Portable Spot AC Experience? - Fiberglass RV
Old 06-02-2013, 08:46 AM   #1
If you have experience using a portable spot AC unit, I would appreciate your input. Here's an example: Amazon.com: Portable Spot Air Conditioner: Home & Kitchen
We have a 13' Scamp with front bath. Need for AC will be very infrequent. We are not interested in a permanent installation.
morz4 is offline   Reply With Quote
Old 06-02-2013, 10:15 AM   #2
David B.'s Avatar
Name: Dave & Paula Brown
Trailer: Lil Snoozy
I have not used one in our 13' Scamp, but whenever we have remodeling done at work, the contractors use larger versions of these to cool very large areas, and they appear to work fine. If you have room in your tow vehicle, this appears to be a great idea. If you go this route, let us know how it works out, as I would probable then purchase one also. There was a posting someone who had a burro did that I think could be incorporated into the portable use refrigeration unit. They used round (sealable when not in use) vent holes, that appear to be approximately the same size as the cooling tube of the portable unit. One could even have a glass company cut a round hole in the small frosted glass by the sink, to install one of these covered vents, if you didn't want to cut through your fiberglass body.
Old 06-02-2013, 01:12 PM   #3
Brian B-P's Avatar
Any air conditioner moves heat from somewhere you don't want it to somewhere else.
  • Built-in air conditioners have a part (with the condenser) outside of with access to outside air, so they blow hot air outside to get rid of the heat.
    To have parts both inside and outside
    • small units normally install through a wall or window
    • large whole-building units are split between an indoor unit mounted like a forced-air furnace and a box mounted outside covered in vents (with plumbing between them)
    • some small split units have an outside mounted box and an inside wall-mounted box (with plumbing between them)
  • Portable air conditioners use a hose to vent the hot air outside (and preferably another one to bring outside air in), again to get rid of the heat.
    • Sometimes these are shown in ads without the hose to the outside, misleading potential buyers about the actual installation requirements.
  • There are some "spot" air conditioners which blow cold air in a very localized area, and just dump the heat into the same room, out the back or side of the unit.
Any system which does not send the heat outside will heat up the room it's in. For one person working in a factory, the cool spot around them may be all they need, and the extra heat in the big room might not matter. In a small room, trying to make one spot comfortable while putting hundreds of watts of heat into that same room seems entirely futile.
I suggest finding out what type any proposed unit might be, and ensuring that the experience of others applies to that type.
Finding a spot! Sue and Henry Camping, Campout Reports 17 06-08-2012 05:52 PM
portable toilet and portable shower Ruth G Plumbing | Systems and Fixtures 8 04-20-2012 12:36 PM
our secret spot CharlynnT Camping, Campout Reports 2 05-16-2008 08:31 PM
bright spot Legacy Posts Rallies, Get-togethers, Molded Meets (Archive) 3 06-16-2003 09:34 AM
» Virginia Campgrounds
