Pleez help me find a post - Fiberglass RV
Old 09-01-2010, 10:46 AM   #1
Vickie B.'s Avatar
Trailer: 1988 Perris Pacer ('Bean') / 2015 Ford F-150, 2017 Winnebago UltraLite 27BHSS
Nebraska
Several days Kevin K. posted a really neat idea about extending the front bunk to make it wider. The next day (or so) another post showed up with a similar set up using 4 legs to hold up the extension (rather than pvc pipe.) I cannot find that second post! I can't remember who the poster was or anything.
Just remember the plywood extension to the front bunk, and the 4 legs holding it up.
Thanks for your help!
Vickie B. is offline   Reply With Quote
Old 09-01-2010, 11:13 AM   #2
Kevin K's Avatar
Trailer: 17' Casita
Mpls,Minnesota
This is it. Scamp Side Dinette and Sleeping
Old 09-01-2010, 02:03 PM   #3
Vickie B.'s Avatar
Nebraska
Thanks Kevin! I'm trying to get up the nerve to make my front bunk into a dinette like that, AND have the bed, AND have your extension!
I'd almost rather just take out the fiberglass piece and make a separate dinette/couch frame, so as not to ruin the original fiberglass front seat.
Under the front seat of the Perris Pacer there is a "hump" on each side. It does not look like other campers have these in the way, because some people have built in a porta potty under the front bunk on the door side. Mine almost look like wheel wells, but there are no wheels there!
Old 09-01-2010, 05:18 PM   #4
Lizbeth's Avatar
Vickie, many Bolers have those humps including mine. I keep my potty under the back dinette which is a permanent bed. My front area fiberglass is U shaped and has a low spot in the middle for a potty which is the foot well for the dinette mod. We also use it as a bed for hubby, the back bed is just not big enough for both of us to be comfortable.
Is yours just a couch with no opening in the front of it?
Old 09-01-2010, 07:44 PM   #5
Vickie B.'s Avatar
Nebraska
Hi Lizbeth,.
Yes, luckily there is a door and some pretty nice storage space under the front couch, but it would be nicer if those 2 "bump"s weren't there!
Old 09-01-2010, 08:25 PM   #6
Trailer: Fiber Stream
Those aren't "bumps" actually. The floor does not rise in the corners, it drops in the center to make the potty cupboard. While you may think "same difference", it is a significant distinction frame-wise. I searched for a post about a frame-off restoration with pictures to illustrate my point, and I think I found it:
Boler #2 frame off
That drop in the floor was designed so the trailer could be low enough to fit inside a garage.
Old 09-01-2010, 08:35 PM   #7
Vickie B.'s Avatar
Nebraska
That makes sense, Frederick. Am I right in thinking I have seen some trailers who don't have those "whatevers"? Like the built-in potty Robert Johans put in his camper----it's over by the front door.
Old 09-01-2010, 08:45 PM   #8
Am I right in thinking I have seen some trailers who don't have those...
Yes, as have I. I don't remember what the distinction is, though... Why some do and some don't.
Old 09-01-2010, 08:47 PM   #9
Vickie B.'s Avatar
Nebraska
Well, at least now I know I'm not crazy
Old 09-03-2010, 02:11 PM   #10
Roy in TO's Avatar
From what I've observed the earlier trailers did not have the floor extend under the seat. (Which makes the bumps) Then they started doing it to allow more height under the bench for a porta-potty. You can't have the floor lowered across the whole trailer because the frame is there.
Old 09-03-2010, 02:41 PM   #11
Raya's Avatar
To expand on what Roy said:
I have not seen any Bolers or Scamps that do not have the dropped floor design (but I have not seen a Perris Pacer, even though it looks like a Boler clone). In other words, all of these have a dropped floor in the center of the trailer. Meaning it is "dropped" into the frame rails. The rest of the trailer (dinette area, under the kitchen, under the closet, under the front couch) is at "normal" height on top of the frame. So, although it seems like parts of the trailer are "bumps" or raised, it is actually that the middle is lowered.
The exception to this is the entryway, which is an extension of the dropped area so that you can easily go in and out. This is a built in "jog" in the frame rail on that side.
Now, where you have variations is in the front couch area. Early Bolers just have a straight-across frame member there, so the dropped floor ends at the front couch completely. In other words, the whole front couch is at the "upper" level on top of the frame, and not dropped. Thus in these trailers there is no central Porta-Potti compartment under the couch (where you can slide a Porta-Potti in and out from the main floor). If someone builds a Porta-Potti into one of these trailers, it will be about 5" higher than the main (dropped) floor.
Photos of this type:
Name:	<a title=Boler solid bench small 2.jpg Views: 10 Size: 48.4 KB ID: 30936" style="margin: 2px" />
Later/some Bolers (and all Scamps, from what I have seen), have an additional "dropped" box built into the frame, under the center of the front couch. This is the aforementioned, floor-level Porta-Potti compartment. These have a door in the base of the couch, but the top of the couch platform goes all the way across, with just lift out panels to access the side compartments.
Photo of Scamp-type, with frame cutout but upper bench straight across:
Name:	<a title=boler door hinge strengthening idea.jpg Views: 7 Size: 126.5 KB ID: 30933" style="margin: 2px" />
I think that although Robert has a Scamp, so it does have the central dropped area in the front bench, he built his potti area on top of the frame to the side of the cutout (correct me if I'm wrong):
Photo of Robert's Scamp:
Name:	blonde wood <a title=scamp 4.jpg Views: 9 Size: 31.5 KB ID: 30931" style="margin: 2px" />
Later/some Bolers have not only the additional dropped frame compartment under the front couch, but also have the upper couch platform molded with a U-shaped cutout, which enables easy conversion to a dinette (just lift up the U-shaped cutout's lid and Voila!). I have not seen this on any Scamps (doesn't mean it does not exist, but I have not seen it).
Photos of later Boler type (from some mfg. plants) with fully U-molded bench:
Name:	boler dinette with cutout bench.jpg
Name:	boler yellow dinette mod keeping bunk with table up.JPG
I have seen folks with the early "solid" Bolers have a forward box welded in during a frame-off, and in at least one case it was even a bit wider than the standard one. Of course you have to balance it with ground clearance.
As I said above, I don't know how the Perris Pacer is made, frame-wise, even though it looks like a Boler clone - so it may be different.
Raya
Old 09-04-2010, 06:27 AM   #12
Pam Garlow's Avatar
Trailer: U-Haul 1985
GREAT Explaination, Raya! It's so cooool to see all the different construction methods, and modifications. If only this website could be turned into a book.....
Pam Garlow is online now   Reply With Quote
Old 09-04-2010, 01:15 PM   #13
Vickie B.'s Avatar
Nebraska
No Kidding---thanks so much for all the great info---inquiring minds want to know---and the more I know about what's going on, the less "terrified" I'll be to do mods, etc.! I so want to be like some of you guys and gut it and make it like new
Old 09-04-2010, 01:34 PM   #14
Raya's Avatar
Vickie,
Can you explain how your Perris Pacer's frame/floor and front couch are set up? Does it have the dropped center section like the Boler/clone? A Porta-Pottie "slot" in the couch base?
Thanks,
Raya
another good find April Wilcox General Chat 22 09-29-2011 08:59 PM
Help me pleez! Newbie... Janelle Problem Solving | Owners Helping Owners 15 09-15-2007 05:33 PM
HELP to find the right trailer davidhopkins Wanted: Molded Fiberglass Travel Trailers 3 04-21-2006 06:16 PM
Help me find Lynn Musgrave General Chat 23 02-01-2006 07:56 PM
