portable table - Fiberglass RV
Old 04-02-2006, 08:26 PM   #1
Sandra Lair's Avatar
Trailer: 1982 Scamp 13 ft
We have admired the modifications several people have made to convert their sofa seat to a small dinette. However, we didn't want to give up the porta-pottie storage that the seat provides. We just wanted a small table that we could use for eating, etc., then remove when we don't need it. I've never been fond of having to change the bed back to a table every day so I really wanted to find a way to have another table when we need it.
What I came up with is a funny-looking little table that works quite well! It is big enough for the two of us to eat, strong enough to support our TV/VCR and I also stenciled a backgammon design on it so we can use it as a game board. And by changing two of the table legs, we can even use it in our screen room.
I'll attach a few photos so you can see how it turned out. The back legs are 14" long & fit snugly between the seat & back cushions. The front legs are 28". The back of the table top rests against the cushion.
Sandra Lair is offline   Reply With Quote
Old 04-02-2006, 08:27 PM   #2
Here's another view showing the backgammon top.
Old 04-02-2006, 08:29 PM   #3
This one is to show that it is big enough for two people to eat on (just barely!)
Old 04-02-2006, 08:31 PM   #4
Here is a view under the table showing the removable legs. The legs and the hardware were bought a Lowe's. The 28" legs were just right but the other legs were 16", so I had to shorten them a couple of inches to make the table level.
Old 04-02-2006, 08:32 PM   #5
Sharon Herman's Avatar
Trailer: 1979 13 ft Trillium
Sandra,
Really cool idea. Would you mind sharing the tabletop dimensions?
Sharon
Sharon Herman is offline   Reply With Quote
Old 04-02-2006, 08:33 PM   #6
And here it is all taken apart for traveling.
Old 04-02-2006, 08:34 PM   #7
What did you use for the tabletop?
Old 04-02-2006, 08:34 PM   #8
We can remove the long legs, add two short one and use it in our screen room. The height is great between the two chairs.
Old 04-02-2006, 08:40 PM   #9
Thanks, Sharon! I just used pine shelving from Lowe's. I wanted to use oak but it was a little pricey for the width I needed. The finished table top is 16" wide x 24" long. I just rounded off the front corners with a jigsaw. I stained it & used 3 coats of polyurethane. It was really easy!
Old 04-02-2006, 08:47 PM   #10
Brian B-P's Avatar
Slick setup Sandra! I particularly like the backgammon board idea, and idea of legs setup to "step up" onto the seat.
Apparently, you two are both thinner than some of us, and tidier eaters. We wouldn't fit in that front seat space with a table; fortunately, we have 17' Boler, with more room...
Old 04-02-2006, 09:03 PM   #11
Gina D.'s Avatar
West Coast USA
VERY Crafty!
What a nice looking and functional mod. I like the table game idea!
Old 04-02-2006, 09:14 PM   #12
Well, we're not exactly what you would call "thin" but we do fit easily on either side of the table. We eat most of our meals on the campground tables but this will be our back-up if it's rainy or too chilly to eat outside. It can be removed & broken down in about 30 seconds so it never has to be in our way. It's good to have options when you're camping in a 13-footer!
Old 04-02-2006, 09:21 PM   #13
Trailer: 73 Surfside 14 / '05 Magnum RT AWD
I really like this idea. I've been trying to think of something to use as a table, but no dice. this should be just perfect. thanks a bunch.
Jana J is offline   Reply With Quote
Old 04-02-2006, 10:04 PM   #14
Ken James's Avatar
Trailer: 1978 Trillium 15 ft
Send a message via ICQ to Ken James
Brilliant Sandra! No great expense, pretty simple, and quite efficient. Great problem-solving! Go to the head of the class.
Ken James is offline   Reply With Quote
The portable shower Ken James Modifications, Alterations and Updates 19 01-06-2017 07:43 PM
portable toilet and portable shower Ruth G Plumbing | Systems and Fixtures 8 04-20-2012 12:36 PM
Portable Table Jim Bennett Care and Feeding of Molded Fiberglass Trailers 45 05-20-2009 10:12 AM
Portable Solar John Blair Care and Feeding of Molded Fiberglass Trailers 8 03-15-2007 12:39 PM
Portable Legacy Posts Problem Solving | Owners Helping Owners 55 05-27-2003 09:12 PM
