ParkLiner - remote battery posts - Fiberglass RV
Old 07-31-2014, 04:36 PM   #1
frank_a's Avatar
Trailer: 2012 ParkLiner #006
ParkLiner has this new elegant tongue mounted battery box. The only problem is you have to remove the propane tanks to get to the top of the battery box, then you have to remove the difficult-to-remove screws they use to hold the top down, and then you can get to the batteries! Hmm.
I already re-positioned the top (they mounted it crooked at the factory!) then drilled and tapped 5/16-24 holes to make it easy to attach and remove. But I was concerned with the difficulty of getting to the batteries, so did something many hot rodders do - installed remote battery posts. These can be used for my trickle charger to keep the batteries topped off during the winter, but could also be used with a solar panel, or electric tongue jack, just with alligator clips. Easy, and no wrestling with propane tanks and all to do it.
I had some scrap aluminum angle around, drilled the 1-1/4" holes needed to mount the battery posts with a cheap step drill bit from Harbor Freight, and mounted it with the same self-tapping screws ParkLiner uses for all their frame-mounted stuff.
I still need to liquid-electric-tape all my connections, but will do that Saturday when I do all the other unprotected crimp connections under the trailer. It is amazing to me that ParkLiner (namely Chandler) doesn't seem to think these under carriage crimped connections need protection. I disagree.
Here's some pics...
2012 ParkLiner #006
2013 4wd Escape 2L Ecoboost with 3500# tow package
Old 07-31-2014, 04:39 PM   #2
Borrego Dave's Avatar
Trailer: Casita SD17 2006
Nice and clean Frank
Old 07-31-2014, 05:10 PM   #3
frank_a's Avatar
Thanks Dave. Nothing is tight yet, except the original battery post nuts, and I still need to clean up that mount - I can see pencil lines! Now all I need is an electric tongue jack and solar collector. Actually I went through this so I don't have to bring the batteries in this winter. I can trickle charge them in place.
Frank
2012 ParkLiner #006
Old 07-31-2014, 05:15 PM   #4
I would bring the batteries in where it's warm. I only leave batteries in equipment that I'll need to use in cold weather, like tractors.
Old 07-31-2014, 05:25 PM   #5
deryk's Avatar
New Jersey
with my solar panel keeping a charge on my batteries they should be ok installed right? If we get a decent weekend Im not opposed to an impromptu camping weekend in January lol.
Looks good Frank! Maybe some kind of lockable box over those remote terminals?
deryk
Old 07-31-2014, 05:39 PM   #6
frank_a's Avatar
That's what I think. If they're on a trickle charge, why move them? They're a bear to get to!
What kinda lockable box Deryk? Gotta think about that one.
Thanks!
Frank
2012 ParkLiner #006
Old 07-31-2014, 05:53 PM   #7
deryk's Avatar
New Jersey
Just something so folks don't mess with it and protected from the elements.
deryk
Old 07-31-2014, 07:17 PM   #8
Trailer: ParkLiner
Virginia
What gauge wire did you use and did you use an inline fuse? If yes, how many amps?
Huck is offline   Reply With Quote
Old 07-31-2014, 07:53 PM   #9
mszabo's Avatar
Trailer: 1986 Bigfoot FT20
Frank, checkout Bottomdollar for a jack. They have them all the time starting at $45
12 Volt Black Power Jack Model 18179 | eBay
Old 07-31-2014, 07:59 PM   #10
frank_a's Avatar
10 gauge was all I had at home Huck, so that's what I used. I did not use an in-line fuse. That's probably a good idea. What would you think? I would want something that would work with a 100 amp solar panel.
Thanks,
Frank
2012 ParkLiner #006
Old 07-31-2014, 08:40 PM   #11
deryk's Avatar
New Jersey
heh... 100 Watt Solar Panel
deryk
battery, parkliner
A/C Universal Remote Control Ruth C. General Chat 0 07-11-2011 07:34 PM
Two Remote Campgrounds in CA Lisa M. Camping, Campout Reports 4 06-30-2009 11:42 PM
"View New Posts": can I exclude For Sale posts? E. Graham Forum Admin, News & Announcements 4 07-20-2008 11:59 AM
Remote Control Todd Sleeman Modifications, Alterations and Updates 4 05-08-2008 08:28 PM
RV Remote Control Trailer Parking Machine Bob H Modifications, Alterations and Updates 6 02-17-2008 06:09 PM
