plastic plywood - Fiberglass RV
Old 03-18-2012, 07:53 PM   #1
Trailer: 17 boler
plastic plywood
has anybody ever used plastic plywood to resheet the floor?
its about 30% heavier but will never rot, any thoughts?
Home
andrew
andrew78 is offline   Reply With Quote
Old 03-18-2012, 08:33 PM   #2
Reid Larsen's Avatar
Trailer: 1979 Trillium 4500
30% heavier and wimblywambly-needs more support not to sag. Too many rv manufacturers use OSB which is worse than plywood for decomposing and supporting loads, I would lean towards a good quality exterior ply or marine grade or even pressure treated if you can find it and are worried about it coming apart. Seal every thing real well and w/ no leaks you shouldn't have to worry.IMHO
Reid Larsen is offline   Reply With Quote
Old 03-19-2012, 06:06 AM   #3
Trailer:
As it's recycled, that probably means limited control over which plastics go into it - and some, like polypropylene, can be almost impossible to get a good bond to, so preventing the floor from being laminated into place.
Old 03-19-2012, 11:01 AM   #4
Mike Magee's Avatar
Trailer: Li'l Hauley
Chalet has been using something like that on their A-frame popup trailers for close to a decade now, I believe. I wish more manufacturers would use a no-rot subfloor material, it seems like it would save some problems later on.
How to prepare Tofu
Step 2: grill some meat
Old 03-19-2012, 11:55 AM   #5
I would use (Min 3/4 inch) pressure treated ply, coat the bottom side with truckbed coating and put linoleum on the top side to keep the treated material away from the occupants.
Old 03-19-2012, 01:34 PM   #6
Trailer: 17 boler
thanks for the reply, i alway appreciate the input
Old 03-19-2012, 01:45 PM   #7
Thomas G.'s Avatar
Trailer: For Sale Or Rent
Rooms to Let 50 Cents
My UHaul has a plywood floor with fiberglass laminated to top and bottom. Lot of work, but no rotten spots after 27 years.
Old 03-19-2012, 02:29 PM   #8
There is also a rot-proof, lightweight product which will also take a lot of weight out your wallet! It is the aluminum honeycomb materials used for floors in commercial aircraft.
Before Boeing closed their (open to the public) surplus store in the Seattle area, I used to get sheets of it there for strong, light, well-insulated floors in hotrods. The open spaces in the honeycomb was filled with an insulating foam of some sort. Incredibly rigid, very strong ultra light, and both heat and sound insulating.
May be available elsewhere on the web?
Old 03-20-2012, 10:00 AM   #9
Trailer: Casita 17 ft Liberty Deluxe
We Washingtonians have always referred to Boeing Surplus as Fantasyland! We all miss it.
Mike Price is offline   Reply With Quote
Old 03-20-2012, 09:31 PM   #10
Trailer: Casita 17'SD
Look for a product called Starboard. We use it for hatch covers on the fish boats. Plenty stong. Easy to cut or rout.
LK Gray is offline   Reply With Quote
How do I paint Oak Plywood? Vickie B. Problem Solving | Owners Helping Owners 8 02-07-2012 01:11 PM
Plywood floor - what do I look for? Melanie Problem Solving | Owners Helping Owners 6 07-03-2011 08:38 AM
Plywood screen doors? Russell A Modifications, Alterations and Updates 20 01-01-2011 12:39 PM
Total plywood replacement? brady hansen Problem Solving | Owners Helping Owners 27 03-13-2008 09:13 PM
plywood edging Peggy Problem Solving | Owners Helping Owners 8 07-09-2007 01:04 PM
