ParkLiner - leveling jacks to replace stabilizers? - Fiberglass RV
Old 07-09-2014, 08:53 AM   #1
frank_a's Avatar
Trailer: 2012 ParkLiner #006
Have any of you ParkLiner owners installed leveling jacks to replace the stabilizers in the back? I have a pair of these left over from the last trailer rebuild, and was thinking of installing them.
My basic concern is that they're heavy and I would be using four stainless self drill screws per side. The screws I would use are size 14 X 1-1/2". I would NOT want the jacks coming off as we drove down the road!
I'm pretty sure the relatively lightweight stabilizers on 006 now are held on by two self drill screws.
What do you think?
Frank
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
Old 07-09-2014, 09:01 AM   #2
cpaharley2008's Avatar
Over kill….
Jim
Never in doubt, often wrong
Old 07-09-2014, 09:03 AM   #3
frank_a's Avatar
I had them on our Sunline Sunspot, even smaller and lighter than the ParkLiner. Thing is you can't find lighter ones in this style.
Frank
2012 ParkLiner #006
Old 07-09-2014, 09:07 AM   #4
Frank, those appear to be more like scissors jacks, do you not want stabilizers?
Jim
Old 07-09-2014, 09:08 AM   #5
frank_a's Avatar
What good are stabilizers? I want to level the trailer when I'm parked. I don't understand what good stabilizers are for leveling a trailer. Never had stabilizers before, always scissor jacks. It's what I see on most other trailer when we camp.
Frank
2012 ParkLiner #006
Old 07-09-2014, 09:12 AM   #6
Most trailer frames are not meant to be jacked except only at certain locations, normally close to the axles. Stabilizers secure your trailer from movement. Your tongue jack is used to raise and lower the trailer, to level it. it is designed for that purpose. Jacking up a light trailer at each corner could cause some major frame flexing and possible fiberglass cracking, it is better to only jack from the front.
Jim
Old 07-09-2014, 09:14 AM   #7
There is also the B@l tire leveler, works great on single axles units.
Jim
Old 07-09-2014, 09:16 AM   #8
frank_a's Avatar
That doesn't deal with side-to-side leveling though, which was our problem at the last campground. So should I get bottle jacks for that and jack at the axles? Then I have to store the jacks. The scissor jacks only work well when attached to the frame.
Thanks,
Frank
2012 ParkLiner #006
Old 07-09-2014, 09:21 AM   #9
Again, side to side leveling should be done at the axle with leveling blocks or the B@l leveler, jacking the frame at the end points on one side only may cause frame issues. YMMV
Jim
Old 07-09-2014, 09:23 AM   #10
Frank
I have read in other threads that the lightweight frames on the eggs aren't strong enough to lift the whole trailer from a single point (or even 4 points). Since you would have to raise one corner at a time, I suspect the twisting could damage the frame. Stabilizers are just that - they keep the trailer from shaking after it has been leveled using leveling blocks under the wheels. Most of the weight remains on the suspension and stresses are distributed evenly throughout the whole frame.
Old 07-09-2014, 11:07 AM   #11
Trailer: 13' Scamp
Tire leveler
Works great. Super easy to setup and level. Only draw back is its size. I bought this and immediately threw away the stupid plastic blocks I had purchased. I agree that stabilizers are pretty useless. I took them off of my 13' Scamp.
Amazon.com: BAL R.V. Products Group 28050 Light Trailer Tire Leveler: Sports & Outdoors
KevinScamps is offline   Reply With Quote
Old 07-09-2014, 11:16 AM   #12
frank_a's Avatar
Do you use their tire chock with it?
Thanks,
Frank
2012 ParkLiner #006
Old 07-09-2014, 11:24 AM   #13
Trailer: 13' Scamp
Tire chock
no idea what their tire chock is, so I guess not. The jack chocks the tire front and back so it is not going to roll anywhere. I will chock the other tire if I am on a particularly slanting site, otherwise not necessary. In theory on a hard surface it could slide I suppose, but it has a lot of weight on it, so it would take a LOT of effort to do so... maybe if you were camping on a frozen lake.... but then a chock wouldn't do much either
Old 07-09-2014, 11:26 AM   #14
frank_a's Avatar
The chock come up under "Frequently bought together" when I went to that Amazon link. Thanks, we'll have to get one of those. Great idea!
fRANK
2012 ParkLiner #006
parkliner
Scamp rear leveling Jacks length? Roger Harshaw Towing, Hitching, Axles and Running Gear 2 04-20-2009 02:23 PM
leveling jacks and storage jacks Ricky 4 Problem Solving | Owners Helping Owners 1 07-28-2008 10:29 AM
BAL Leveler, Stabilizers and Jacks Greg Conly Care and Feeding of Molded Fiberglass Trailers 29 04-06-2008 09:26 AM
Oliver self leveling jacks? Ken C General Chat 5 12-05-2007 01:31 PM
BAL Leveling Scissor Jacks Adrian W Modifications, Alterations and Updates 5 12-30-2006 07:55 PM
