of the 11'-6" canopy on the edge of the trolley top, canopy projects from the trailer side 8'-3"; about the same projection as a conventional canopy.
Thunderstorm forecast for late this afternoon so I will find out if I have a canopy or a kite. I will have to develop a drill to take off sail in a hurry! Incidentally, there is no nylon patch tape included with the GM canopy and the stakes are absolutely worthless. I like the size and wgt. of the carry bag (5'x6"x28") when packed and there's room for my foot long steel angle stakes and patch tape but the suction lifters will have to pack separately.
I have a steel-frame EZ-up type canopy with a big weight penalty, big footprint packed, and a PIB to set up for only one nite. For the expense (about 62$ with the suction cup lifters), I like what I see so far.
Old 05-30-2013, 04:07 PM   #35
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
Do the suction cups from HF hold for long periods..i.e. days?
Old 05-30-2013, 05:09 PM   #36
Brian M. in NY's Avatar
Trailer: 2013 ParkLiner
Upstate New York
Mine just arrived this afternoon. Haven't had a chance to unpack yet but thanks for the heads up on the stakes. I was planning on packing my heavy duty ones and you've confirmed my suspicions. They will definitely go in the case! I plan to go with bungees, at first, on the ParkLiner but am toying with the idea of cutting the hooks off a set of ratchet straps and stitching them on to the corners on the trailer side.
Brian M.
Always remember you're unique, just like everyone else.
Brian M. in NY is offline   Reply With Quote
Old 05-30-2013, 06:06 PM   #37
rabbit's Avatar
Delaware
Tom, I've got four of the dumbbell lifters. I bought them Monday after ordering the FM canopy Sunday and they've been up there since Monday. I have one of the four that isn't trustworthy and loses vacuum on one cup. They are very sensitive to convexity in the surface; need a flat for one cup and a still larger flat plane for the dumbbells. Got the receipt so the bad one going back.
My thunderstorm went north of us but I got a little wind. Altho gusty, wasn't strong enuf to produce much distortion or pull the suction cups free. One of the criticisms of these things is that they aren't strong in resistance to sheer. I think mine are aftually pretty good in sheer as I haven't pulled one loose yet pulling at a right angle to the cups. I'm going to try this rig out at Assateague on the Accomac Peninsula mid-month; should be sustained wind there. Let you know.
jack
Old 05-30-2013, 06:20 PM   #38
Thomas G.'s Avatar
jack
Thanks. I was actually thinking of using a pair to augment my roof rack. The roof rack is biased to the rear of the vehicle and when the canoe is on with the trailer, I need to keep it way forward to clear the trailer. So, a pair of these just behind the windshield would add a lot of stabilization to the front of the canoe....if they hold a suction.......
Old 05-30-2013, 07:18 PM   #39
rabbit's Avatar
Delaware
Tom, you're the automotive engineer so you'll know if my answer indicates my head residing in dark place. I have the feeling from having put these suckers on different areas of the Burro that convexity of surface ain't good. There are special suction cups made for curved surfaces. They're very expensive. Mine work very well on a 9' long section of the trolley top.
I know enuf about mold making at the "bootstrap" level to realize that if a big flat plane is acceptable, most people will utilize sheet material in the plug and minimize station framing to achieve a fair appearance. On the flip side is that Ford Contour of a few yrs. back. Supposedly the sheet metal had more to do with the possibilities of computer design than with sculpted clay. Was there a definable flat 5" in diameter anywhere on that car. My guess is that you'll be hunting for a flat spot on the roof of your Escape so might not be a workable idea. I should try sticking them on the 4runner, particularly in the area fwd of the roof rack. The old way with canoes, however badly the rack was located, was to haul the canoe down bow eyes to bumpers both ends.
jack
Old 05-30-2013, 07:29 PM   #40
Actually, you do not want to tie off your canoe at extreme bow and stern.
If you do, it looks like this: /-----/
As you can see, that prevents the canoe from going backwards, but there is nothing to prevent it from going forward ( as in a panic stop ).
Need to tie like this: /----\--
I tie at the rear, to one of the thwarts, not to the stern.
Old 05-30-2013, 07:48 PM   #41
Mimi Lee's Avatar
Trailer: Parkliner
My order arrived today, too. Thanks all for the posts on your variations of setup as it's giving us some ideas on the different ways it can be setup, and looking at ordering some similar suction cups tonight.
Mimi Lee is offline   Reply With Quote
Old 05-30-2013, 07:54 PM   #42
rabbit's Avatar
Delaware
Depends on length of canoe; length of vehicle. Never had the problem Baglo describes whatever the lead to the bumper, possibly due to straps side to side which could be cinched up real good.
jack
parkliner
ParkLiner Awning deryk Modifications, Alterations and Updates 22 05-15-2013 10:56 AM
spark lighter Terry R. General Chat 3 06-14-2011 08:11 PM
Lighter Trillium? Linda D Care and Feeding of Molded Fiberglass Trailers 21 02-17-2010 09:08 AM
Lighter than air TT Alistair Camelford General Chat 10 12-05-2006 03:59 AM
Lighter problem Legacy Posts Jokes, Stories & Tall Tales 4 12-13-2002 04:24 PM
