I've been doing a bit of research into techniques for building structural panels using readily available products. Thinking of going this way for the new cabinetry, benches,dividing walls, etc. in the 17 ft.
Boler renovation. The goal being panels of
light weight, structural strength and relatively low cost.
Presently thinking of using Polyester Fibreglass resin, (the cheaper auto body type) with varying weaves and densities of fibrecloth over sheets of Polyisocyanurate Insulation sheathing. (4x8 sheets of yellow, foil covered foam from the local building supply store.). Apparently I can't use the other Pink or Blue foam as it is an Extruded Polystyrene and the Polyester resin will dissolve it. The pink or blue could be used but one would need to switch to an epoxy resin which is much more expensive here in Calgary. The foil on the yellow foam needs to be removed as the polyester resin will not adhere to it however I performed a little test and it peels easily so not a problem there.
I know it sounds complicated and it is a bit confusing keeping all the "Poly-styrene-isocyanurate-ester terms straight in my head but I think I have enough information to do some experiments.
Hopefully I can get a surface smooth enough to glue-up a wood veneer should I decide to finish the interior this way. If not, I will
paint with Interlux. Perhaps a combination
Anyone have any experience with these building techniques and can provide advice to steer me away from potential problems?
http://www.iko.com/shared/commercial...chEnerfoil.pdf
Bondo Fiberglass Resin
I will film the tests and keep you posted.
